Old 486 Project Box
Reply 20 of 27, by DonutKing
My 486 lacks L2 cache and I think it's a bit overrated anyway. It's certainly not terrible without it.
Yeah I think this is true. When I had the M919 it still performed pretty well without the L2 cache. On my 386 I doubled the cache from 128kb to 256kb and didn't notice any difference- even 3dbench didn't score any higher.
Of course, killing the L2 cache on a 386 makes a noticeable difference to performance but I think the onboard L1 cache on the 486 CPU goes a long way to bridging this gap so L2 cache is not as critical.
Reply 21 of 27, by retro games 100
Alphakilo470 wrote:
BTW, @retro,
If you can, take a look at your PCChips m919. I just noticed that on mine, there's no visible leads coming from the outer-most pins on the CPU socket and that there's visible metal in all but the outer-most pin holes. While I did get mine to post with the Pentium Overdrive chip which uses those pins a 486 would leave empty, it makes me think an Overdrive would never be a good idea for that board.
I'm sorry, but ATM I can't find this mobo. I'll keep looking...!
Edit: Damn, I can't find it. I found some other 486 mobos, but not this one. Sorry about that. It'll turn up eventually however...
Reply 22 of 27, by retro games 100
Alphakilo470 wrote:
BTW, @retro,
I found the mobo, at last! I hope this pic is OK.
Reply 23 of 27, by Tetrium
I can't see anything though. Can you take a pic with less light?
Can you see anything in the outer layer of pin holes?
Btw, does the back of the mobo have 3 or 4 rows of solder dots behind the socket?
My retro rigs (old topic)
Report spammers here!
Reply 24 of 27, by Alphakilo470
On the m919 I have, there's a full four rows of solder dots to correspond with the four rows of pinholes on the socket. However, only the inner three rows have pins sticking through them. The outer most layer literally has nothing but the empty solder dots. Aside from that, there appears to be no wire traces coming from them either.
Unfortunately, the focus on my camera is not very good. However, I'm hoping this picture came in clear enough. If you view it in full size and look closely, you should be able to see what I'm talking about.
Reply 25 of 27, by retro games 100
Unfortunately, I've caught some winter bug, and I'll have to abstain from the exciting world of retro hardware for a few days. I'll dig out that mobo again as soon as I can, and take a pic of the underside.
Reply 26 of 27, by Tetrium
Ah damn. Hope you get well soon 😉
(and no touchy me plz!!!1 😜 )
Reply 27 of 27, by retro games 100
Thanks a lot. I feel ok to browse vogons, but I've got a temp and pulse is high, and I feel like c--p, hehe.
