MDK A3D patch!?
Reply 20 of 34, by idddqd
Hi guys!
I have a A3D patch mdka3d3d.zip (Direct3D version). You can download it at the following link:
http://www110.zippyshare.com/v/xVTJi1u7/file.html
Unfortunately, I was not able to recover mdka3d95.zip file (Win 95 version)...
Best regards
Reply 21 of 34, by F2bnp
Woah, this came out of the blue! Where'd you get this idddqd? No matter, this is beyond awesome, I've been looking for this for years now, looking for my copy of MDK as I'm typing this and will run to the nearest retro PC with Vortex 2 🤣 .
Thank you so much for sharing!
Reply 23 of 34, by vetz
Daamn! Just when you thought it was lost forever!!
Thank you so much! 😁 I hope it's okey I attach the file here, incase Zippyshare goes down and to have another mirror
    mdka3d3d.zip
    322.28 KiB
    819 downloads
Reply 25 of 34, by F2bnp
Tried to power up a particular PC with a Vortex 2 installed and was greeted with a totally dead power supply, so I haven't yet managed to fool around with this A3D patch 😵 . I believe it is fairly easy to reverse engineer the exe to include the specific patch to the vanilla Windows 95 executable if we can't get the real deal.
Anybody tried it yet? Impressions?
Reply 26 of 34, by Stiletto
Well I can tell you that the No-CD string referred to in a post on page 1 exists. 😉
[EDIT] Thought it was at different offset but actually my hexeditor has offsets in hex whereas the patch was using a decimal offset.😀
Otherwise I don't own a Vortex 2 right now, so cannot try... 🙁
do the Fandango!" - Queen
Stiletto
Reply 27 of 34, by idddqd
Here is No-CD version:
http://www109.zippyshare.com/v/QbDX7JF3/file.html
Edit mdka3d3d.exe - A3D sound patch off net
Search for: E8 72 75 07 00 at offset 13,865
Change to : http://www.abandonware-forums.org/archive/ind … hp/t-27965.html
Reply 30 of 34, by Stiletto
From back in the day:
http://members.optusnet.com.au/kirben/3dsoftware.html
"Aureal A3D patch no longer available"
... BOOM. One down, one to go! 😁
[EDIT] Bumped up the appropriate gog.com thread and also told FalconFly and mr. 3dgw.com. 😀
Stiletto
Reply 32 of 34, by F2bnp
Finally got the chance to try this out. Had a blast playing through the first two levels, but I can't say the patch does much of a difference. I played using my headphones to make sure I caught any 3D effects going on. I could hear some of the doors opening get a 3D effect and maybe some enemy blaster shots but that was about it to be honest.
The vanilla game does some 3D sound positioning for the enemies, I fired up the software version right after that and could still hear enemies behind me or at an angle. Most of the soundscape being 11KHz doesn't really help.
Still, I can't believe someone found this, I thought it was pretty much a lost cause.
leileilol wrote:
Was there ever a MDK A3D PowerVR patch? 🤣
