I see that a portion of people don't like the breakout combo... I personally don't get why as it's basically the same deal as the old-style DB9 cable (db9 goes to card, female midi plugs go to modules, you DON'T need to mess with the 3.5mm jacks at all, connect them once and don't touch them again if you don't like)
- BUT -
to each their own and I really want people to be happy with their cards so I will start offering an option to anyone past this point:
- sacrifice the whole breakout+midi cables to get a cable like the OLD one :
I will actually cut the 3.5mm connectors from the machine-made cables and I will solder them to the db9 connector and put it inside a shell : you won't get the breakout pcb and you'll have to chose from having eirher 2xOUT or 1xOUT + 1xIN ports.
How does that sound?
