Reply 39800 of 52793, by LuckyPiquel
I’ve scored Powerleap PL-K6-III v. 2.0 interposer. Still didn’t have time to test it but hope it will allow me to sport K6-2 or even K6-III in my Socket 7 Olivetti. However, one thing is intriguing me, why this interposer does not have small heatsink with VRM at the back as I use to see on the other interposers?
Reply 39801 of 52793, by Doornkaat
LuckyPiquel wrote on 2021-07-13, 20:06:
Nice score! Congrats.
The VRM is a switching design that will output much less heat than a linear regulator so it doesn't require a heatsink. Putting the switching transistors inside the socket saves space but prevents air movement over them so maybe that's a bit suboptimal. With good cooling on the CPU I wouldn't worry too much though.
Reply 39802 of 52793, by A001
appiah4 wrote on 2021-07-13, 16:47:
A001 wrote on 2021-07-13, 16:06:
This Gigabyte board has a self-destruct feature where a voltage regulator fries any caps nearby. Hopefully a perfect pair for the gorb after recapping.
I believe this is due to excessive AGP voltage, mostly caused by Voodoo 3 cards?
Very plausible, the Voodoo jumper on this board hasn't been shorted. The board and cpu fans turn on but I get no post beeps or video.
Reply 39803 of 52793, by LuckyPiquel
Doornkaat wrote on 2021-07-13, 20:14:
Yep I’m really happy to have it, especially because I don’t see much of these interposers around. Also thank you for the advice, I will put special attention to the cooling. Just using the occasion, any idea what I have to set on the motherboard in terms of the multiplier etc.? I’ve read couple sites already and the manual itself but they just describe how to use the dip switch on the interposer itself. Is the interposer somehow „overwrites” the settings on the mobo?
Reply 39804 of 52793, by Doornkaat
LuckyPiquel wrote on 2021-07-14, 07:18:
If you have multiplier or CPU core voltage jumpers on the interposer the corresponding motherboard jumpers should be ignored.
Reply 39805 of 52793, by Bancho
Awesome pickup! I'm surprised these haven't been reverse engineered.
Reply 39806 of 52793, by Doornkaat
Bancho wrote on 2021-07-14, 08:13:
In principle it's simple to make a new design but doing so is chore. Also CPU sockets [Edit: currently readily avaliable again] and the interposer pins are hard to source so I don't think it makes too much sense to just release a PCB design for individuals to order and assemble themselves.
Reply 39807 of 52793, by wiretap
The parts are all readily available to order, it isn't an exotic design and uses common parts. It is just that nobody has taken the time to clone it. I'm currently building a 68040 to 68060 interposer board and sourcing the parts took all of 5 minutes on Mouser and Ebay. Socket 7 PGA sockets are even more common than that. Although it would probably be better to design the top socket on a SS7 interposer with a ZIF socket so you could easily add a nice heatsink. (those are about $5)
My Github
Circuit Board Repair Manuals
Reply 39808 of 52793, by LuckyPiquel
Doornkaat wrote on 2021-07-14, 07:34:
Yep it has dip switch underneath. Thanks for the answers, can wait to play with it this weekend 😁
Right? I also had such thought first, but then I realized that maybe a lot of ppl would just rather buy Socket 7 board that directly supports K6 processor of choice. It would be seems like a easier and cheaper solution I think, but on the other hand our hobby is not always about choosing easier and cheaper way 😁
Reply 39809 of 52793, by vad4r
vad4r wrote on 2021-06-28, 19:24:
Today, his bro joined the arena 😀
936.17 KiB
Edit:
When the postman rings twice ^^
1.66 MiB
vae victis!
Reply 39810 of 52793, by mtgmackid
Bought this nice 386 minitower for $40 from ewaste:
Shuttle HOT-307
20mb ram
MediaVision Jazz card + Panasonic interface CD
2mb Diamond Speedstar64 ISA
Very happy to get the Speedstar64 in particular again 😀
Also found 3 random Biostar Socket 7 motherboard boxes lying around in an ewaste bin, turns out that they had a nice group of completely different contents. They must have upgraded a few computers back then and stored the parts for years:
PCChips M919 V1.5
PCChips M912 V1.4
Both PCChips boards have Am5x86s installed as well.
Reply 39811 of 52793, by chrismeyer6
Nice finds I wish I could find stuff like that by me but sadly there's no ewaste places anywhere near me and for the 6 years I've owned my house I've yet to see any computers or come to think of it any electronics out to the curb for garbage either.
Reply 39812 of 52793, by SteveC
chrismeyer6 wrote on 2021-07-15, 14:01:
Same here 🙁 However I simply don't have the room for everything I'd save 😁
Reply 39813 of 52793, by luckybob
(Sellers image)
Found this strange card in a junk lot with a bunch of basic video cards. I've got a soft spot for Frankenstein esque cards like this. I don't expect it to be anything special, but if I'm ever doing a build and I have to choose between scsi and pci video, I now have a perfect solution.
Reply 39814 of 52793, by wiretap
In New Jersey? There has to be.
edit: a quick search shows these are some places. There are bound to be a lot more since this was just the top search result. You have to contact these places and offer to buy things (for more than they get as a per pound recycling profit - don't worry it's cheap) once any hard drives or personal data is removed. Not all places will agree, but some will. It really helps if you know someone or a friend of a friend/family works there. The best place I've found is when cities do drop-offs in a specific location -- usually once a year. Most are just an unsupervised 40yd open ended dumpster that people set stuff in. Local dumps also have an electronics recycling section -- some allow taking stuff, some don't.
All of these sites below are listed to accept computers and CRT's as of 2021.
Englewood DPW 175 South Van Brunt Street, 07631 Englewood Monday - Friday 9:00am - 2:00pm 201.568.3401 ext. 404
Fair Lawn DPW 20-05 Saddle River Road, 07410 Fair Lawn Monday - Friday 7:00am - 3:15pm, Saturday 9-12:45pm, Sunday 12-3:45pm. Scheduled Curbside Pick Up 201.794.5341
Ramsey Borough Public Works 33 N Central Ave (Billing Address) Erie Plaza (Recycling Address), 07446 Ramsey Monday-Friday 8:00am - 3:00pm 201.825.3400 ext. 274
Ridgewood Recycling Center 203 E Glen Ave, 07450 Ridgewood Monday-Saturday 8:00am-3:00pm 201.670.3373
Paramus DPW Carlough Drive, Public Works Building, 07652 Paramus Monday, Tuesday, Thursday, Friday 7:00am - 3:00pm, Wednesday 7:00am - 6:00pm, Saturday 10:00am - 4:00pm 201.265.2100 ext. 3100
Parsippany Troy Hills DPW 1 Pump House Road, 07054 Parsippany-Troy Hills Monday - Friday 7:30am - 2:15pm, Saturday 8:00am - 11:45am 973.263.7273
DPW Recycling Center 1 Memorial Dr, 07644 Lodi Saturday 8:00am - 12:00pm 973.365.4068
Demarest DPW 22 Wakelee Drive, 07627 Demarest 24/7 201.768.5439
Rochelle Park DPW 193 Rochelle Ave, Rochelle Park, NJ 07662 Rochelle Park Monday - Friday 9:00am - 3:30pm; Curbside pickup 1st and 3rd Wednesday of the month by appointment 201.587.7740
Techrecyclers Public Drop Off 996 Belleville Tpke, Kearny, NJ 07032 Kearny Monday-Friday 9-5pm. Saturday 9:00am - 12:00pm 908.364.5386
Urban Renewal 53 Hackensack Ave, 07032 Kearny Monday-Friday 8:00am-5:00pm 973.522.0544
CLR Solutions 220 Franklin Rd, 07869 Randolph Monday-Friday 9:00am-6:00pm 877.257.7658
Clean Green Electronics Recylcing 139 Morris St., Morristown, NJ 07960 Morristown Monday-Friday 8:00am-8:00pm 888.769.2783
My Github
Reply 39815 of 52793, by chrismeyer6
All of those places are at least 2 hours north of me I live in the heart of the Pine Barrens in a very rural area. I do appreciate your time in looking up those locations thank you
Reply 39816 of 52793, by wiretap
Ah, if that's the case you need to actively seek out these types of things. You can't really expect anything to fall in your lap -- I've only had that happen one or two times out of many years. Most components that myself and others get are actively looked for. Sometimes it takes a lot of driving to get a good deal or even free item. Several times per week I'm checking various places, and come up empty handed. Every once in a while it pays off.
My Github
Reply 39818 of 52793, by PC@LIVE
Today finally after a long wait the PCI video card with ATI RAGE XL chip has arrived.
It has an on-board memory of 8MB, which is enough for Dos and windows 3.X and 9x programs, especially for resolutions below 1024x768, however the card has no drivers supplied, there is neither a floppy nor a CD.
For the drivers I still have to look for them, I hope it is not complicated to find them, however I think a lot depends on the OS, I believe that specific drivers are not needed with winXP (or higher),
I plan to install it on a socket7 PC and i430 chipset, currently I have a couple of VX on the bench and two TX PCs where I could replace the Vga with this one.
    917.24 KiB
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
AST Pentium Pro 200 MHz L2 256KB
Reply 39819 of 52793, by BitWrangler
aaronkatrini wrote on 2021-07-15, 20:29:
Finally found one! S3 Savage 2000 with 64Mb of Video Memory 😀
Yay, now you can stick it to those TNT Rivas. 🤣
