The Soundblaster DSP project
Reply 680 of 1053, by S95Sedan
Maelgrum wrote on 2023-10-05, 18:55:
From 4.13 […]
S95Sedan wrote on 2023-10-05, 18:45:
See attached; line 1225 (413) line 1095 (416) […]
Maelgrum wrote on 2023-10-05, 18:35:
Group 4 commands ( 4X)
See attached;
line 1225 (413)
line 1095 (416)
Yeah the code is the same but the routine doesnt jump to the table in 4.16. (hence the X0a60 vs X0260)
Dont know if this is intentional or another error on their part.
From 4.13
convert_samplerate:
mov dptr,#samplerate_table; 08b6 90 08 bb ..;
movc a,@a+dptr ; 08b9 93 .
ret ; 08ba 22 "
samplerate_table: db 15h,16h,16h,16h,16h,16h,16h,16h ; 08bb ........
db 16h,16h,16h,16h,17h,17h,17h,17h ; 08c3 ........
db 17h,17h,17h,17h,17h,17h,18h,18h ; 08cb ........
db 18h,18h,18h,18h,18h,18h,18h,18h ; 08d3 ........
db 19h,19h,19h,19h,19h,19h,19h,19h ; 08db ........
db 1ah,1ah,1ah,1ah,1ah,1ah,1ah,1ah ; 08e3 ........
db 1bh,1bh,1bh,1bh,1bh,1bh,1bh,1bh ; 08eb ........
db 1ch,1ch,1ch,1ch,1ch,1ch,1ch,1dh ; 08f3 ........
db 1dh,1dh,1dh,1dh,1dh,1eh,1eh,1eh ; 08fb ........
db 1eh,1eh,1eh,1fh,1fh,1fh,1fh,1fh ; 0903 ........
db 1fh,20h,20h,20h,20h,20h,21h,21h ; 090b . !!
db 21h,21h,21h,22h,22h,22h,22h,22h ; 0913 !!!"""""
db 23h,23h,23h,23h,24h,24h,24h,24h ; 091b ####$$$$
db 25h,25h,25h,25h,26h,26h,26h,26h ; 0923 %%%%&&&&
db 27h,27h,27h,27h,28h,28h,28h,29h ; 092b ''''((()
db 29h,29h,29h,2ah,2ah,2ah,2bh,2bh ; 0933 )))***++
db 2bh,2ch,2ch,2dh,2dh,2dh,2eh,2eh ; 093b +,,---..
db 2eh,2fh,2fh,30h,30h,30h,31h,31h ; 0943 .//00011
db 32h,32h,33h,33h,34h,34h,35h,35h ; 094b 22334455
db 36h,36h,37h,37h,38h,38h,39h,39h ; 0953 66778899
db 3ah,3bh,3bh,3ch,3dh,3dh,3eh,3fh ; 095b :;;<==>?
db 3fh,40h,41h,42h,42h,43h,44h,45h ; 0963 ?@ABBCDE
db 46h,47h,48h,49h,49h,4ah,4bh,4dh ; 096b FGHIIJKM
db 4eh,4fh,50h,51h,52h,53h,55h,56h ; 0973 NOPQRSUV
db 57h,59h,5ah,5ch,5dh,5fh,60h,62h ; 097b WYZ\]_`b
db 64h,66h,68h,6ah,6ch,6eh,70h,72h ; 0983 dfhjlnpr
db 75h,77h,7ah,7ch,7fh,82h,85h,89h ; 098b uwz|....
db 8ch,90h,93h,97h,9ch,0a0h,0a5h,0aah ; 0993 ..... %*
db 0afh,0b5h,0bbh,0c1h,0c8h,0d0h,0d8h,0e0h ; 099b /5;AHPX`
db 0eah,0f4h,0ffh,0ffh ; 09a3 jt..
Yeah that looks the same, apart from a label down the table.
But i suppose its a conversion error somewhere then.
See below.
    57.72 KiB
    102.43 KiB
Reply 681 of 1053, by Maelgrum
S95Sedan wrote on 2023-10-05, 19:03:
See below.
From V4.16:
Details
convert_samplerate:
ret ; 08ba 22 "
From 4.13:
Details
convert_samplerate:
mov dptr,#samplerate_table; 0987 90 09 8c ...
movc a,@a+dptr ; 098a 93 .
ret ; 098b 22 "
samplerate_table: db 15h,16h,16h,16h,16h,16h,16h,16h ; 098c ........
db 16h,16h,16h,16h,17h,17h,17h,17h ; 0994 ........
db 17h,17h,17h,17h,17h,17h,18h,18h ; 099c ........
db 18h,18h,18h,18h,18h,18h,18h,18h ; 09a4 ........
db 19h,19h,19h,19h,19h,19h,19h,19h ; 09ac ........
db 1ah,1ah,1ah,1ah,1ah,1ah,1ah,1ah ; 09b4 ........
db 1bh,1bh,1bh,1bh,1bh,1bh,1bh,1bh ; 09bc ........
db 1ch,1ch,1ch,1ch,1ch,1ch,1ch,1dh ; 09c4 ........
db 1dh,1dh,1dh,1dh,1dh,1eh,1eh,1eh ; 09cc ........
db 1eh,1eh,1eh,1fh,1fh,1fh,1fh,1fh ; 09d4 ........
db 1fh,20h,20h,20h,20h,20h,21h,21h ; 09dc . !!
db 21h,21h,21h,22h,22h,22h,22h,22h ; 09e4 !!!"""""
db 23h,23h,23h,23h,24h,24h,24h,24h ; 09ec ####$$$$
db 25h,25h,25h,25h,26h,26h,26h,26h ; 09f4 %%%%&&&&
db 27h,27h,27h,27h,28h,28h,28h,29h ; 09fc ''''((()
db 29h,29h,29h,2ah,2ah,2ah,2bh,2bh ; 0a04 )))***++
db 2bh,2ch,2ch,2dh,2dh,2dh,2eh,2eh ; 0a0c +,,---..
db 2eh,2fh,2fh,30h,30h,30h,31h,31h ; 0a14 .//00011
db 32h,32h,33h,33h,34h,34h,35h,35h ; 0a1c 22334455
db 36h,36h,37h,37h,38h,38h,39h,39h ; 0a24 66778899
db 3ah,3bh,3bh,3ch,3dh,3dh,3eh,3fh ; 0a2c :;;<==>?
db 3fh,40h,41h,42h,42h,43h,44h,45h ; 0a34 ?@ABBCDE
db 46h,47h,48h,49h,49h,4ah,4bh,4dh ; 0a3c FGHIIJKM
db 4eh,4fh,50h,51h,52h,53h,55h,56h ; 0a44 NOPQRSUV
db 57h,59h,5ah,5ch,5dh,5fh,60h,62h ; 0a4c WYZ\]_`b
db 64h,66h,68h,6ah,6ch,6eh,70h,72h ; 0a54 dfhjlnpr
db 75h,77h,7ah,7ch,7fh,82h,85h,89h ; 0a5c uwz|....
db 8ch,90h,93h,97h,9ch,0a0h,0a5h,0aah ; 0a64 ..... %*
db 0afh,0b5h,0bbh,0c1h,0c8h,0d0h,0d8h,0e0h ; 0a6c /5;AHPX`
db 0eah,0f4h,0ffh,0ffh ; 0a74 jt..
Dont see any difference ))
Reply 685 of 1053, by S95Sedan
Maelgrum wrote on 2023-10-05, 19:26:
This is disassembled 4.13 and 4.16
.ctl files for D52 are made by my autotool
Heres a more complete merged 4.13 one with some of the comparing done from this;
https://github.com/schlae/sb-firmware/blob/master/sbv202.asm
Alot of the names in general and of the command groups are added.
    v413-6k_9e1b22c6.zip
    1.68 KiB
    26 downloads
Reply 686 of 1053, by mattw
@Maelgrum : do you think it will work on older DSPs? I mean now after stage4 seems like perfected. I don't have any DSP 3.x or 2.x cards otherwise, would have tried "stage1" myself already and see what it will output.
Reply 688 of 1053, by Maelgrum
mattw wrote on 2023-10-05, 20:54:
This 'Stage 1' cannot work on DSP < 4.xx, it uses MPU-401, and injection attack is made via MPU recieve routine
F9 and FA - needs checking
[EDIT] no F9 and FA, and dont found any other mem read/write commands. but not looked very deep
Reply 689 of 1053, by maxtherabbit
So it sounds like based on the analysis so far 4.13 patch 4 is actually superior to 4.16 since it saves the registers properly and retains CSP support
Reply 690 of 1053, by Maelgrum
maxtherabbit wrote on 2023-10-05, 21:02:
Better interrupt handlers is very minor improvement, but CSP support without hanging notes is good. So far it looks superior.
I am looking into cmd 0x14 (single cycle DMA) code path right now - can it be improved ?....
Reply 691 of 1053, by Gmlb256
Having seen utilities that does EEPROM flashing on AWE64 sound cards. Could be possible to use the patched DSP v4.13 (or somehow a patched v4.16)?
Reply 692 of 1053, by Maelgrum
Gmlb256 wrote on 2023-10-05, 21:09:
Can you point at this utility ?
Reply 693 of 1053, by Maelgrum
Maelgrum wrote on 2023-10-05, 21:07:
Maybe enabling FIFO for command 0x14 can cure Single cycle DMA problem ...
Reply 694 of 1053, by mattw
Maelgrum wrote on 2023-10-05, 21:11:
no those are for the EEPROM that contains IDs and the PnP info, not the DSP:
Re: SB2AWE EEPROM flasher utility.
I think Dell were the one that leaked the EEPROM tool, then it was reversed-engineered.
[EDIT] however, I am not sure considering my "conspiracy theory" about CT4170 and DSP V4.13 v DSPv4.16. I don't know why Dell needed to update only the EEPROM. maybe, only the EEPROM part of the Dell tool was reversed-engineered and it's capable to update/patch DSP. I don't know... but it makes no sense as all AWE64 have V4.16 and so it has to be limited to the EEPROM.
Reply 695 of 1053, by Maelgrum
S95Sedan wrote on 2023-10-05, 20:34:
Heres a more complete merged 4.13 one with some of the comparing done from this; https://github.com/schlae/sb-firmware/blob/mast […]
This merging is not reliable - it contains some invalid definitions , like:
m 24 autoinit_16bit ; 24h.2 x
this is not true ))
So it is better to analyze code, what was true in DSP 2.0, is not in DSP 4.xx
Reply 696 of 1053, by Gmlb256
mattw wrote on 2023-10-05, 21:13:
no those are for the EEPROM that contains IDs and the PnP info, not the DSP: […]
I think Dell were the one leaked the EEPROM tool, then it was reversed-engineered.
That's a bummer, I thought that these utilities could flash the DSP firmware. 😒
Reply 697 of 1053, by mattw
Gmlb256 wrote on 2023-10-05, 21:19:
What I don't understand is why Dell released those AWE64 EEPROM flash tools in the first place - they say to recover your AWE64, but recover it from what? do they suffer some random EEPROM damage. I don't own AWE64 and I don't know. So, in what case the Dell tool was supposed to be used and intended originally for?
Reply 698 of 1053, by Gmlb256
mattw wrote on 2023-10-05, 21:22:
I don't know about it either tbh as mine never suffered that.
Reply 699 of 1053, by Error 0x7CF
As far as I'm aware, AWE64s store PNP configuration information in the eeprom and if it gets incompletely written while being changed (updated? rewritten on power-up?) it will render the card invisible.
Fortunately I personally have not suffered this.
Old precedes antique.
