First post, by Tetrium
Hi all.
I'm basically trying to split up a discussion from the "Bought these (new) hardware today"-thread to over here as I think there is a lot to talk about when it comes to both the usual and the really strange memory modules we see.
Original reply: Re: Bought these (retro) hardware today
Personally I think the modules RacoonRider scanned are parity, but I'm not sure.
Because I was having dinner and can't eat while digging through boxes of memory modules, I decided to dig through my collection of old photos instead and found a few other odd memory modules.
One pic is from 10 memory modules (5 pairs) of 64MB SIMM modules. These do post in a standard s7 board, but they were very unstable which is because of the large number of chips I think (many motherboard manuals of the day actually mention a maximum of 24 chips iirc). Both sides are "chipped" on all of these modules.
Even though I had no use for them, I kept them because I think they looked kinda cool 😁
The other pic is of 4x 16MB(?) SIMMs which I took from some server that was too heavy to transport, so I stripped all the components out and brought those home.
So what are your strange or otherwise interesting memory modules? Pics or it didn't happen! 😁
    2.31 MiB
    2.27 MiB
My retro rigs (old topic)
Report spammers here!
Reply 1 of 40, by PCBONEZ
Yes. With parity.
Reply 2 of 40, by PCBONEZ
I can't read the numbers off the square chips.
IBM occasionally used proprietary RAM.
I ran into some 72-pin years ago that looked standard but the key-cut was too shallow to allow insertion into a standard slot.
Reply 3 of 40, by Snayperskaya
I have two 64MB @ 100MHz, double height, SDRAM modules around. Pretty uncommon here.
The "weidest" I've seen was some SIPP modules from a colleague's stash of old stuff (funny enough, since he isn't even into hardware and PC in general). I didn't caught it back then, but I wonder how those pins fared against corrosion and mechanical insertions. They seemed to be a bit on the fragile side.
Reply 4 of 40, by Tetrium
I should have some of those double-height DIMMs also somewhere.
Once I get through the rest of my boxes of graphics cards, I'll go through the boxes of memory modules and take pics of anything interesting I find.
Should have some EDO DIMM which has the notches positioned differently, so they don't fit ordinary SDRAM slots and I should also have a pair of very old 30p SIMMs with "chips" which look more like metallic dice or something which I stumbled upon recently when looking for other stuff (IBM modules I think).
PCBONEZ wrote:
I can't read the numbers off the square chips. […]
I'll write all text to a new post as I haven't a good enough camera right now and my scanner is dug in somewhere very deep in some obscure part of the house 🤣.
I should also have some SIMMs which at first glance look like regular 72p SIMMs, but they had a slightly different number of pins actually and their physical size was very slightly different I think.
Reply 5 of 40, by PCBONEZ
Tetrium wrote:
Should have some EDO DIMM which has the notches positioned differently, so they don't fit ordinary SDRAM slots.
This is to separate 5v from 3.3v DIMMs and buffered from unbuffered.
40.85 KiB
Reply 6 of 40, by CelGen
IBM and their SLT stuff was wild.
Edited: My MicroVAX 4 is even more absurd
That is an absolutely insane amount of M511000 ZIP chips.
Reply 7 of 40, by Kamerat
What's the capacity? 😀
YouTube channel
Reply 9 of 40, by CelGen
I believe it was about 8mb, plus an extra bank for parity.
Reply 10 of 40, by gdjacobs
Ah, MicroVAX. Don't stand near it if you have a pacemaker or braces.
Have you got a version of VMS running on it, or does it run UNIX?
Reply 11 of 40, by PCBONEZ
I wish I could remember the name of it so I could go find a pic.
The weirdest RAM I remember was for a PC only sold in Japan that was already 'retro' in 2000 when I saw it.
The modules were small rectangular PCBs approximately the size of a 2.5" drive.
To add more RAM the modules stacked directly on top of each other in the fashion of a PC/104 stack.
https://www.google.com/search?q=PC/104+stack
Reply 12 of 40, by 386_junkie
For Compaq's Systempro... and some older Deskpro's.
Reply 13 of 40, by CelGen
VMS obviously. Unix is for the other RISC dweebs. 😜
Reply 16 of 40, by Tetrium
Finally got around to checking these strange memory modules I was referring to earlier.
I don't have a working camera, so I decided to google the part number and the 68p SIMMs apparently are some kind of 256KB Apple video memory modules.
Some pics can be viewed here:
http://www.ebay.com/itm/Apple-Macintosh-256K- … 6ZZnTNdEZQt8zUQ
http://www.memoryten.com/p/004687.htm
I'm still checking for the rest, still haven't found those ice cube or sugar cube memory modules but I'll keep looking 😀
edit:
CelGen wrote:
IBM and their SLT stuff was wild. […]
They looked exactly like the cubes on this pic, but they had a different number of chips and the row wasn't interrupted (no 'missing' cubes).
Reply 18 of 40, by PCBONEZ
Nahkri wrote:
Can somebody tell me,what r those switches on the right side,for?
They put those there so people will ask what they are for. 🤣
On those modules it should be easy enough to look-up the pinouts trace the circuit and figure it out.
Reply 19 of 40, by Callahan
PCBONEZ wrote:
This is to separate 5v from 3.3v DIMMs and buffered from unbuffered. . […]
Ain't right; proof:
How can it be, some modules both: buffered and unbuffered, so where are buffer chips? Buffering is keyed??? 😲
Look at this, from left:
3,3V sdram, unbuffered non-ecc
5V Edo buffered ecc (buffer chip)
5V Edo unbuff ecc
3,3V edo unbuff ecc
Last, first from the right; Here's the pearl: Universal 5v/3,3V edo unbuff ecc
Full hires, use right click, view image, take a look for nothes.
Cpq: ap550(2x1G/256k), sp750(2x900/2MB), 5100(2xpII300)
TD-30 2xP166 NT 3.51
HP Vectra XU 6/200 2x PIIOD 512MB FPM Banshee
Super S2DG2@550/2MB SCSI 15k V5 5500
P4T533-C P4 3,06 Ti4600
Dell T700r @P3-700 V3 3500
PR440FX-2x PIIOD Voodoo 4500 PCI r320 CT1920
