Reply 400 of 52980, by kemot001
- Newbie
I was looking for it for some time and there it is !
My retro sound card collection
http://retrosoundcards.wordpress.com/
wrote:Yup! Though I prefer to not use any of the "high end" AGP+PCI+ISA boards for just testing purposes, but AGP 4x boards work with […]
wrote:It would make a great board for vintage video card testing.
Yup! Though I prefer to not use any of the "high end" AGP+PCI+ISA boards for just testing purposes, but AGP 4x boards work with any AGP card ever made...in theory at least.
I'm using an ASUS A7V board with a Duron for testing graphics cards because of the universal AGP slot. 😉The most recent AGP+PCI+ISA boards made for consumers were Tualatin and SDRAM Socket A boards. There are newer boards with ISA (seen LGA775 Conroe boards with an ISA slot! 😳 ) but those are scary because of their price, and the ISA slot might have compatibility issues as it's a bridged ISA slot.
But with the newer boards you can run faster processors and potentially remove any CPU bottlenecks and get a truer indicator of what the video card is capable of. A card that is CPU bound on a PII motherboard might not be on a P4 motherboard.
wrote:wrote:Yup! Though I prefer to not use any of the "high end" AGP+PCI+ISA boards for just testing purposes, but AGP 4x boards work with […]
Ah, we had a misunderstanding here. With a test board, I usually mean a board that I use to test if a card isn't broken or anything! 😜
More of a hardware test instead of a benchmark test 😁
Hello everybody!
I'm pretty new to this retro computing thing. I've just bought a ThrustMaster FLCS + TQS + Elite rudders!
Very happy with it, I've just clean them and all!! 😁
The thing is, it came with no Manuals nor software. 🙁
Is there any chance for some charitable soul (yes Kreshna, that's you!) to scan the manuals and floppies for these amazing pieces of hardware???
Please....
Cheers,
Rita Graça.
My DOS machine: MS-DOS 6.22, Pentium MMX 200MHz, 64MB RAM, AWE64 Gold, 4GB HD, Philips 19" CRT, 3"1/2 Floppy, CDROM, Parallel ZIP, ThrustMaster FLCS+TQL+Elite.
Obviously, I meant take the floppy images, not scan them! Duh!! What good would that do?? 😜
Cheers,
Rita Graça.
wrote:Hello everybody! […]
Hello everybody!
Please....
I'd suggest you start a new thread. I haven't seen Kreshna post in a while I think, so he may be busy.
In your new thread, you might as well introduce yourself, always fun to read 😉
And welcome aboard! 😉
386 mainboard M-321 http://stason.org/TULARC/pc/motherboards/I/IL … -386-M-321.html
PC#1: K6-III+ 400 | 512MB | Geforce4 | Voodoo1 | SB Live | AWE64 | GUS PNP Pro
PC#2: 486DX2-66 | 64MB | Riva128 | AWE64 | GUS PNP | PAS16
PC#3: 386DX-40 | 32MB | CL-GD5434 | SB Pro | GUS MAX | PAS16
Think you know your games music? Show us: viewtopic.php?f=5&t=37532
Thank you Tetrium.
I'll do that!
Cheers,
Rita Graça.
I just picked up an NEC/ Yamaha clone DB60XG card. You can never have too much Midi. 😀 Doom and FF7 sound that much cooler with this.
Some guy optimized the E1M1 map tune from Doom 1 for the XG, check this out
http://youtu.be/UODyfKhdyQg
Let's see...so I will be using IRQ 220 for the Sound Blaster, 620 for the AWE32, 250 for the Gravis Ultrasound, and 330 for the Yamaha daughter card (I think?) IRQ insanity.
"The height of strategy, is to attack your opponent’s strategy” -Sun Tzu
“Make your fighting stance, your everyday stance and make your everyday stance, your fighting stance.” - Musashi
SET BLASTER = A220 I5 D1 T3 P330 E620 OMG WTF BBQ
^ uh yeah I'm pretty sure 'some guy' is RFNAngel, a member here 😜 😀
but yeah I have that same daughterboard and an SC55 and I personally think that daughterboard sounds better- in GM mode at least. The SC55 supports GS mode but I don't know of any games that support GS or XG.
technically every apogee general midi game is supposed to sound better with yamaha cards/modules because it was created with that sound modules
@RFNAngel
I gratefully appreciate your musical aptitude in a most gratuitous and appreciative manner. (Joseph Ducreux for "it rocks.") 🤣
wrote:I just picked up an NEC/ Yamaha clone DB60XG card. You can never have too much Midi. :) Doom and FF7 sound that much cooler with […]
http://youtu.be/UODyfKhdyQgLet's see...so I will be using IRQ 220 for the Sound Blaster, 620 for the AWE32, 250 for the Gravis Ultrasound, and 330 for the Yamaha daughter card (I think?) IRQ insanity.
How do you install it? There's no edge connector. Does it connect to a Wavetable header?
Yep, I have a CT-3900 AWE32 with the wavetable header. It should plug right into the connector on that daughterboard. I just hope I have enough room to sandwich it in between the Sound Blaster and Gravis Ultrasound. I should probably install another case fan and have it cool the ISA/PCI header. Lotsa cards.
wrote:386 mainboard M-321 http://stason.org/TULARC/pc/motherboards/I/IL … -386-M-321.html http://www.abload.de/thumb/img_2143wfcv.jpg […]
Nice haul! Especially the board and the TNT2 PCI! Never seen a full TNT2 PCI model before, only the M64 variants 😉
wrote:How do you install it? There's no edge connector. Does it connect to a Wavetable header?
let me [hotlink]post the backside of this great sounding module:
so, as you can see, there's the standard 26-pin female header.
Got myself two of these to put in my Dos rig, SLI mode (need to get the darn connector, those things are rare) I don't feel like taking an hour cutting a floppy cable with a hobby knife!
3dfx Black Magic Voodoo II
@FGB
Thanks! I'm sorry guys, I forgot to post the back of the NEC/Yamaha wavetable board. I still need to wait 20 days for it to come from China
wrote:Got myself two of these to put in my Dos rig, SLI mode (need to get the darn connector, those things are rare) I don't feel like […]
The P166? Even if you up that to a 233, you're not going to max out a single V2, let alone two of them. Those things fly. My advice is just keep one as a spare and save yourself the trouble of making the SLI cable.
Those are my all time favorite video cards. You'll be very happy running Glide titles on them.
I have an AMD 2.1GhZ system with a socket A chip and 1.5 Gigs of Ram, Audigy 2 ZS, etc. Plenty of free slots and a spare drive...should I install Win98 as a second OS and used the Glide cards with my GeForce 5200? That system should handle it easy enough. Or should I use hacked 3dfx drivers for XP?
