Reply 20 of 48, by nukeykt
Battler wrote:
So basically, all I need to do is not map the high bank, and that's it?
Yes. For single OPL2 it's enough. But you should emulate somehow Dual OPL2.
Reply 24 of 48, by FM-OPL-Midi-Freak
Hello all!
please, can anyone tell me, how can install the patch file, the content of the"dosbox-nuked-opl.zip" I just replaced with the original dosbox.exe and the corresponding *.dll´s "SDL_net / SDL.dll,
For answer I am grateful 😉
Greets
Matthias
Equipment:
- ESS Solo (PCI)
- Ess Audio Drive-Compaq (ISA)
- Soundblaster 2.0
-Audioblaster Pro 4.0 at the time puplished by CPS Hamburg
-Sw1000XG / Motif XF
Reply 26 of 48, by NewRisingSun
nukeykt, I noticed something when I used the YM3812-bearing CT1320 in my Tandy 1000 TX.
Most documentation states that the YM3812 can be distinguished from the YMF262 by reading the index port; a YM3812 supposedly always returns 0x06, while an YMF262 supposedly always returns 0x00. Well, on the Tandy 1000 TX, reading the index port only returns 0x06 if you write a byte with bits 1 and 2 set immediately to it before! Unlike standard ATs, the Tandy 1000 TX does not pull "open bus" bits high. That also manifests itself in reads from unmapped I/O ports returning whatever just happens to be on the bus, while on a standard AT, reading unmapped I/O ports always returns 0xFF.
Can you confirm that on the YM3812, index port bits 1 and 2 are open bus rather than "1" bits from the chip side?
Reply 27 of 48, by nukeykt
Nuked OPL3 v1.8 is out.
Changelog:
* New envelope generator.
* Rhythm mode emulation is 100% correct now.
These and other aspects of chip have been verified on YMF262 die shot, so emulation should be perfect now.
P.S. For some reason i can't edit topic's header. So i'll attach patch here.
    dosbox-nuked-opl_1_8.zip
    986.75 KiB
    352 downloads
    Windows build
    nukedopl_1_8.patch
    47.59 KiB
    347 downloads
    Nuked OPL3 v1.8 patch for DOSBox r4088
Reply 29 of 48, by nukeykt
appiah4 wrote:
Can this be somehow used with the stable branch of Dosbox instead of SVN? I really don't like messing with SVN most of the time..
Yes. But you have to apply these changes to the source code manually.
Reply 30 of 48, by appiah4
This would go way above my head I'm afraid. Would be very glad if you can build the patch for the stable version as well 😀 Thanks anyway.
Reply 31 of 48, by nukeykt
I'll give a shot then.
Reply 32 of 48, by nukeykt
Here's windows builds. I've accidantly attached older build above and can't edit it.
    dosbox-0.74-nuked-opl.zip
    2.34 MiB
    313 downloads
    DOSBox v0.74 build
    970.73 KiB
    301 downloads
    DOSBox SVN r4088 build
Reply 34 of 48, by Yesterplay80
Thank you, nukeyt! DOSBox ECE was updated with your new version, as of r4088.2 it now includes version 1.8 of your Nuked OPL emu.
My full-featured DOSBox SVN builds for Windows & Linux: Vanilla DOSBox and DOSBox ECE (Google Drive Mirror)
Reply 36 of 48, by Taiyoumaru
If I am to take the information provided by D-Fend Reloaded as accurate, then each individual sound module as its own sample rate except for Disney Sounds Source. https://gyazo.com/c656b6de5e16b84245f7c485be8acdfc
Reply 39 of 48, by evgs
nukeykt wrote:
Nuked OPL3 v1.8 is out. Changelog: * New envelope generator. * Rhythm mode emulation is 100% correct now. These and other aspe […]
Changelog:
Sad that Nuked OPL3 core is not available in "official" upcoming dosbox 0.75 branch.
It eats not too much CPU power, so it must be default as most-accurate core.
