First post, by 133MHz
On December last year I was given three of these "thin client" systems at the place I worked on back then:
They were all missing one part or another (case, RAM, cables, switches, drive cages, etc) but I managed to put together a complete system from the lot. Here's the motherboard itself, a CV860C:
...and the I/O ports:
This thing is pretty packed: VIA Samuel 533MHz CPU, PC133 SDRAM slot, 4 serial ports (accepting funky protocols like RS422/485), parallel, PS/2, LAN, 3 USB 1.1 ports, sound, 40 & 44 pin IDE ports, CF card slot, DiskOnChip slot and a totally fanless design, running straight from an external 12V power brick.
My first thought was to use it as a silent but powerful router/firewall box, but its sole LAN interface, no internal expansion and slow USB wouldn't cut it with my 40Mbps broadband so I abandoned that idea. Then I saw that the onboard sound had legacy SoundBlaster emulation and I thought this would make a killer totally solid-state DOS/9x gaming setup if I add a CF card! so I added a cheap 4GB Kingston CF and I tried to install Windows 98SE on it... it was unbearably slow and I couldn't get the SB emulation to work, so I put the whole thing away. Leason learned: cheap CF cards make for really bad poor man's SSDs.
I've now got a better 2GB Dane-Elec CF card, not a speed demon by any means but it's actually usable now so it has revived my interest in getting this awesome tiny PC to run DOS games with sound.
Here's the obligatory SpeedSys 4.78 screenshot:
It has the A3 revision BIOS installed which seems to be the latest one, and I'm using the drivers I found at this website.
The problem is, I still can't get SB-emulated sound from DOS or Windows to work. There's these options in the BIOS:
Back in December 2011 when I first tried it pretty much nothing worked because all four serial ports were enabled and gobbling up IRQs and whatnot so I ended up disabling all of them to free system resources. The onboard sound chip is a Realtek ALC201A and it works fine on Windows, the SB emulation device is also detected correctly
but it does not produce any sound whatsoever in either DOS or Windows. Games like Wolfenstein 3D see a Sound Blaster device but there is no sound output, if I set Windows to use the SB mixer exclusively by setting the "Use only preferred devices" option I also get no sound at all. What could I've been doing wrong? Any recommended diagnostic software I should run to shed some light into the problem?
For me there's something uncanny about using an x86-based PC with absolutely no moving parts, it even feels a bit eerie to see the computer working but not being able to hear it, but at the same time it's really cool and I'd love to get it running correctly and enjoy some solid-state DOS gaming!
http://133FSB.wordpress.com
Reply 2 of 15, by 133MHz
Excuse me for not expressing myself very clearly. AC97 sound works fine in Windows, legacy SB sound doesn't work in neither Windows or DOS. The non-PnP SB-emulation device takes up the right system resources and some games detect it correctly, it just doesn't produce any sound.
The latest generic driver from Realtek doesn't work (Code 2). There is a physical ALC201A chip on the motherboard but I noticed that Realtek's own Sound Manager also refers to it as VIA3058. There's a VIA AC97 driver for this board so I tried it and it works fine, but still no legacy SB sound.
Wolfenstein 3D 'sees' a Sound Blaster compatible device, Commander Keen 4 doesn't. Creative's DIAGNOSE.EXE doesn't find any sound hardware.
Reply 4 of 15, by WolverineDK
epicbrad wrote:
I wonder if there are any USB sound card solutions that will solve the problem....
As such a question is a pretty good question, and why not go for the source then. And find/hunt/buy/salvage/dumpster dive a Creative USB soundblaster ? Cause they work quite well(I sent such a device to a friend of mine and it works). Unless you happen to get into a driver issue..
Reply 5 of 15, by swaaye
If SB DOS emulation isn't working it may be due to missing non-maskable interrupt support on the motherboard.
Also, I am not sure any USB sound devices can do DOS. Seems unlikely. Certainly not outside of Windows.
Reply 6 of 15, by WolverineDK
Okay, but as I said. It was just a thought, but am I wrong by saying perhaps he could dual/triple boot with Freedos on a partition, cause they support USB. Or is that more like USB CD/DVD etc. ? Instead of USB soundcards !?
Reply 7 of 15, by swaaye
It looks like FreeDOS has some support for USB storage and input devices by various drivers.
Besides, without NMI support, he needs a real ISA sound card to get DOS sound AFAIK. Or a PCI card with a SBLink connection.
Reply 8 of 15, by WolverineDK
Then I bloody hope, he does not have a hardware failure. Cause then he is pretty much SOL.
Reply 9 of 15, by 133MHz
To rule out the possibility of hardware failure, since I have three identical systems I have tested the other two, same exact thing.
I'm starting to think that the SB-compatible sound was never implemented correctly in the first place, but why have such explicit BIOS options then? Is there any way to check if this board lacks NMI support?
Reply 10 of 15, by swaaye
Yeah since the BIOS has SB settings, I think the board probably does support it. I think you need the VIA audio drivers for that southbridge instead of the Realtek driver. They mention DOS SB emulation.
http://www.via.com.tw/en/support/drivers.jsp
Work your way to the Windows 98SE AC97 sound drivers. There is also a link in the description there for a SB driver for pure DOS.
Delete that SBPRO driver you have installed as I'm sure that won't work.
Reply 11 of 15, by epicbrad
Perhaps some variables / files need to be parsed from command line pre / during OS load? along with win vxd / dll's?
What a frustrating problem. Are there any board updates?
Have you tested the audio in 8-bit only for dos stuff? ie doom, Rott stuff that needs it fed in rather than W3D etc
Reply 12 of 15, by 133MHz
I haven't had much time lately to mess around with this thing, and I have also been without Internet access, but I've finally solved the problem. You've hit the nail right in the head, swaaye. You provided the crucial piece of the puzzle I needed to figure the rest out. 😉
That leads here:
The audio drivers provided on this website are general sound effect drivers with common functions. System manufacturers and motherboard vendors customize audio hardware and software and therefore, to ensure optimal sound quality and compatibility, we strongly recommend you to obtain the system-validated and certified audio drivers directly from your system manufacturer or motherboard manufacturer. If you use audio drivers provided on this website and you experience a difficulty, we recommend that you uninstall them and instead use the latest drivers supplied by your motherboard or system manufacturer. This driver supports DOS sound for VT82C686A/VT82C686B/VT8231 only. The VIAAUDIO.COM file mentioned in the Readme concerning DOS sound can be obtained from this old audio driver package.
SB-emulation sound in Windows
The old audio driver package (68MU220b.zip) is exactly what we need. It comes with DOS drivers and both WDM and VxD Windows drivers. The VxD drivers must be used for the SB emulation feature to work!
A proper driver will be installed for the SBPro emulation device when you use the VxD driver. Unfortunately the VxD driver performs worse than the WDM driver - the sound output is a bit weird and distorted (kind of like if both speakers were out of phase but not quite), but if you want SB-compatible sound, you've got no other choice.
SB-emulation sound in MS-DOS
In order to enable the SB-emulation feature of the VT82C686 in pure DOS mode install the DOS driver by running INSTALL.EXE found on the \DOS directory. This will create a VIAUDIO directory on the root of your hard drive and it'll modify the AUTOEXEC.BAT file for you, but it won't work straight away! You need an additional file which is not included with the aformentioned DOS driver: VIAFMTSR.COM
Just add the VIAFMTSR.COM to the VIAUDIO directory and call them in this exact order through your AUTOEXEC.BAT or DOSSTART.BAT
C:\VIAUDIO\VIAUDIO.COM
C:\VIAUDIO\VIAFMTSR.COM
SET BLASTER=A220 I5 D1 P330
You should have SB-compatible sound working in DOS now! A downside of these drivers is that they take a crapload of conventional memory, making it difficult to run your games. You might try loading them high, I had limited success with that.
Finally I managed to get SB-compatible sound to work so I can use this mini PC as a cool solid state DOS gaming rig I can just throw in my backpack and carry with me. 😁 Sound quality is so-so but for a specialized board with no expansion possibilities I'm grateful to even have an option. It took some time and effort to get it working but now it's all documented in case someone else ends up with the same problem. I have mirrored the files here in case they ever disappear from the VIA website. I know how frustrating is not being able to find some old and obscure driver file anywhere.
Thanks a lot to everyone who helped! 😀
    68MU220b.zip
    4.27 MiB
    455 downloads
    DOS and Windows WDM/VxD drivers for VIA VT82C686B
    viafmtsr.zip
    14.22 KiB
    477 downloads
    VIA FM TSR (needed for SB-emulation sound in pure DOS mode, not included in main driver)
Reply 13 of 15, by Mau1wurf1977
Great outcome, well done and thank you for updating the thread!
My YouTube channel
Reply 14 of 15, by Merri
I have to thank you for this thread! I bought myself a EP-8KTA3PRO motherboard that is VIA-KT133A based and does include the same VT82C686B sound chip. With the information here I got sound working under DOS (Jazz Jackrabbit keeps crashing though). I also found it easy to load the sound driver to high memory and still have more than 600 kB available, if anyone is interested I can post my CONFIG.SYS and AUTOEXEC.BAT - I'm running on a Windows 98 shipped DOS.
At the moment I'm researching an ideal general DOS gaming system for myself and this is the high end side of things. Of same generation of motherboards I also have nForce2 based ASUS A7N8X-VM/400 but it is just awful for DOS gaming and legacy Windows stuff doesn't work quite right on it either.
Reply 15 of 15, by MarmotaArmy
Sorry for the necro
I have the same thin client and I can confirm it works, the FM sound quality is OK and the SFX is good enough. Also VIAFMTSR.COM eats a lot of memory and some of the motherboard ROMs (i guess the bootmanager for LAN) eats a good chunk of upper memory leaving like only 45kb available. With some QEMM magic the best I can get is 584K of free conventional memory with Keyb , Display.sys, Ansi.sys , Doskey , CTMouse, VIAFMTSR and VIAUDIO, with files=30, buffers=10, Lastdrive=L (EMS enabled) and 607K with NOEMS. No smartdrive.
This little PC boots into DOS at warp speed, I'm pleased. I have only tried DOOM 1 and WOLF3d so far.
