Reply 20 of 26, by j^aws
- Oldbie
^^ I had a quick scan through some Nehemiah cores, and none are Ax50xxx - they are all Ax60xxx. FWIW, I haven't come across a Nehemiah at 1.4v; they have all been Ezra-Ts.
Excellent. The Ezras are the ones we want, anyway.
Looking for a slocket for my SE440BX-2. I specifically want Ezra compatibility. Are any of the following familiar and known to work for anyone?
http://www.ebay.ca/itm/Socket-370-to-Slot-1-3 … 3gAAOSww5NZBeQe
http://www.ebay.ca/itm/Vintage-Slot-1-to-Sock … hkAAOSw2xRYR-Kd
http://www.ebay.ca/itm/Vintage-Intel-CPU-Sock … utorefresh=true
I hope not to hijack this thread. But, I posted my own a while back and it never did get much attention. I have one of those Evergreen branded upgrade CPUs. Specifically an Evergreen Spectra III 600 Mhz. I was thinking it was a Samuel core, but not really sure and can't find anything about it.
^^ Have you tried insalling that CPU and running something like AIDA16 in DOS? Or Speedsys? They should be able to tell you what type of VIA C3 core you have.
wrote:Looking for a slocket for my SE440BX-2. I specifically want Ezra compatibility. Are any of the following familiar and known to w […]
I haven't tried any of those Slockets/ Slotkets. I can comment on the ones I have tried that work:
Asus
AOpen
Abit
MSI
Can't remember their exact model designations, but online searching should reveal them. All the above had a voltage clamp IC onboard, and adjustable voltage. I'm sure there are more that would work.
This is the one I use for my Nehemiah and Samuel 2: http://www.ebay.com/itm/2-Stuck-MS-6905-Maste … nkAAOSwnONZD7yi
I bought the five pack of thoose.
Alrighty, I'll go with the MSI card!
