Reply 22760 of 52970, by brostenen
keropi wrote:
today I received these 2 cards 😀
Nice.... 😀
Reply 22761 of 52970, by xjas
Hah, I didn't think anyone ever shipped a Voodoo card with drivers on floppy. Those might be interesting to image & upload if they're not online already.
Reply 22762 of 52970, by xjas
PC Hoarder Patrol wrote:
@xjas […]
@xjas
Links for...
... the motherboard -https://web.archive.org/web/20041222204751/ht … 4000494tc.shtml
...the server - https://web.archive.org/web/20041224114237/ht … ers/8504076.pdf
Awesome, thanks! I did find the "user's guide" for the server itself (probably the same one linked there) but it completely glosses over the motherboard settings. Those will definitely be useful.
Reply 22763 of 52970, by cyclone3d
brostenen wrote:
Great... Yeah. There is something about VLB system's. Something different that are really cool. If you get tired of playing with […]
If you get tired of playing with DX2-66, then upgrade to DX2-80.
Not many people are doing systems like that, yet I think that 2xVLB cards and 40mhz FSB are great.
This is my Dx2-80 system:
Dx2or (Dextor) - A tale of a Dx2 Rebuild Log
You can also just run a DX2-66 at 80Mhz. That's what I did back in the day. Just keep it cool at it will most likely run just fine.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 22765 of 52970, by brostenen
True... If overclocking is you'r game. Personally, I like to keep everything at stock speed.
Reply 22766 of 52970, by cyclone3d
I've been overclocking ever since I saw a 25/33Mhz jumper on a 486 motherboard.
The best was when AMD came along with the Slot-A Athlon CPUs. Almost all of them were actually higher rated CPUs than what they were sold as. Pull the cover off a 500Mhz and see that it is actually rated for 650Mhz. Pull the cover off a 650Mhz and see an 800Mhz part. A couple soldered jumpers later and you have a much higher speed than what it was sold as.
YMF7x4 Guide
Reply 22767 of 52970, by debs3759
Even easier is to use a GFD. Someone at http://www.cpu-world.com/forum/viewtopic.php?t=28887 is working on making some.
Reply 22768 of 52970, by Ozzuneoj
Pabloz wrote:
bought this humble lot
Woa... that graphics blaster Eclipse is interesting looking. Apparently its a CirrusLogic GD5465 4MB card? That has to be the first graphics card ever made with that kind of colorful printed artwork on it... and pasted right onto the die too! Never seen anything like that. 😀
Reply 22770 of 52970, by yawetaG
Bid on a pretty rare MIDI module and won it:
125.28 KiB
(auction picture)
That's the IO Data MIDI-KG/APW, a Japan-only (AFAIK) MIDI module that's actually a OEM version of a Korg wavetable board in a separate housing, in this case the version for Apples. Seems to be missing only the MIDI cable...
Reply 22771 of 52970, by mongaccio
Found random PC components at the local thrift shop. Luckily all i needed to refurbish my broken pentium setup.
Shuttle Hot 553,HX chipset, with cpu, AT power supply, 4 sticks of ram and one cache module,Video and audio card. all for 18 euro.
329.18 KiB
Cpu is a p200 mmx, so i checked all jumpers, especially the VRM module addon (the vertical tiny pcb near cpu) Everything was already set up correctly for the p200 mmx.
Started it up , and no magic smoke! Dallas RTC is obviously dead.Sigh, it's not even socketed, I'll have to desolder it and apply a coin cell battery
432.61 KiB
80 megs of ram! That's quite a lot. I had only 32 megabytes installed in my mmx pc back in '97
Reply 22772 of 52970, by jheronimus
JeffBai wrote:
Full album with commentaries here: https://imgur.com/gallery/t6HiO
Your sleeper build looks absolutely gorgeous. I love Model M, I love desktop cases, and I've been actually looking to try Eizo LCD screens for my Voodoo 5 build (https://imgur.com/a/laQXm) for a while now. The aesthetics of your build really speak to me. I would be very interested to hear how well this screen works for games.
MR BIOS catalog
Unicore catalog
Reply 22774 of 52970, by TheAbandonwareGuy
appiah4 wrote:
A 3D printed front panel cover for my C1084S monitor […]
Who did your printing?
I need a bezel for my Gateway CrystalScan EV700 and my iMac G3 Bondi
Reply 22775 of 52970, by bjwil1991
I need to do that for my IBM 2115 monitor that lost its bezel years ago (plastic always breaks) that covers the display adjustments (pan left/right, stretch left/right, pan up/down, stretch up/down, curvy, brightness and contrast via potentiometers).
Reply 22776 of 52970, by oeuvre
JeffBai wrote:
Got myself an EIZO FlexScan L771 today for some UXGA action! […]
NETVISTA MASTER RACE!
Sweet monitor!
Reply 22777 of 52970, by appiah4
A very small local company printed it out of PLA plastic for 10 bucks. It was the best offer I had locally. The quality isn't great, there are gaps and the finish is somewhat rough on the inside but it will do.
I just checked that monitor out and yes, it has a very small panel door. No wonder it broke off and went missing at some point. Whoever designed these things, I want to have a word or two with them. At least we have 3D scanning and 3D printers now.
Reply 22778 of 52970, by JeffBai
The screen will work a lot better for text/still image for its long refresh delay, unfortunately. I needed it mainly for the resolution.
But there are EIZO screens that are better in this regard though, surely.
