Reply 3680 of 4609, by Miphee
H3nrik V! wrote on 2022-04-11, 19:32:
As in driving around the streets and picking up stuff from the curb? But yeah, she's a keeper
She was the one who told me that the local school organized an e-waste collection day so we went there and picked up everything computer related. We had to make 2 turns to get them all. They usually don't advertise these events to keep people like me away but my wife knows the staff so they let me collect whatever I wanted.
gerry wrote on 2022-04-12, 09:13:
all of that in one swoop? fantastic!!
Too bad it's only twice a year! 😁
Reply 3682 of 4609, by TechieDude
Kahenraz wrote on 2022-04-13, 10:52:
When she told you about the e-waste collection, that was actually a test. You failed.
Partners that 'test' you like that should be thrown to the curb. They're the real waste.
Reply 3683 of 4609, by holdencars11
Random curb pile eMac. Heavy beast to carry home and no carry handle like a G3!
Dusty internally but less of a pain to take apart to clean the CRT board than a G3 iMac..
The acrylic shell polished quite nicely.
    1.37 MiB
    1018.52 KiB
    1.36 MiB
    1.64 MiB
Ryzen5 1600AF/ASRock B450Mac/16Gb/HD7750
i7 2600K/P67A-C43/16GB/GTX560
i7 960/MSI X58 Pro/8GB/8800GTS
Athlon II x4 620/GA-M56-S3/8GB/8800GTS
Duron 1300/A7S333/512MB/MX440
6x86MX PR200/PC Chips M571/64MB/ET6000
NEC PowerMate1 268 10MHz
And another 40 rigs.
Reply 3684 of 4609, by Cuttoon
holdencars11 wrote on 2022-04-14, 11:49:
Lol, that's how I always imagined Steve Jobs to look on the inside.
Had to work on one of those once and the HDD noise drove me nuts.
I might have left face down it on the curb.
(no, not really)
So there was Halo for the Mac, only two years later. Figure that!
I like jumpers.
Reply 3685 of 4609, by holdencars11
Cuttoon wrote on 2022-04-14, 12:02:
(no, not really)
hahh i don't think I've ever bought anything new from Apple... all came from the trash
Was considering leaving it, just couldn't...
Reply 3686 of 4609, by H3nrik V!
Miphee wrote on 2022-04-13, 09:52:
She was the one who told me that the local school organized an e-waste collection day so we went there and picked up everything […]
Nice! I want that kind of events too 🤣
Reply 3687 of 4609, by TrashPanda
Found a Zida TX100-3D board today, never seen an AT board this small, not sure what Ill do with it if it passes POST and testing but I do have a IBM 6x86 PR266 2.9v sitting in my collection that should work on this board if Ultimate Retro is correct.
Don't know if I have a case that wont look silly with such a tiny board in it though ..its down right adorable if you can say such a thing about PC hardware.
Never realised they made SFF sized AT boards, its certainly something I want to keep, fingers crossed that it works.
Reply 3688 of 4609, by mkarcher
cyclone3d wrote on 2022-04-12, 04:37:
maestro wrote on 2022-04-12, 02:08:
1. Maxware 8086 (NEC V20)
The NEC V20 is the replacement for the 8088, while the v30 is the replacement for the 8086.
V20 is likely correct, and 8086 wrong. The board looks like the standard mid-80s XT clone board, and the XT is designed around the 8-bit data bus of the 8088. As there is no crystal oscillator box, but just the 14.318 MHz crystal next to the ISA slots, I'd expect that the board is 4.77MHz only, and doesn't feature a "turbo mode".
To reduce the risk of fireworks and spontaneous combustion of capacitors on the board, I suggest to test the power rails for short circiuits before powering up the board. The tantalum caps on that kind of hardware tend to fail short and burn with a nasty smell if the power supply doesn't enter short-circuit protection mode quick enough. Even if they test good unpowered, they might break down under voltage. Apart from the nasty smell, failing tantalums rarely cause collateral damage, so don't be afraid to try to power up the board. If capacitors burn up, remove them and plan to replace them.
Reply 3689 of 4609, by Cuttoon
appiah4 wrote on 2022-03-22, 11:09:
InWin A500 is the best ATX case ever made. I wish I had one 🤣
This would be your chance:
https://www.ebay.de/itm/154951173566
Price of 59 € is not nothing, but the seller seems like one who'll be open to offers.
@mod, I have no affiliation with that sale, but if I'm not supposed to post this here, please let me know!
I like jumpers.
Reply 3691 of 4609, by Cuttoon
MMaximus wrote on 2022-04-16, 15:10:
I see the InWin A500 often mentioned positively on this forum - what's so special about it?
mainly the motherboard tray and the truly compact height - afforded by putting the PSU not horizontally up top but in line with the mobo over the ATX bracket and (usually) CPU area.
Overall build quality is top notch as well.
I like jumpers.
Reply 3692 of 4609, by weedeewee
another week, another haul... help. 😐
a bit higher res images can be found here : https://imgur.com/a/8d8nfGt
not photographed...
microsoft natural keyboard, one with the arrow keys in an inverted T shape, not the horrible plus shape.
Sinclair QL
powerpc mac mini
2 normal floppy drives, new in box.
1 ide zip 250
4GB quantum bigfoot
USrobotics 56k USB modem
and a pinnacle systems Studio MP10
edit: I forgot... a Tandy 1100FD
    138.41 KiB
    memories
    242.25 KiB
    snd, gpu, usb-fdd, wifi, tv capture, 5250 card
    281.07 KiB
    lan
    208.91 KiB
    scsi stuff - 29160 card was not in the box
Do not ask Why !
Reply 3693 of 4609, by MMaximus
Cuttoon wrote on 2022-04-16, 15:16:
Thanks for the info. I wonder why more manufacturers didn't use this PSU placement. Maybe not the best for thermals I guess
Hard Disk Sounds
Reply 3694 of 4609, by Tetrium
MMaximus wrote on 2022-04-17, 08:31:
Probably because it was bad for airflow using socketed CPUs along with a PSU that pushed air out of the case. or at least this is what would seem logical to me.
My retro rigs (old topic)
Report spammers here!
Reply 3695 of 4609, by maestro
mkarcher wrote on 2022-04-15, 08:31:
Indeed, this is a V20 and 8088. I saw 86 stamped on the chip and thought it was an 8086. Thanks for clearing that up and for the useful information on the tantalums, it's greatly appreciated as is anything I can learn about hands-on repair.
82.11 KiB
Both the XT and the Paradise '88 are working. I'm not sure what EA means but when I press F1 the system responds by shreiking continuously from the PC speaker. I'll leave it at that for now, the important point is that the PSU is working and so the problem with my 486 is on the motherboard-side of things.
Reply 3696 of 4609, by Cuttoon
maestro wrote on 2022-04-18, 17:34:
Indeed, this is a V20 and 8088. I saw 86 stamped on the chip and thought it was an 8086. Thanks for clearing that up and for the […]
Damn, it's an intelligent computer? Where did you find that thing????
I like jumpers.
Reply 3697 of 4609, by mkarcher
(Screenshot saying "EA keyboard bad, press F1 to continue" removed)
The "EA" probably is a hexadecimal error code. Are you aware that XT and AT computers use the same keyboard plug, but the communication protocol is incompatible? Your issue might be caused by connecting an AT keyboard to an XT computer. Many early AT keyboards have a switch reachaeble from the bottom side labelled "XT/AT" or "8088/286". You can use that switch to select the protocol. Some keyboards also can auto-sense whether the connected computer requires the XT or the AT protocol, so a keyboard without that switch might possibly work, too.
Reply 3698 of 4609, by maestro
Cuttoon wrote on 2022-04-18, 17:40:
18.74 KiB
Here's a picture of the case these were in. My coworker had already pillaged all the Voodoo cards from the other boxes so I just grabbed what was left.
mkarcher wrote on 2022-04-18, 17:47:
Yes, it looks like a hexadecimal code. I'm using a PS/2 keyboard with an adapter, not ideal since they weren't 100% backwards compatible but unfortunately that's all I have to test with. I remember that switch now that you mention it. 😀
Reply 3699 of 4609, by mkarcher
maestro wrote on 2022-04-18, 18:21:
To put things straight: PS/2 keyboards and AT keyboards with a DIN connector are 100% compatible. You can use the cheap passive cable adapter without any restrictions. On the other hand, AT and XT keyboards are 0% compatible. XT keyboards use a unidirectional protocol without parity, and AT keyboards use a bidirectional keyboard with parity and the possibility to resend bytes if the receiver encounters a parity error.
Your problem is only that much related to the keyboard having a PS/2 plug as keyboards with PS/2 plugs are less likely to implement the XT protocol than keyboards with DIN plugs. An AT keyboard with DIN plug without XT protocol support would work just as bad as the PS/2 keyboard you are currently using.
