Reply 20 of 42, by rug
Are these rare? Would it be possible to make one of those? I'm quite handy with a soldering iron!
Cheers,
Rita Graça.
My DOS machine: MS-DOS 6.22, Pentium MMX 200MHz, 64MB RAM, AWE64 Gold, 4GB HD, Philips 19" CRT, 3"1/2 Floppy, CDROM, Parallel ZIP, ThrustMaster FLCS+TQL+Elite.
Reply 21 of 42, by Mau1wurf1977
I don't see why not.
They shouldn't be expensive though. I think mine was 15 or 20 bucks.
My YouTube channel
Reply 22 of 42, by batracio
You can find some schematics for a do-it-yourself cable here:
http://www.midi.org/techspecs/electrispec.php
Reply 23 of 42, by rug
This seems a bit more complicated than what I was expecting. 🙁
In fact, I was hoping for a kind of Y cable, with a DB15 male, to connect to the sound card, and a Din-5 + DB15 female (to connect to the SC-55 and joystick, respectively).
I can't quite understand those 2 schematics in your link...
Cheers,
Rita Graça.
Reply 24 of 42, by Mau1wurf1977
10 bucks shipped:
http://www.ebay.com.au/itm/Music-Instrument-E … =item2310b8703b
My YouTube channel
Reply 25 of 42, by rug
Mau1wurf1977 wrote:
That's brilliant!
Thanks, Mau1wurf1977.
Cheers,
Rita Graça.
Reply 26 of 42, by rug
Would it be possible to connect 2 sound cards: one for the SC-55 and the other for the joystick?
Cheers,
Rita Graça.
Reply 27 of 42, by Mau1wurf1977
Can you be more specific please? If you mean the cable I linked, no it's meant to connect 1 joystick + MIDI In and out into a single joystick port (Sound Blaster).
My YouTube channel
Reply 28 of 42, by batracio
The schematics are not that complicated, it's just that soldering the wires is not enough; you will also need some resistors, diodes, inverters and opto-isolator if you want to build a good quality adapter.
Yes, but most times a single sound card with both joystick and Sound Canvas connected to the same gameport will do the trick. Only if you want to play a game with the joystick and hear the music on the Sound Canvas simultaneously, you would need a second gameport to separate them.
Reply 29 of 42, by rug
That's precisely what I want: play a game, hear its music on the SC-55, and its sound effects on the Soundblaster.
So, if I use a Y cable, I can't do that? I need 2 sound cards, right?
Cheers,
Rita Graça.
Reply 30 of 42, by batracio
Yes, but if you mean a Sound Blaster 16 or 32, you would need two sound cards anyway. If you try to use both MPU-401 UART and digital sound on the same SB16, the infamous hanging notes bug will probably arise.
Reply 31 of 42, by rug
I have an AWE64. My plan is to use it for sound effects and the SC-55. Then use an ISA I/O card to connect the joystick. What do you think?
Other thing, what's so special about the Yamaha YMF-719?
Cheers,
Rita Graça.
Reply 32 of 42, by Mau1wurf1977
Are you sure about that?
I'm 99% sure that you can use your joystick while having MIDI music. That's the whole point of getting this cable.
AWE64 is perfect for the SC-55.
@rug
Just buy that $10 cable and don't overthink the issue 🤣
Reply 33 of 42, by rug
Mau1wurf1977 wrote:
Are you sure about that? […]
@rug
Thanks Mau. That was what I thought but me being a newbie, I like to listen to what others have to say. 😉
Do you think I could try successfully the setup I described above, with the IO card?
Cheers,
Rita Graça.
Reply 35 of 42, by batracio
The potential issue I was talking about is the usage of pin 12 as MIDI OUT and pin 15 as MIDI IN being itself a non-standard implementation of the gameport interface that some standard devices may be unaware of. Those pins were originally intended for grounding buttons 3 and 4 and +5V DC respectively. Nothing prevents a joystick manufacturer from building a device that conforms to the standard gameport specification, and use those pins to handle additional buttons. Are you sure that 99 out of 100 joysticks follow the non-standard implementation with MIDI IN/OUT, instead of the original specification with +5V/GND? Well, I'm not that sure, so I thought it would be useful to warn about this potential issue. More info here:
http://www.epanorama.net/documents/joystick/p … .html#connector
http://www.epanorama.net/documents/joystick/p … #ycableproblems
Reply 37 of 42, by rug
batracio wrote:
The potential issue I was talking about is the usage of pin 12 as MIDI OUT and pin 15 as MIDI IN being itself a non-standard imp […]
In that case, wouldn't the IO Card\Sound Card solution be a good solution?
Cheers,
Rita Graça.
Reply 38 of 42, by batracio
I would first try a single gameport setup with the AWE64. If that works, it will keep things simple. But since your HOTAS system (Flight Control System + Throttle Quadrant System + rudder pedals) is old stuff with lots of extra features, there are some chances of hitting the MIDI IN/OUT issue when using it along with the Sound Canvas. If so, I would connect the Sound Canvas to the sound card, and the HOTAS system to the I/O card. The former card is guaranteed to have a gameport with MIDI IN/OUT, while the latter card should have a standard gameport with +5V/GND if needed.
I have attached some files for a Thrustmaster FLCS + TQS + Elite DOS setup. You will find more info, drivers, patches and utilities for Windows 9x here: http://www.stickworks.com/
    tm_flcs.zip
    838.48 KiB
    167 downloads
    ThrustMaster FLCS+TQS+Elite DOS Files
Reply 39 of 42, by rug
That's brilliant! Although I plan to use DOS only, not windows.
Thanks batracio.
Cheers,
Rita Graça.
