First post, by Malvineous
Hi all,
I got a collection of "as-is" ISA cards off eBay recently, and one of them is an 8-bit ISA VGA card (an Osborne branded card with a Cirrus GD520A chip.) I'd like to keep this for use in an XT, however it looks like the video memory has gone bad:
The display is fine with another card, so it's definitely a fault with this particular card.
How would you go about repairing this? I'd like to avoid desoldering each memory chip unless I have to, so can these chips be tested in-circuit? Can you still buy new pin-compatible replacements for them?
The memory chips on the card all say "8902" and "VT4464P10". My 286 motherboard manual says it can take 4464 DRAM chips, and looking around it seems like this is a fairly standard type of memory, but perhaps not one that is manufactured any more. Is this right?
It looks like the 4464 is a one-bit memory chip, which would explain why there are eight of them on this card. That doesn't really explain why the text is OK and only the attributes are corrupted though, as those are stored in alternating bytes, so you'd think all chips would be used for both text and attributes if they were connected in parallel.
Maybe there's a way to disable one chip at a time (perhaps by grounding the data output line) to see whether the corruption disappears when one or more of the chips aren't returning data?
Any other suggestions/ideas?
Reply 1 of 4, by wbc
I think that one of 4464 memory chips is failed. Find it out and replace with working one (any 4 x 65536 bit chip should work)
Also you can try to swap two chips on card and if you notice some changes in picture you have probably found a defective module.
No, it is 4 bits x 65536 memory chip, so 8 chips will result in 256 kb of VGA memory with 32 bit bus width.
--wbcbz7
Reply 2 of 4, by alexanrs
It looks like the chips that hold the highest four bits of each 16-bit word (so two chips for a 32-bit bus or a single one if the video controller runs on a 16-bit memory bus with two banks). It might be better if you desolder the chip and add sockets to the board.
Also, I'd try diagnosing it on a high-res graphical mode that makes use of the full memory range of the card. If only half of the screen gets corruption on every odd pixel then an educated guess would be that there are two memory banks and only a single chip is busted, and swapping the banks would allow you to use VGA modes just fine (unchained mode apps can still face corruption)
Reply 3 of 4, by Malvineous
Thanks for the suggestions! The chips are soldered on, so swapping them isn't straightforward unfortunately. Replacing them with sockets might be the way to go.
Since I've been investigating, the characters have now become corrupted as well, and the system no longer boots - no memory check, so best guess is the VGA BIOS is displaying an error message and halting (it looks like a box has been drawn on the screen but I can't make out what letters are inside the box.
If I'm going to have to desolder all the chips, would it be possible to replace them all with a single modern memory chip? Or maybe two if there are two banks? I'm guessing I can just hook up the address and data lines to match, and providing the replacement chip is 5V tolerant and fast enough, it should work?
You might be onto something with the two banks - the chips are labelled U9 U10 U11 U12 U1 U2 U3 U4 in that order, and it looks like there's a break in the address lines between the two groups of four chips, so it may well be in two banks of 16-bits (which would again make sense if only the attribute bytes were originally affected, as they appear in the same position every 16 bits.)
Reply 4 of 4, by alexanrs
If you find a modern 5V chip that has simillar characteristics, then it might just work. If you have a programmer like a TL866, I think it can also work as a DRAM tester for 4464 ICs - I used my TL866 to isolate a faulty cache chip a while ago. If you do desolder and put sockets, try swapping the banks - maybe that will be enough to get it to boot.
