I thought I was asking a very simple question.
Jorpho wrote:Jorpho wrote:It's like I just said: What folder are you mounting when you run Windows 3.1 in DOSBox, and where did you unzip the S3 drivers?
Y'know, if you would just answer these questions your problems could probably be solved very quickly. You've already gotten Windows 3.1 running (without 256 color mode); that's the tricky part.
You do have Windows 3.1 running in DOSBox, right? You mentioned as much before.
Also,
TG19942015 wrote:because I didn't find the boot disk used in the video and there are no links in the description. So I'm using another boot disk but Dosbox seems to quit work then.
If you start following a guide and then start changing things randomly, you cannot expect the guide to work. This applies to many things in life in general.
