Tillamook 266MHz and working L2 cache?
Reply 340 of 503, by Nemo1985
Is there an easy way to inject the microcode or check if it is present?
Once I asked Jan to add the microcode to my epox ss7 board and he answered it was already present, despite of that the board never posted with the tillamook.
Reply 341 of 503, by Sphere478
Nemo1985 wrote on 2021-03-02, 19:08:
it’s possible for the board to be incompatible or set wrong but still have a bios that supports it.
Verify voltages are correct and try some of the pin mods.
Not having the micro codes usually won’t prevent it from posting. It will just show up as wrong or unknown cpu.
Sphere's PCB projects.
Reply 342 of 503, by the_patchelor
Worked on my Tillamook again a bit after it seems too work fine on Asus XP55T2P4 Rev. 3.0
On my ASUS P/I-P55T2P4 (rev.3.1) it gave freezes in some games or already when trying to load autoexec and config.
Both need L2 mod of course, BF2 "extended mod" and VCC2DET mod as both boards will not recognize dual rail cpu and send 3.2v core voltage.
I haven't applied the VCC2DET before on the Asus XP55T2P4, where it seems to work fine without BUT probing the core voltage showed 3.2v ouuuups. So far the system was able to run my simple benchmark and game tests without showing any issue why I thought everything was okay... but it wasn't...
On the P/I-P55T2P4 the high single rail voltage was crashing always after a few seconds or minutes.... why I was wondering after it "worked" on the ATX version of the Board.
So far, probing the voltage showed the problem and thanks to the guys here, I was able to troubleshoot and to fix...
1.03 MiB
1.29 MiB
OC 266@300 running 4x75Mhz
613.31 KiB
684.93 KiB
688.74 KiB
Reply 344 of 503, by Sphere478
the_patchelor wrote on 2021-03-03, 09:55:
Worked on my Tillamook again a bit after it seems too work fine on Asus XP55T2P4 Rev. 3.0 On my ASUS P/I-P55T2P4 (rev.3.1) it ga […]
can you explain the 4x extended mod?
Reply 345 of 503, by the_patchelor
how I understand:
"normal" BF2 mod is just routing BF2 to NC pin, as on Tillamook BF2 Pin is on a different position.
for some Boards (at least the P55T2P4's) "Forcing" BF2 is required as without only 3.5x multi boots (=will bot as 233mhz CPU). BF2 can be activated when it will be connected to ground (VSS) or voltage (VCC3) pin.
the P55T2P4's do not have a factory jumper for BF2 (multi >3,5) so e.g. for a AMD K6-300 (4,5) you also have to bridge/mod the socket ...... then I think the normal "BF2" mod (BF2-NC) is enough. But right now I don't wanna have a flying cable or hard modded Board...
Nemo1985 wrote on 2021-03-03, 15:22:
Sorry for the dumb question, so it does work without issues on the P/I-P55T2P4?
Thank you
no issues once you do the 3 bridges on the CPU.
but I only can talk about my version/rev. 3.10
Reply 346 of 503, by Sphere478
the_patchelor wrote on 2021-03-03, 16:24:
how I understand: "normal" BF2 mod is just routing BF2 to NC pin, as on Tillamook BF2 Pin is on a different position. […]
how I understand:
Thank you
is it connected to all three or just the outer two? I May need to do this also. Where do you set the jumpers when using this? I tried the jumper across the inner two and tried no jumpers and 2x jumpers but nothing except 233. my motherboard has options for 1.5/3.5x, 2x, 2.5x, 3x
we should update the picture guide for this
Reply 348 of 503, by Sphere478
(Edit from the !!!future!!! ^ I tried connecting all three, it released magic smoke from my motherboard. But I was able to repair it thankfully. do not connect all three) (this happened a few months ago though so maybe I did it wrong, in any case, maybe try the mod with a resistor to be sure nothing goes pop)
the_patchelor wrote on 2021-03-08, 18:37:
it works if all three are connect and also if only outer two.
Multi jumpers on board are then ignored. you can leave them or set what ever
Sweet!
Someone should update the pic that shows the mods.
Reply 349 of 503, by galanopu
Thank for the MODs!
Well, I did some benchmarks of the Tillamook.
Overclocked to 420Mhz (3.5 x 120).
I used my Asus P5A v1.06 with 1MB of cache.
Compared this to the 512k model and to a K6-2.
Here is Video:
https://www.youtube.com/watch?v=fqB4yCssUCM
    413.38 KiB
Let's mod everything! Check my youtube channel:
https://www.youtube.com/channel/UCZ6ULBqIKhxuNslAbqFNJUg
Interested in my devices? Check my store:
https://migronelectronics.bigcartel.com
Reply 350 of 503, by Sphere478
galanopu wrote on 2021-03-11, 09:13:
Thank for the MODs! […]
Thank for the MODs!
Here is Video:
I was expecting it to totally destroy the k6-2 guess not so much.
Thanks for this review! Very informative!
Reply 352 of 503, by bofh.fromhell
So I decided to join the Tillamook fun.
Choose a GA-5AX (rev 3.0) for the experiment.
Added the green and the yellow (VCC and L2), set the MB to 2.0v, 66MHz FSB and 3.0 multi.
MB posted, showed "Tillamook 200MHz" on post and Booted into W2K .
CPU-z showed 100MHz and no L2 for some reason.
Rebooted into DOS and ran speedsys, mem graph clearly showed working L2.
Shut down and set multi to 3.5, once again success at 233MHz.
And here is where it went wrong.
Figured that I should probably double check CPU voltage with a multimeter.
I measured 1.5v, which was weird I thought.
And while I was pondering this the system crashed and the now familiar smell of defeat spread around the CPU area.
Turns out that despite my rather overkill insulation of the soldered jumpers the CPU cooler must have added just a tad to much pressure and shorted something.
I must have nudged the CPU cooler ever so slightly while poking around.
Now I curse myself for using a huge FEP32 when just about any cooler would have done.
So I had my fun, it worked for a while and thankfully the motherboard is OK.
The CPU however is not.
But that's OK, its not like they are expensive or rare (yet).
Reply 353 of 503, by Sphere478
shame 🙁 get another and keep experimenting!
Reply 356 of 503, by GRIFF
Hello guys.
See my result of overclocking this great CPU at march 2020 with enabled L2 cache.
https://hwbot.org/submission/4382631_griff_su … min_54sec_954ms
https://hwbot.org/submission/4382632_griff_wp … min_15sec_271ms
https://hwbot.org/submission/4266296_griff_cp … _266mhz_533_mhz
Reply 357 of 503, by Sphere478
GRIFF wrote on 2021-08-20, 09:39:
Hello guys. See my result of overclocking this great CPU at march 2020 with enabled L2 cache. https://hwbot.org/submission/43826 […]
Hello guys.
You got it to 533mhz?! Woah
How high would it go on air cooling?
What bus speed?
Were you limited by bus, memory, or core clock
Reply 358 of 503, by LeFlash
Sphere478 wrote on 2021-10-20, 21:16:
You got it to 533mhz?! Woah […]
What bus speed?
I had no problems pushing it beyond 400MHz.
It doesn't get that hot, even at those temps.
Reply 359 of 503, by feipoa
What was the result with running dual Tillamooks? I recall reading somewhere that Intel removed SMP on the Tillamooks entirely, not just disabled it. Probably to reduce the transistor count. I tried dual Tillamooks on a socket 5 system using Evergreen and Kingston adapters, but it will only ever see one CPU. If I use the regular P233MMX chips, the system detects both.
