Reply 51840 of 53105, by kinetix
I´m getting ready to fix five resistors in a PS/2 model 50 motherboard, destroyed by its neofit previous owner. also the damaged veins.
I rescued the machine literally form the garbage and mud. Had to disassembly the keyboard down to the springs, for cleaning.
I couldn't recover the bottom and the back, so I will have to build some replacements
    251.18 KiB
    295.11 KiB
Reply 51841 of 53105, by zwrr
Got these today:
No.1
Number Nine GXE64 Pro, 4MB VRAM
815.13 KiB
659.72 KiB
No.2
The motherboard is manufactured by Cache Computers Inc.
No information about this motherboard can be found on the internet and is not included in theretroweb.
Probably manufactured by IBM OEM, because it has a 386SLC-25Mhz processor installed, the CacheCHK program can detect the presence of an 8KB L1 Cache,
The processor under the cylindrical heatsink generates a lot of heat and it is not possible to keep your finger on the heatsink for a long time.
1.07 MiB
836.03 KiB
316.29 KiB
486DLC-40, 386-VC-H, 32MB, GD5429, ES1868F
X5-133, HIPPO-15, 32MB, Riva 128, ES1868F
5x86-120GP, SYL8884, 32MB, Trio64V+, ES1868F
Pentium MMX-233, T2P4, 128MB, TNT2, SB16
Tualatin-1.4G, 694X, 512MB, G400, Voodoo2, SB AWE32
Reply 51842 of 53105, by BitWrangler
Does look like a later revision of this one though https://theretroweb.com/motherboards/s/cache- … 386sx-model-345
edit: BTW, see if it benchmarks more like a DX33, a lot of these SLC/DLC cores seem to do about 1.5 the IPC of generic 386, more so the ones with a "486" model name, think they got the extra instructions as well as boost from cache.
Reply 51843 of 53105, by wirerogue
m919 board, amd 486dx4-100 and coast module.
1.94 MiB
Reply 51844 of 53105, by H3nrik V!
Kahenraz wrote on 2024-02-17, 16:53:
BitWrangler wrote on 2024-02-17, 16:07:
If I'm away for a bit, I only read the last two or three pages, it's a "what's going on with people now" kind of thing.
This is what I do as well. It helps me keep a thumb on what kinds of things people are interested in at the moment.
I use it to get inspiration to what I didn't know I was missing 🤣
Reply 51846 of 53105, by BitWrangler
wirerogue wrote on 2024-02-18, 17:50:
The board is '96, so see if you got a stealth DX5 under there https://x86.fr/the-odd-story-of-factory-downgraded-486s
Reply 51847 of 53105, by wirerogue
BitWrangler wrote on 2024-02-18, 21:09:
I am not very familiar with AMD CPUs, did I win?
624.52 KiB
Reply 51848 of 53105, by BitWrangler
wirerogue wrote on 2024-02-18, 22:50:
It checks all the boxes, late 96, right package code "C" step at odds with package code, so yeah, might be a 5x86 dx5 when you switch the multi setting to 4x.
Reply 51849 of 53105, by wirerogue
BitWrangler wrote on 2024-02-18, 23:29:
That is so cool. Thank you for all the info.
Reply 51850 of 53105, by buckeye
smtkr wrote on 2024-02-17, 04:15:
buckeye wrote on 2024-02-16, 13:58:
Bought these the other day for my windows 98 system. Know the ssd is not considered retro but the application is and never had a
ati branded card before so thought I'd give it a shot and see if it'll surpass the voodoo 3 it's replacing. Still kinda "sketchy" on what
drivers to use for win98 and if it'll need directx 8 or not.
I really like the Radeon. I had to choose between one of those and a Geforce 2 GTS for my main retro build. The Radeon is technically better, I think, but Geforce 2s are more common and have better drivers. That's a great looking card you got too.
Thanks, so far it runs very well. Getting 93fps in quake 2 800x 600 and 162fps in GLquake 640x 480.
Intel SE440BX P3 450 256MB 80GB SSD Asus V7700 GF2 64mb SB 32pnp 350W 98SE
Reply 51851 of 53105, by eindbaas
Today I bought the Escom pc from my youth in exact the same case and configuration as mine was. Underwhelming in terms of performance maybe, but it reminds me of happy days and that's what counts 😀
1.14 MiB
1.37 MiB
Reply 51852 of 53105, by mrfusion92
Bought an entire untested PC for very cheap because it was hiding an Asus TUV4X inside. And seem to fully work!
It came with an 1Ghz Coppermine (133 bus, nice). At first it wasn't booting with two different Tualerons but after a bios update to the latest beta, it POSTs successfully.
Reply 51853 of 53105, by Thermalwrong
mrfusion92 wrote on 2024-02-19, 21:24:
Nice 😀 Great that it's working with just BIOS updates. Do you know if Asus had similar problems to Abit? I've had to recap the VH6T board where all the caps over 100uF were bursting.
I've just done the same thing to get an Abit BH6 and a DB50XG attached to a Turtle Beach Fiji, all in an Enlight 7105 ATX case - I've got lots of slot1 motherboards but the BH6 is one of those boards I wish I'd never sold off long ago. The family PC went from a Cyrix 5x86-100 to an Abit BH6 with a Celeron 300A @ 450MHz, with my 3Dfx Voodoo 1 😀
Now I've got the Voodoo 1 (s.. plural), some Celeron 300A Slot1 CPUs and the BH6 back at last.
279.6 KiB
Of course, the DB50XG was flopping about in the case when it got here but it seems to work well.
Reply 51854 of 53105, by Kahenraz
I bought a pair of brand new ASUS MEL-M 440LX motherboards with AGP, ISA, and an onboard Yamaha sound card. There are three memory slots and even an SB-LINK connector. The capacitors are also genuine Rubycon and are in great condition. What a great little board. Lovely, lovely!
503.56 KiB
252.97 KiB
505 KiB
Reply 51855 of 53105, by mrfusion92
Thermalwrong wrote on 2024-02-20, 02:07:
I heard that Abit was the worst of all during the plague caps era. This particular Asus motherboard has near mint caps, none of them (at least visually) show any sign of failure.
Reply 51856 of 53105, by Mandrew
Got a Core 2 Duo T5470 sample nobody wanted so I sniped it. Nothing special but I have a thing for ES.
Reply 51857 of 53105, by BitWrangler
I took a punt on a mixed CPU lot "pulled from working environment" there's nothing too special in there, but it gets to my door at the same price as getting low end testers twice, i.e. about $20 a purchase with the shipping in. Hoping the Phenom II black edition turns out good, but there's also a windsor to screw with, a PentiumD, some core2 class to act as scratch monkeys for modding tests, and some randoms for testers, might end up divesting some of the spare on the freebie thread. Had laptop in the title, but only 5 are mobile I think, possible a couple of those might offer a minor speed bump to machines that are in the fam.
I was looking for other stuff but got sidetracked as you do. Another cheap/variety lot that caught my eye was "Lot 24 Intel Pentium & AMD Mixed w/ Pentium-II ..." price seemed reasonable for good variety, kind of a 96-2006 starter kit, though a bit socket A heavy.
Reply 51859 of 53105, by megatron-uk
Made an offer on a ISA single board computer, an Advantech PCA-6145 - looks to have either 16 or 32mb ram and a DX4. Has 1mb C&T 65550 video on a VL bus and can take pc/104 cards. It's pretty small - no longer than a 16bit ISA card.
Have been wanting to build a tiny 486 for a while now , I will be using a with a passive 3 slot ISA riser and putting all of my big box towers away in storage.
My biggest issue will be the case... I'm an atrocious wood worker!
https://www.target-earth.net
