First post, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
We recently streamlined Exult's mt32emu with current MUNT again (after a decade or so). Unfortunately the iOS port exhibits frequent distortions. Probably needs some ARM optimizations or there is another problem.
The exult-ios port and the changed mt32emu code https://github.com/litchie/exult-ios/commit/3 … 225f1b11c84833e
Main Exult (same commit) https://github.com/exult/exult/commit/c40439c … b9814106e468b5e
I've also added a bug report to SF https://sourceforge.net/p/munt/bugs/25/
    exult-ios.ogg
    376.31 KiB
    110 downloads
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 16, by Dominus
DOSBox Moderator
you can hit me up with anything to try 😀
Reply 4 of 16, by Dominus
DOSBox Moderator
It's only a problem when using the iOS port (with latest munt integrated). Xcode debug shows that it's not maxing out the CPU, if that helps.
Reply 5 of 16, by sergm
I wondered if we can increase the rendering buffer size (the easiest solution but it will impact the latency). Also, please check if the rendering is performed on iOS in the same thread as the other processing.
Reply 7 of 16, by Dominus
DOSBox Moderator
Wow, mt32emu-qt on the iphone? Wow...
Sorry for not responding but weekend was busy... couldn't get to it ;(
So, getting Exult for iOS to run is much easier 😉 you can just grab and compile it with xcode https://github.com/litchie/exult-ios (project file is in /ios). You only need one of the games which can be synced via itunes share
Apart from some include (config.h) Marzo changed Exult to easily accept your upstream changes.
Reply 8 of 16, by sergm
Don't panic. mt32emu-qt needs a lot of work to become a usable iOS app (and to be fair, android as well). You can look at whatamess it is now 😀
I planned to get hands on Exult itself but first wanted to ensure that CPU is powerful enough to at least do the synthesis.
Reply 9 of 16, by Dominus
DOSBox Moderator
Still... awesome 😉
Reply 10 of 16, by sergm
Yeah... Cmake appeared to be not quite that tool one needs to build mobile Qt apps 🙁
Even one (at least) Qt class is missing (!) when building for iOS.
But at least CoreAudio and CoreMIDI all works fine. Btw, the app creates a MIDI destination as usual. I wonder if that CoreMIDI destination can be used to accept connections from other devices via RTP MIDI.
Though, the most disappointing thing is that the app cannot work in the background, so connecting it to other apps seems to have no sense 🙁
Reply 11 of 16, by Dominus
DOSBox Moderator
Yes, it would be great if you could use it in the background for other apps. I don't know if you can use CoreMidi to receive connections but you can use it to send Midi out. I've done that with my MT32, MIDI-USB adapter, Apple camera connection adapter and my iPhone through Exult 😀
Reply 12 of 16, by sergm
This is really weird. Even a single CPU core is capable enough to do the synthesis. However, if I open the "Credits" (or "Quotes") scroller, CPU load rises to over 140% but there are no more dropouts of the sound.
Reply 13 of 16, by Dominus
DOSBox Moderator
Odd, never noticed that the credits and quotes run the CPU so high. And yes, no dropouts in that.
Reply 14 of 16, by sergm
BTW, I cannot see the way Exult resample the output of MT32Emu to the sample_rate required by the mixer. Previously, it was configured in the emu properties but now I can't see any reference...
Anyway, I checked the rendering thread to be the audio unit high-priority thread. Perhaps, we should organise yet another thread to pre-render samples and convert to the output rate, so more buffering to add.
Reply 16 of 16, by Dominus
DOSBox Moderator
Yes, I noticed that as well that only 22k seems to sound like anything. For fun set it to mono ... crash...
