Reply 25701 of 27574, by ChrisK
Activated Win XP through telephone. My first time ever. EVER.
Didn't think that phone number the setup showed would still be in service. It was.
All in all a really straight forward process. Most effort was to pass that trillions of numbers through the phone.
But it worked without issue.
Still amazed.
All I actually wanted to do was to function test this home made LAN adapter for an old mainboard which has onboard LAN but requires some breakout board with the actual socket (which was of course missing when I got it). Those breakout boards are still around if you know what you are searching for, but 10 bucks are 10 bucks and all the parts that were needed I had lying around.
It may not be 100% original and period correct but i works and since I'm not really going to use this very much this DIY cable will be fine. Will make it a bit more user friendly when time comes, though.
    1.2 MiB
Reply 25702 of 27574, by BitWrangler
Even with quite "hard" water, I don't really think you see residues left unless you lie the thing flat with large blobs/puddles on top and it evaporates away totally rather than draining. So shaking the worst off, leaving it where it can drain, and making sure no sockets are "full" is probably fine most of the time. You're still gonna have edge cases, but you can follow up with IPA contact cleaning if you're nervous.
ChrisK wrote on 2023-10-26, 06:54:
I saw a pic of an adapter required for one of my boards with onboard LAN and while it wasn't good enough to tell exact components, there were a lot of components on the PCB as well as the socket. So I was put off the idea of simple IDC header to RJ socket. But I was not thinking at the time about those RJ sockets that have "magnetics" incorporated, all the chokes, filters, inductor things, which may be what is needed. So this socket looks like a bit of a chunkier one, did you pick one with the "magnetics" included or is it a happy coincidence? I am interested to hear how it works. One thing I would be nervous about for vintage setups would be if using a period "hub" rather than a switch as anything putting the signals out of whack slightly might cause the whole segment problems.
Reply 25703 of 27574, by Shponglefan
Continued to 'downgrade' my 1995 Pentium 133 by installing a motherboard with a 430FX (Triton) chipset.
Previously I had installed a Gigabyte GA-586ATV which uses the 430VX (Triton II) chipset. The replacement motherboard is the Gigabyte GA-586ATE/P.
1.1 MiB
1.1 MiB
Both motherboards feature turbo switch functionality which is nice. They do seem to throttle to different speeds though. The GA-586ATV throttles to the equivalent of a Pentium 100, whereas the GA-586ATE/P slows down to approximately a Pentium 75. With the turbo functionality and SETMUL to disable L1 cache I can slow the latter system to the equivalent of a 486 DX-33 or 386 DX-40.
The GA-586ATE/P does have really irritatingly place IDE connectors. Fortunately I was able to wrangle both the cables and the full length AWE32 card and make everything fit.
It also gives me a 4th ISA slot should I decide to install something else.
828.17 KiB
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 25704 of 27574, by ubiq
Shponglefan wrote on 2023-10-26, 16:20:
Continued to 'downgrade' my 1995 Pentium 133 by installing a motherboard with a 430FX (Triton) chipset. […]
Haha, fantastic cable routing on that, love it!
I added an IDE to SD card adapter to my "Mini ITX" Pentium 90:
1.28 MiB
Reply 25705 of 27574, by kingcake
What should I use to dissolve this plastic/wax-like TIM. It's hard as a rock. Had to use the heat gun to get the heatsink off in the first place.
Tried 99% Alcohol, GooGone, neither made a dent.
1.49 MiB
1007.71 KiB
Reply 25706 of 27574, by gmaverick2k
kingcake wrote on 2023-10-27, 03:48:
What should I use to dissolve this plastic/wax-like TIM. It's hard as a rock. Had to use the heat gun to get the heatsink off in […]
Brake cleaner spray in well ventilated area. Scrape off whilst wet
https://www.eurocarparts.com/p/triple-qx-tqx- … rmula-542779000
https://youtu.be/d3Qmm6Tegb4?si=4_8r0vk8_MSy2cBt
"What's all this racket going on up here, son? You watchin' yer girl cartoons again?"
Reply 25707 of 27574, by Munx
Heat it up with a hair drier. That should soften it up.
My builds!
The Underdog - The budget K6
Reply 25708 of 27574, by ChrisK
BitWrangler wrote on 2023-10-26, 14:04:
Yes indeed it is a socket with all parts integrated. Magnetics, termination resistors and cap, and LEDs.
This is the original breakout board (photo from the net):
100.4 KiB
All components are on top side so the "re-engineering task" wasn't too complex.
Most "chip side" components are placed on the mainboard as I had already found out some time before, leaving just the center tap caps on the breakout board.
The "cable side" components are nothing more than four resistors and the big blue cap. All of them including the magnetics are commonly integrated in the connector nowadays.
So all that was to be done was determining which pin on the mainboard connector was TX+/TX-/RX+/RX- and which ones are for the LEDs and connecting everything in the right order to the LAN connector.
For reference:
The mainboard is an Elitegroup K7SEM with a Realtek RTL 8139C LAN chip. Nothing fancy, that's why I didn't want to invest more than absolutely necessary.
https://theretroweb.com/motherboards/s/ecs-k7sem-v1-x
The connector I've used is a Würth 7499010441.
https://www.we-online.com/components/products … /7499010441.pdf
Reply 25709 of 27574, by BitWrangler
ChrisK wrote on 2023-10-27, 06:40:
Yes indeed it is a socket with all parts integrated. Magnetics, termination resistors and cap, and LEDs. This is the original br […]
For reference:
Thanks very much for the explanation, yes it's also an Elitegroup/PCChips board I had in mind. I may try this for it sometime, when the big project wheel turns and it gets attention.
Reply 25710 of 27574, by PcBytes
Zippo lighter fluid. That's about the only I've seen remove even the toughest Voodoo3 thermal compound, and I am not even the slightest joking.
Reply 25711 of 27574, by Kahenraz
Leave a puddle of Goo Gone on it and scrape at it periodically when a vinyl spudger. I'm very familiar with this paste used on old ATI cards and it is terrible.
My worst experience was actually in a laptop. The paste had turned into some kind of cement and was so hard that I could only chip away at it with a metal screwdriver.
Reply 25712 of 27574, by PcBytes
As I have mentioned, Zippo lighter fluid is the way to go if you need to do it quickly.
There's just something in it that dissolves the toughest of compounds - including the stupid yellow compound found on older ATI/nVidia cards - I have had a Medion FX5600XT with that kind of thermal compound, and a good amount of Zippo fluid got it pretty quickly off with no damages.
I have also used it for stubborn pink compound used on most Intel northbridge heatsinks - a few of the boards I did this on were ABIT IS7-E, Intel Desktop Board D865GLC, and the latest would be a P4Dual-915GL.
Reply 25713 of 27574, by BitWrangler
Coleman stove fuel might be about the same chemically if you haven't got zippo fluid around. Though I have heard that what petrochemicals will work as solvents for, so will vegetable oils, you just have to leave them sit longer.
Reply 25714 of 27574, by kingcake
PcBytes wrote on 2023-10-27, 14:49:
Just tried lighter fluid. Didn't make a dent. Even let it sit on the die for a while then gently scraped at it with a plastic razor blade. No go.
Reply 25715 of 27574, by kingcake
Kahenraz wrote on 2023-10-27, 17:22:
In my post I said I tried Goo Gone. Let it sit. Didn't soften it at all.
Reply 25716 of 27574, by Shponglefan
Acetone? Or maybe oven cleaner?
Alternative would be try chipping it off with a metal razor blade.
Reply 25718 of 27574, by gmaverick2k
Guy in the video mentions avoid acetone, methanol as it will cut through the silk screen. My guess is smaller chain alcohols/ketone will do that(?)
