Reply 40 of 66, by filipetolhuizen
- Oldbie
wrote:doVoodoo definitely solved my problems with guru mediations. desynchronization is less frequent if you have during game stable f […]
desynchronization is less frequent if you have during game stable fps and no over 60fps to dont make crash.(frame-limiters make desync.sound)
On the stronger computers best way is play on one core with dgvoodoo, then you have solved all problems and you can play normal without errors and desync.sound.
Weaker computers have problem because playing on one core make drastic drop in fps, dgvoodoo like too eat some fps and we have problem with liquidity
It helped me too with the speed issues, but sound wrappers also cause guru meditations here.
