Is your pentium 3 faster then mine?
First post, by Oldskoolmaniac
I just want to see what you all got in the way of Pentium 3 machine, I know some of you out there have dual P3 machines.
Just post pic's of your machine and benchmarks.
This is the fastest P3 machine Ive built its a bit overkill but..... why the hell not, im currently trying to get dual slot board.
My specs:
CPU: 1.4GHz Pentium 3-s Powerleap adapter
RAM: 2GB of pc-133
HDD: 2x 120GB white label western digital drives
Video: Geforce 6800 gt
Audio: Asus xonar DG
Power Supply: Antec Earthwatts 380watt
Motherboard: Asus p3v4x
    1.27 MiB
    295.61 KiB
    321.04 KiB
    328.54 KiB
    943.67 KiB
    My iphone isnt the greatest. I wanted to take the pic when it was lite up, its actually not that bright.
Motherboard Reviews The Motherboard Thread
Plastic parts looking nasty and yellow try this Deyellowing Plastic
Reply 2 of 36, by brassicGamer
I'm literally about to post up a thread about my dual Tualatin so I'll chuck some benchmarks in here 😀
No AGP slot sadly, as it's a server, so no bad-ass graphics.
Reply 3 of 36, by Darkman
I wonder how Doom3 runs on this thing....
a tip I would give is to use older drivers, Ive noticed youre using the latest ones available , which generally have more issues with the older cards (worse performance too). For a 6800 , I use the 93.71 drivers.
Reply 5 of 36, by mrau
oldskoolmaniac can you do sandra tests on it?
quite frankly except for the powerful graphics i cannot see anything of interest in the screenshots
i also wouldnt expect it to be faster on a via than on an intel motherboard - are your experiences different?
Reply 6 of 36, by Oldskoolmaniac
i do have an intel motherboard in my dell that im waiting on a tualatin mod for, i can put that up against it as well as my 440bx board although i need to get more parts for my bx and replace caps on it.
Reply 7 of 36, by Oldskoolmaniac
I thought the older driver had problems with via chipsets?
Reply 8 of 36, by Oldskoolmaniac
tyuper wrote:
Is there something wrong with voltage in CPU-Z,...
...or you just preparing to squeeze extra frequency from CPU? 🤣
the voltage jumper on the power leap is 1.65v the motherboard is reporting 2.09, but the powerleap dubs it down with its voltage regulator.
Reply 9 of 36, by Jade Falcon
Rank BANNED
BANNED
If I drop a newer video card and 1.4ghz in my piii setup it would be way faster.
I'm sure I could get a 1.4piii around 1.6ghz easy. Maybe even 1.7ghz
Oh and thake a look at these!
http://valid.canardpc.com/show_oc.php?id=420005
Reply 10 of 36, by Oldskoolmaniac
2GHz from a p3 thats crazy, what motherboard are you using?
My asus sucks at overclocking with a powerleap very unstable.
I do have a spare HD3870 agp laying around.
I should post my p4 system, that thing is beast ive been trying to get close to 4GHz with fan cooling and low volts.
Reply 11 of 36, by Oldskoolmaniac
So far Jade Falcon is the winner here.
Reply 12 of 36, by zstandig
Ah, I have a Pentium 3-s 1.4ghz too. (in my L800r, see the Dell thread)
The old Dell is a bit of a bummer though. No AGP and the RAM is limited to 512MB, wouldn't boot with any more.
The best card I can get working is a Jaton Geforce 9500 (with 1GB of RAM..., more than the computer itself has)
A while ago I got one of those Zotac GPUs that uses Geforce 430GT on a PCI thinking I would upgrade it, but it didn't work with it.
Reply 13 of 36, by Oldskoolmaniac
what kind of scores are getting with that geforce 9500 though?
I know sometimes if u go overkill on GPU you'll get lower scores.
I got a dell 4100 ill post results after i get my tualatin upgrade for it, it wont be any faster then these other boards on here, but we will see where it stands as a Dell.
Reply 14 of 36, by foey
Very nice.
My Pentium 3 scores a little more than yours in 3DMark 2000 on a Ti4600, see my benchmarks for reference...
CPU Intel Pentium III 1400-S Tualatin
Motherboard ECS P6IPAT Intel 815EP B-step Motherboard
RAM 512mb Crucial PC133 CAS2 Ram
Primary Graphics Card 128mb Creative Geforce 4 Ti4600 AGP 4x
Secondary Graphics Creative 3D Blaster Voodoo 2 SLi, 2x 12mb CT6670
Sound Card Creative Sound Blaster Live! CT4760
NIC 3Com PCI 10/100 NIC
SCSI Adaptec 2940U2W SCSI Controller
Storage 40Gb Western Digital 7200rpm IDE Hard Drive - Windows ME
300Gb Seagate Cheetah 10k.7 SCSI Hard Drive - Windows 2000 + Storage for Games
Optical Creative DVD5240E 5X DVD-ROM Drive
Optical Iomega ZIP100 Drive (ATAPI)
Extra Creative Live! Drive IR SB0010
PSU Suntek 420w Dual fan PSU
URL (Full Rig) :- ATC-S PIII Coppermine Win9x Build Log [WIP] **Photo Heavy**
Cyrix Instead Build, 6x86 166+ | 32mb SD | 4mb S3 Virge DX | Creative AWE64 | Win95
ATC-S PIII Tualatin Win9x Build :- ATC-S PIII Coppermine Win9x Build Log [WIP] **Photo Heavy**
Reply 15 of 36, by Oldskoolmaniac
Nice i like the creative theme
Reply 16 of 36, by Jade Falcon
Rank BANNED
BANNED
Those aren't mine. I pulled them from hwbot.
I have a few 1.4ghz and I'm sure with ether my fx5950 ultra or 9800 and some over clocking my piii would be faster. But you scores are grate. Not only that but you systems is nice too.
My piii system has a be62
Reply 18 of 36, by Darkman
does it? admittedly I haven't used that particular VIA chipset , but the VIA chipset on my S939 board works fine with these drivers
Reply 19 of 36, by Jade Falcon
Rank BANNED
BANNED
Via chip sets are not the best for overclocking, without being very skilled with overclocking you will not get over 143fsb by much. Ram can also hold you back
