First post, by Just_Another_DOS_Lover
I'm just about to download this DOSBox program and I need to know if it can run Mortal Kombat 3 for DOS.
I know there is a nice MK3 version for Windows, but I don't like it: I can't use the Ctrl, Alt, Shift keys (I can't belive somebody who made such a good game can be so STUPID at Windows programming 😒 )
Thanks, haven't checked anything around here, hope this is not an abandoned site or something 😉 ...
Reply 2 of 11, by Just_Another_DOS_Lover
Yes, it seems to work, but with a terrible price:
VERY SLOW + NON RESPONSIVE = UNPLAYABLE
What can I do to increase the speed? I raised CPU cycles to max, frameskip between 0 - 2, no other programs running etc., but no visible change...
I have a brand new AMD Sempron 2600+ at 1.6 MHz, 256 Mb DDRAM, GeForce MX400 with 128 Mb VRAM, powerful enough for many things (like playing emulated playstation games)
If it's not working on such a computer then I have 2 conclusions:
1. Something is still not setup right, but I doubt it;
2. DOSBox it's not YET what it was supposed to be 😢
What can I do?
Reply 3 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
you switched to dynamic core ?
Water flows down the stream
Reply 4 of 11, by DosFreak
Click on "DosBox CVS Build" in my signature and use ykhwong's build.
Also as Qbix said use Dynamic core.
The fact that you can play playstation games on your computer really doesn't mean anything since DosBox and EPSX/PSXeven are totally different emulators.
Make your games work offline
Reply 5 of 11, by vasyl
Also, don't push CPU cycles to the max from the beginning. At some point it may cause some adverse effects. Start at some reasonable value (8000-10000 should work on your system) and increase only if you find that it needs it.
Side note: 256MB of RAM is rather low if you are running Windows XP. The memory is not expensive these days, consider upgrading.
Reply 6 of 11, by Just_Another_DOS_Lover
Hmm, thanks! I've downloaded the "ykhwong's build" and i'll try it soon (I'm at work right now 😒 ). I hope it will run better.
But what's that "dynamic core" you're talking about?
To the authors of DOSBox: I realy appreciate your work, it's nice that somebody is still fighting to preserve the good stuff. Keep up the good work!!!
Reply 7 of 11, by eL_PuSHeR
Dynamic core is just a tweak for improving cpu performance. It may be unstable, though and it's less compatible than normal core.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 8 of 11, by cigo30
so can you or can you not run MK3 on youre computer. i tried everithing but when i type indo dos mk3w for runing the game poof nothing happens. he said that program cant be run in dos mode?????
please help me i need to play that game
Reply 9 of 11, by wd
Rank DOSBox Author
DOSBox Author
Nobody can help you if you're trying to run a WINDOWS executable
in a DOS emulator.
Reply 10 of 11, by cigo30
???? i dont get it. mk3 is compatibile with dos, isn't it?
so what do you suggest me to do? how can i make her run. if if start her from start menu, there is sound and everithyng but picture is lame. i can only see foggy picture.
if it's any help this is my configuration
amd a64 3000+
msi k8t800
maxtor sata 160 gb
radeon 9600 pro 128
512 ddr
Reply 11 of 11, by wd
Rank DOSBox Author
DOSBox Author
mk3w.exe is for windows, mk3.exe for dos. If that executable is not
there, then it's the windows version of Mortal Kombat 3 (if that
existed, don't know). In the last case DOSbox obviously won't help.
