Reply 20 of 23, by Arctic
- Oldbie
I'd be interested to see if this was stable under load and what the core temperature reached to confirm.
wrote:Does your card still work?
Does anyone have long term experience with this mod?
Yeah, the card still works. It's in storage at the moment. I did use it for a few months without issues. I took precautions with extra air flow and cooling inside the case, even though the card seems over engineered with its own single-slot cooler.
This is the GT model, an underclocked Ultra, and it easily overclocked to Ultra speeds and beyond.
@Kahenraz:
It is stable under load. The only time it wasn't was when using a PIII Tualatin at 150MHz FSB - I ran 3DMark 2001 with infinite loop, and it would lock-up after an hour or so. I don't remember its temperatures, but when I did check, they were more than reasonable. Otherwise, alarm bells would've rang due to me being paranoid about these things.
Too bad I didn't buy the card...
I guess I will just stick with the Geforce 4 Ti 4600 then...
