Reply 420 of 3174, by shock__
Finally got the SIMM72 slot attached (except for the VCC pins)
http://i.imgur.com/oRtAm9f.png
Can anyone of you measure the height of a few ordinary SIMM sticks for me (metric pls)? Eagle just has footprints for tiny ones. I've guess-timated something, but want to make sure everything works out.
(I'm awesome and just have a single 4MB SIMM72 stick here - unless I took my testbox apart)
Current Project: new GUS PnP compatible soundcard
[Z?]
Reply 421 of 3174, by dogchainx
shock__ wrote:
Finally got the SIMM72 slot attached (except for the VCC pins) http://i.imgur.com/oRtAm9f.png […]
72-PIN SIMMS are a little over 2.5cm in height (like 2.51 ). I just measured a few of them, and all of them are extremely close 2.5cm (how wide is the width of the mark??? 🤣)
386DX-40MHz-8MB-540MB+428MB+Speedstar64@2MB+SoundBlaster Pro+MT-32/MKII
486DX2-66Mhz-16MB-4.3GB+SpeedStar64 VLB DRAM 2MB+AWE32/SB16+SCB-55
MY BLOG RETRO PC BLOG: https://bitbyted.wordpress.com/
Reply 424 of 3174, by shock__
Marmes wrote:
Why use soj memory? I do agree with rom memory...
It's just there in case anyone wants to use that for some reason instead of the SIMM72 so there's no major part of the PCB unused.
If I run out of space or someone has another idea what to do within that area - I'd have no problem to remove one or both SOJ footprints.
[Z?]
Reply 425 of 3174, by hard1k
Yesterday I bought a REVEAL WAVExtreme 32 card off eBay, I could donate it for the project if you see any specific use for it 😀
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
Reply 426 of 3174, by shock__
I have one of those here 😀 Sadly non-working but it helped me reverse the DIP footprint for the rom and the ROM itself is on the way to Marmes for getting read out.
[Z?]
Reply 427 of 3174, by keropi
the lasted schematic looks really really awesome!!!
Reply 428 of 3174, by hard1k
Yeah, I really like it too! SOJes, SIMM72 and bank assigning jumpers are great!
AWE64 Legacy
Reply 429 of 3174, by shock__
I think I will take a few days off from the project - really getting tired of the signal juggling for now (moving components so the SIMM bar fits). Which is okay I guess - so I can resume once the ROMs have been dumped.
[Z?]
Reply 430 of 3174, by shock__
Just a small heads up - the SIMM72 socket is fully attached now and the PnP-ROM moved so it doesn't interfere with SIMM sticks (I'll add options for adding straight, 45° and 90° SIMM72 slots).
If anyone knows any software requiring a 1MB GUS Classic (!) please give me a heads up, as i'd like to test if those work as well (there's word around the InterWave just supports 512kb in UltraSound mode - which I couldn't verify yet).
I'll write another blog post summing up the current status later on today.
[Z?]
Reply 431 of 3174, by dogchainx
Awesome work Shock! Thanks for the updates. I've never had a GUS, so I'm not familiar with any games requiring the 1MB GUS classic.
Keep up the great work! 😎
Reply 432 of 3174, by shock__
From what I've seen an InterWave card with 4 banks of at least 256kb RAM seem to be compatible with the classic Ultrasound cards @ 1MB.
Tested that with a random demo requiring 1MB and UtraDRV (GUS sample RAM as a RAM-Disk under DOS) yesterday - still want to make sure that works.
On another note - I might be able to get a classic GUS for testing with quite a history, Abyss^FC is giving his original 1993 GUS away, which ran Second Reality before it was officially released 😀
[Z?]
Reply 433 of 3174, by wbc
Heh, good, I saw this thread on pouet. 😀
--wbcbz7
Reply 434 of 3174, by shock__
Picked up the AM78C201AKC chips - just had to pay the usual 19% sales taxes for goods coming from outside the EU, no customs.
http://i.imgur.com/hLTqYis.jpg
[Z?]
Reply 435 of 3174, by keropi
Excellent! At least there were no customs fees involved, it's something! 😀
Reply 436 of 3174, by QBiN
That would be a pretty cool collector piece of computer history.
Reply 438 of 3174, by buyerninety
A suggestion on the current http://i.imgur.com/oRtAm9f.png
Reduce the unused area, by making a cutout in the final pcb,
the purpose of which is to reduce any chance that the pcb will
intrude onto or close to motherboard components (capacitor tops,
insertable bios ROM, coils, etc.). {So reduces likelihood of;
"Gee - I would have preferred to place the card in ISA slot N,
but there was a tall component blocking the overhang there so
I had to put the card in a less desired slot..." 😢 }.
A cutout will also act to usefully provide additional separation
of the pcb planes from any RF emitted by various motherboard
components. (Orange or grey line shows cutout area, below left;)
159.66 KiB
Like grey line straight cutout, or orange line curved cut to
give easier 'fingertip grip' when removing pcb from slot.
Note; cut begins outwards, slightly away from corner where
slot extension joins pcb body, so as not to weaken the right
angle location where the slot extension joins the pcb body.
If the fabrication company cannot action the cutout without
undesireably adding to the price, perhaps a line of through
holes nearly touching each other, would serve as a last ditch
option allowing someone to gently connect (saw through) the
holes, so as to clear any obstacle, if it turns out that your
preferred motherboard, (perhaps with only one ISA slot) won't
allow fitment of the length of the pcb... .
Another suggestion; include a slight vertical separation between
each horizontal set of jumpers for each of banks 0, 1, 2 and 3. (JP7)
The reason is so that each horizontal jumper will still be able to be set
'as desired' for each individual bank - BUT with the vertical separation
of each set of bank jumpers, you ensure that there is no possibility
of a user accidently placing a jumper joiner which joins (vertically) pins
of any bank - this could conceivably cause damage to the ram (say, for
instance, that bank 0 and 1 highside potential pins {each leftmost pin? of
bank 0 and 1} were inappropriately joined by a jumper placed accidently
vertically across those two pins).
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
ROLL ON THE 'GUSONAISSANCE' !!
Reply 439 of 3174, by shock__
The suggestion with the bank jumpers is good and will most likely be included, not that misplacing them would matter in most cases (I guess tying the !BKSEL* lines on the InterWave together might, the others certainly wouldn't).
About the cut-out, yes the card being "overlength" (at least when taking the ISA socket as a reference) might be an issue on some mainboards BUT that's the mainboards fault - not mine. ISA spec is ~32cm in length with my current design being a bit less than 2/3 of that. If that were such an issue I could see people dumping their GUS classic/PnP cards (which are actually longer than the ARGUS) along with their LAPC-I cards 😀 The empty space will certainly be more or less usefully populated.
[Z?]
