Reply 3660 of 4609, by Disruptor
H3nrik V! wrote on 2022-04-07, 11:00:
The Pentium II did have 512 KiB L2 cache, not 256. Never the less, you are absolutely right that in a lot of applications, the Celeron "450A" was faster than the PII
You're right. All the Klamath, Deschutes Pentium II and Katmai Pentium III have 512 kB half speed L2 cache. They need Slot 1 and there are no Socket 370 versions avaiable.
I've messed it up with the Coppermine Pentium III's which had 256 kB L2 cache, on die and full speed. They do not need Slot 1 and they exist in both Socket 370 and Slot 1 variants.
I fixed it.
Reply 3661 of 4609, by Kahenraz
There's nothing wrong with Celerons. Newer Celerons are often faster than older Pentiums, for example. There are also plenty of good OEM cards from this era.
The right choice of components really comes down to what software you want to run and what your hardware will support. Not all early Intel chipsets can run Coppermine anyways, so there's no point in buying as processor purely based on what you want.
Reply 3662 of 4609, by Disruptor
Disruptor wrote on 2022-04-06, 22:14:
I just was digging in a box and found a Celeron SL2Y2. It is a Covington 300 with the newer A1 stepping.
Is this any good for? Can it be paired with a S3 Virge on a Legend QDI P6I440EX/ATX EXCELLENT 1?
Well, it's not worth hunting for a Covington. You just can emulate its behavior with a Klamath/Deschutes Pentium II, a Mendocino Celeron or a Katmai Pentium III. Run it at 66 MHz FSB and disable L2 cache.
Reply 3663 of 4609, by Miphee
Another spring, another municipal waste collection day. Wife was NOT happy but she helped me anyway. That's true love.
    1.79 MiB
Reply 3665 of 4609, by H3nrik V!
Miphee wrote on 2022-04-11, 16:16:
As in driving around the streets and picking up stuff from the curb? But yeah, she's a keeper
Reply 3667 of 4609, by maestro
Here's some free stuff that was destined for the dumpster.
439 KiB
1. Maxware 8086 (NEC V20)
2. WDC Paradise '88 VGA 16-bit (8-bit friendly)
Does anyone know if I can use my AT power supply with this board? There's 12 pins and plug looks similar but more primative.
Reply 3668 of 4609, by Cuttoon
maestro wrote on 2022-04-12, 02:08:
Someone here will.
If it's indeed an AT connector, it called a Molex 90331:
https://pinouts.ru/Power/MotherboardPower_pinout.shtml
If the middle 4 pins all lead to ground, I'd say, pretty good chances.
But that thing looks really fossil, even to an old geezer like me.
I like jumpers.
Reply 3669 of 4609, by maestro
I'll give it a try it, one day, and wear glasses in case a tantralum blows up in my face. It's old but hopefully I can use this to verify if my PSU is still working, I also have a 486 that won't fully POST and I'm not sure if it's the 486 or PSU.
Reply 3670 of 4609, by cyclone3d
Here's some free stuff that was destined for the dumpster. […]
The NEC V20 is the replacement for the 8088, while the v30 is the replacement for the 8086.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 3672 of 4609, by MMaximus
I had the same question a while ago. I'm 99% sure you can safely plug your AT PSU to this connector (provided of course you stick the black wires next to one another, the same way you would with an AT board)
Hard Disk Sounds
Reply 3673 of 4609, by EvieSigma
Saved this HP NetServer E50 from being scrapped today, feels good.
244.5 KiB
Reply 3674 of 4609, by chrismeyer6
EvieSigma wrote on 2022-04-12, 23:11:
Nice job saving that beautiful machine.
Reply 3677 of 4609, by EvieSigma
chrismeyer6 wrote on 2022-04-12, 23:23:
Wow that's had quite the long deployment life. Once you get it all cleaned up and looking good it'll be a fun system to tinker and play with.
I think this is is one of those classic "nobody remembered it was there and so nobody turned it off" stories, which are always a good story.
Reply 3678 of 4609, by chrismeyer6
EvieSigma wrote on 2022-04-12, 23:36:
I've seen that happen a few times in the past. Always makes for a good story.
Reply 3679 of 4609, by maestro
MMaximus wrote on 2022-04-12, 20:57:
Thanks for the confirmation. I'm pretty sure it will too, I'll post an image of it running if it does end up working.
