Save States - Proof of concept
Reply 161 of 227, by tikalat
direct3d.cpp
+ Allow stretch-to-window Direct3D fullscreen feature (autofit=true + aspect=true + fullscreen=original)
dosbox.cpp
+ Add 'autofit' option
004
midi.cpp
+ Do manual device reset (turn off notes, controllers) on open
(seems to fix random Roland VSC -system- crashes from bad VSC states)
Test build (new dosbox.conf included)
http://www.sendspace.com/file/3g9kr8
TODO:
- May add new mixer savestate idea (only save/load devices that are created)
- May add Innova savestate
- May add Adlib savestate
- Look at paging again
- Experimenting with something called win32 shark_cheater (see ngemu forums - ePSxe_shark) (can't contact original author but seems free source) (modifying for possible relocatable RAM)
    dosbox-svn-daum___diff.7z
    19.62 KiB
    224 downloads
    ykhwong svn-daum 2012-05-21
Reply 162 of 227, by robertmo
You can always use gamewizard32 with dosbox if that is what you are looking for.
Reply 163 of 227, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
is there one diff against current SVN of Dosbox? If I understand correctly it is against Yhkwongs which has countless other patches...
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 164 of 227, by tikalat
Thanks! Must check this out. 😀
Krondor ch4 is brutally hard. 1st dungeon and my team is already half-slaughtered.
Unfortunately only diff is against ykhwong build.
If I can get svn to compile, I'll look it over,
Reply 165 of 227, by Dominus
DOSBox Moderator
That would be great. I'd really like to give it a try on OSX and am not sure whether yhkwongs source will built without a hassle...
Reply 166 of 227, by tikalat
render.cpp
+ Fix fps loadstate mistake
001 - dosbox svn
Full POD support
- Only savestate support. Zero fixes added.
Test builds (dosbox + ykhwong)
http://www.sendspace.com/file/pkxgaz
Dosbox win32 build works okay here. Multi-diffs now attached.
(tested meaning various Krondor states load from CMOS okay)
    ___release.7z
    50.16 KiB
    221 downloads
Reply 167 of 227, by tikalat
svn-daum
006
+ add adlib POD (all versions)
+ use new mixer sub-POD ID enforcement (cut down on accidental loadstate crashes)
svn-dosbox
002 = same additions
Test build
http://www.sendspace.com/file/q25c3v
(Edit: fixing run-time crash error)
(Edit2: done fixing)
    ___release.7z
    56.29 KiB
    224 downloads
    multi-diff
Reply 168 of 227, by Gamecollector
Sometimes after the load state - the restored video mode is wrong. 720x576x8 in the place of 640x480x8, two black borders (right and bottom). Tested game - Supaplex.
The glitch isn't constant, from the same save the result may be wrong or right...
Reply 169 of 227, by tikalat
That's an odd bug. If the console is mentioning '720x576x8', it means the game attempted some type of resolution switch - there's a special case exception iirc though.
I'll check it out (currently absorbed by other projects). Does it happen at any place in the game (menus, in-game, loading, title)?
The svn-daum debugger window input doesn't work either but don't know why (svn-dosbox is okay).
Reply 170 of 227, by ykhwong
Sorry, the current svn-daum build of debugger is broken. (Alt-pause won't work for debugging) Please try 20120220 one which should work.
Reply 172 of 227, by Gamecollector
Your current build write the videomode info only after the video mode switch.
Loading of the savestate isn't considered as such switch.
So - just the "state 1 loaded!"
By the way, the glitch can be seen in the window mode too...
Reply 173 of 227, by ykhwong
robertmo wrote:
ykhwong is there any place where we can post bugs about your builds?
can it be here DOSBox SVN Builds
or you want to start a separate thread about your build only?
I understand that this is going off-topic. This thread must be about the development of save states, not specifically about a bug report of my builds.
Actually there's currently no place to post bugs on my website due to some server limitations. I couldn't afford it for a long time.
Either way is okay to me though my releases are not officially supported here by dosbox developers.
Reply 174 of 227, by laxdragon
Perhaps you could consider hosting your branch on github. They offer a bug tracker and so on.
These days I prefer git for all my revision control needs.
laxDRAGON.com | My Game Collection | My Computers | YouTube
Reply 175 of 227, by tikalat
svn-daum 007
svn-dosbox 003
render.cpp / render.h
+ Add scrn_ratio to savestate
+ Fix loadstate problems with aspect ratio
Test build:
http://www.sendspace.com/file/h0yiti
NOTES:
This should fix the original + aspect ratio window size problems (use original screen ratio)
    ___release.7z
    56.71 KiB
    234 downloads
    multi-diff
Reply 176 of 227, by Gamecollector
Good. Supaplex wrong video mode is fixed.
Reply 177 of 227, by tikalat
004  svn-dosbox
dos_files.cpp
+ add loadstate crash protection
cpu.cpp
+ use new cpu core switching idea
First one fixes a hang bug that happened with virtual files.
Second one lets you save using dynamic core. Exit. Switch to simple core. Reload state and continue (ex. debugger)
Test build:
(Removed per policy request)
NOTE:
I plan on creating a new thread for specifically ykhwong svn-daum support. Continuing the savestate + improvements over there.
    ___release.7z
    37.41 KiB
    201 downloads
    svn-dosbox 3780
Reply 178 of 227, by tikalat
Continuing the save state improvements
008
cpu.cpp
+ Use new loadstate idea (safely allows switching cores)
dos_files.cpp
+ Add safety check for loadstates (virtual files - CON, AUX, PRN)
glide.cpp
+ Add gulikoza's recent texture fix
Test build
http://www.sendspace.com/file/jcr07x
    svn-daum 2012-05-21.7z
    27.99 KiB
    211 downloads
Reply 179 of 227, by tikalat
Thanks to robertmo + Qbix for helping out. 😉
Super'ish patch.
009
munt
+ Add mt32.partials conf line
(can change max partials from 32 -> 0-256)
010
vga.h
+ Amstrad video mode fix
innova.cpp / innova.h / reSID
+ Savestate POD (ex. Ultima 6)
3781-3782 svn fixes
+ IRQ0 (M.U.L.E), Mouse (Settlers 2)
tester
NOTE:
Actually have an idea for paging. Remove all existing vars. Create just skeleton shells and keep a list of them. Per module.
Then loadstate each one up and get the crazy amount of ptrs to line up.
TBD when I want to play around with Win 3.1 again.
    35.04 KiB
    204 downloads
