Reply 49200 of 52818, by paradigital
TrashPanda wrote on 2023-05-20, 15:58:
paradigital wrote on 2023-05-20, 13:53:
Looks like my Voodoo 3 3000 PCI is “only” a 2000, but it was still cheap at £50. The ones on eBay are all mentally priced! Arrived tested and working, which is nice.
The PCI Voodoo 3, 4 and 5 cards go for a large premium over their AGP brothers, if you only paid 50 quid for that card then you got a fucking steal, throw a fan on that V3 2K and OC it, the core should hit V3 3k speeds but the memory will be dependent on how fast the ICs are on that 2k but it should still OC a bit and more than enough to be noticable.
Its a nice card to have in PCI format, look after it.
I got lucky, it was advertised as an auction with a best offer, and was only listed as “3DFX vintage card”. Never expected to win it for the cheeky offer I threw in within 5 minutes of the auction listing going live, but here we are.
It lives alongside my £100 V5 5500 PCI (also a steal, but not quite as much so), and it’s AGP V3 2000 and 3000 bretheren.
Still need a V4 of some type to round out the set (already got V1s and V2s too).
Reply 49203 of 52818, by ubiq
paradigital wrote on 2023-05-20, 18:28:
I got lucky, it was advertised as an auction with a best offer, and was only listed as “3DFX vintage card”. Never expected to w […]
Congrats dude! I used to have a Voodoo 2 SLI back in the day and I'm not hopeful that I will ever again be able to own a 3dfx card of any sort unless I suck it up and hurt myself on eBay.
Reply 49204 of 52818, by informatyk
Bancho wrote on 2023-05-21, 20:07:
Bought a 19" Mitsubishi Diamond 91F Monitor. The Anti-Glare was smeared but i sorted that, but otherwise the condition was great and the Geom was spot on.
How did you removed the anti-glare? Does it looks to bright or reflects too much?
Reply 49205 of 52818, by nach
I got today a NOS Mitsubishi Amity SP, a super-ultra-mega rare 486 DX4 @75Mhz tablet pc that was opened only to take pictures of it but there is no manual.
I tried to boot it up docked at its docking station (and not docked too) and it boots but it stops in the post screen and the screen blinks showing what you can see in the captures i uploaded.
I have seen other more modern models of Mitsubishi amity (amities?) and below the “detected xxx processor at xxxMhz it uses to show the available ram and other more info. I tried removing the installed ram and booting but i get black screen and unfortunately do not have other memory modules that fit so cannot check.
Although the hard disk doesn’t even start to spin i have tired it on a different pc and it works so it is not the hard disk (btw it is a pcmcia hard disk! i thought it was going to be a normal 2.5" ide one).
I also read somewhere that Mitsubishi computers of that era don’t even start if the cmos battery is dead, so it might not be? Anyway it is soldered on the motherboard. (No leaking condensers inside, everything is super clean) not sure if it is worth the effort to unsolder and so on.
Does anybody know what could be the fault? Could be that it is rebooting in an endless loop?
I get no beeps in the post neither, only 4 low volume short beeps when i try to start up with a pcmcia to sd card instead of the hard disk. The BIOS it seems is phoenix if it helps (i cannot even enter the bios, the system halts before being able to)
The keyboard flashed the 3 lights when pushing the power button on the computer so the bios is starting doing its things
Roland MT-32, Roland SCP-55, Roland SC-88, Roland MT-90U, Casio GZ-70SP, Casio GZ-50M, Yamaha MU90B, Yamaha MDP-5, Panasonic CF-VEW212, TDK Digital Music Card 9000, Kawai Gmega
Reply 49207 of 52818, by paradigital
I've either just scored the bargain of the year, or the seller is going to realise their mistake and not ship.
£50, Rage Fury MAXX.
Fingers crossed.
Reply 49208 of 52818, by chrismeyer6
nach wrote on 2023-05-22, 07:19:
I got today a NOS Mitsubishi Amity SP, a super-ultra-mega rare 486 DX4 @75Mhz tablet pc that was opened only to take pictures of […]
It definitely sounds like you need to check if it has a Dallas RTC module with a dead battery or even just a standard coin cell bios battery that's dead. I've had quite a large number of systems not want to post properly or even power on with dead/low bios batteries.
Reply 49209 of 52818, by pampilhoso
Had to pull the trigger on this one...for 5 bucks, old fashioned compaq logo with ps/2 connector, its not mechanical, it uses NBM dome with slider. It has a very satisfying snappy keyfeel. Imaculated state except for the yellowing which I will take care with some retro brightening.
212.7 KiB
227.28 KiB
160.1 KiB
Reply 49210 of 52818, by Minutemanqvs
paradigital wrote on 2023-05-22, 10:23:
Fingers crossed.
That's a nice find if you get it and it works, even if it's a bizarre and not very useful card. But it sure is original.
Searching a Nexgen Nx586 with FPU, PM me if you have one. I have some Athlon MP systems and cookies.
Reply 49211 of 52818, by chrismeyer6
pampilhoso wrote on 2023-05-22, 14:03:
Had to pull the trigger on this one...for 5 bucks, old fashioned compaq logo with ps/2 connector, its not mechanical, it uses N […]
That is an incredible deal on the keyboard. Once you hit it with some retrobright it'll look basically brand new.
Reply 49212 of 52818, by probnot
informatyk wrote on 2023-05-21, 22:36:
I can't speak for what Bancho used, but years ago I used ceramic stovetop cleaner to remove what was left of some ruined anti-glare on a monitor. Worked great to remove the rest, but without the coating it would generate lots of static and attract dust.
Reply 49213 of 52818, by Bancho
probnot wrote on 2023-05-22, 16:27:
I used a similar method, using a product called CIF. It is slightly abrasive which is what removed the coating. I noticed the static first after removing the coating and powering on the monitor. On the second power on though the static was no existant.
The Screen is a bit more reflective in lightly lit rooms. In a dimly lit room the monitor is awesome though!
Reply 49214 of 52818, by cyclone3d
Fingers crossed.
Pretty sure that is what I paid for mine a few years ago. Was super glad I got it that cheap.
Great find!
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 49215 of 52818, by TheAbandonwareGuy
Fingers crossed.
If this is eBay and the seller doesn't ship make sure to report him for not honoring a completed purchase.
Reply 49216 of 52818, by paradigital
TheAbandonwareGuy wrote on 2023-05-23, 04:42:
Fingers crossed.
It was indeed eBay, and yes, I fully intend to ruin his 100% feedback rating if he doesn't follow through with the sale.
Reply 49217 of 52818, by Kahenraz
That's kind of a dick move. I've made errors in my own listings. I've put something up for a good deal but checked free shipping by mistake, for example. Shipping the item free like that puts me at a loss.
I did ship one of these error listings once for a Christmas ornament that was only a few dollars, mentioned it to the seller and wished then a happy holiday, and didn't even get positive feedback.
Reply 49218 of 52818, by Meatball
I wouldn’t post about the deal until AFTER it’s in hand. Someone could tip off the seller or the seller could even be floating around here. Don’t jinx it!
I certainly don’t raise hell against a seller or ever threaten them with negative feedback. Give the seller the same break you would want if you made a mistake.
I bought a Giga-byte Banshee from a seller accidentally listed for $19.90 when it was supposed to be $319.90. The seller canceled the sale, and explained the situation. I replied to the seller with a chuckle and told him I knew it was too good to be true, but it was worth a shot. That same card just recently sold for $319.90.
Reply 49219 of 52818, by Minutemanqvs
Kahenraz wrote on 2023-05-23, 07:40:
I once had that happen to me as a buyer, it did cost the seller more to ship the item than what I paid. I offered to compensate for the missing money but he politely replied that it was "learning money" for him. A really nice guy.
