Reply 480 of 1207, by feipoa
elbbar wrote on 2022-11-12, 15:27:
I would suggest adding several bypass capacitors near the CPU.
Are you referring to adding bypass capacitors to the voltage set resistor(s) or adding more decoupling capacitors? In either case, could you be more specific with which capacitor values should be used and where?
Reply 481 of 1207, by elbbar
Food for thought.
https://invidious.snopyta.org/watch?v=KDQsLDN9df8
https://invidious.snopyta.org/watch?v=1xicZF9glH0
https://invidious.snopyta.org/watch?v=BcJ6UdDx1vg
169.53 KiB
Reply 482 of 1207, by feipoa
elbbar, I'm not sure what you are showing a photo of, but it doesn't look like a 386 or 486 interposer. Our later designs have a total of 10 capacitor pads for Vin and Vout. Could you be more specific with what you are recommending? All I can think of is adding bypass capacitor in parallel to to the voltage setting resistor, R2. When I looked into this some months ago, I decided it probably wasn't necessary, but it is easy enough to test on the beta.
158.98 KiB
Reply 483 of 1207, by Sphere478
Ti 486SXL2-50 on some kind of adapter... what is this for?
Cross linking
Sphere's PCB projects.
Reply 484 of 1207, by feipoa
In the start of that thread, that adapter is on a PGA132 CPU. It helps with cache coherency issues on some obscure systems. Evergreen made one, as did Kingston. I found that none of the 8 or so 386 motherboards I tested needed this adapter. Later in the thread, there's another adaptor for a PGA168 Cyrix 486. That 486 is nothing like the SXL2 PGA168 CPU made by TI. All that later adaptor does is let you run an FPU on that early Cyrix 486 because it didn't have an onboard CPU in the die.
Reply 485 of 1207, by rafpereira
feipoa wrote on 2022-11-20, 00:17:
I can't tell you if this was for SXL2, as I did not take those... but I hope the pictures will serve as inspiration.
74VHC00 - https://utcdn.utsource.info/pdfjs/index.html? … HILD_74VHC04MTC
74HC4024D - https://utcdn.utsource.info/pdfjs/index.html? … I_CD54_74HCT374
    288.18 KiB
    288.93 KiB
Reply 486 of 1207, by feipoa
Thanks. I have this adaptor. It was for a 5 V SXL. We are trying to make this for a 3.6 V CPU. Still waiting for shipment to arrive...
Reply 487 of 1207, by feipoa
Quick update: the new PCB's are here and all pins go where they are supposed to. Silkscreen over vias seems OK. I didn't check U1 and U2. Is there a diagram showing where these should go?
Scanned it this time:
540.46 KiB
Reply 488 of 1207, by Sphere478
They look very good!
I kind of just copied what was done on the other PCB he checked it and said it was OK. for your uses I don’t think you will be using it so simply do not populate it unless you have a board you can test it on
Reply 489 of 1207, by Sphere478
Some of those vias look like they don’t have holes… I’m sure they are fine but can you look closer at that? Probably just image quality. Prob fine.
Reply 490 of 1207, by feipoa
You mean the vias on the 4 corners and some in the centre region? It's not image quality. The vias aren't obvious. I did check every single pin though.
Reply 491 of 1207, by Sphere478
Yeah, there are a bunch that just look flat 🤣. I’m sure it’s fine though 😀
Reply 492 of 1207, by Sphere478
I’ve been holding my breath waiting for an update. I’m kinda a vogons purple color now. :p had a chance to assemble it?
I’ve been looking closely at the images. I see a few solder blobs under the silk but otherwise everything looks amazing. Can’t wait for you to plug it in and see how high you can clock it!
Reply 493 of 1207, by feipoa
I was going to assemble it tonight, but my wife has been getting on my case about staying up late with these self-imposed hobby tasks.
Reply 494 of 1207, by feipoa
I've soldered on all the PGA pins now, top and bottom. With interruptions, it took 1 hr. 45 min. Without, probably would take 1 hr. The trickiest part would be the inner 4 corners. Don't accidentally get solder in an adjacent empty via, or it can be difficult to get out.
The distance from the PGA168 socket to the edge of the PCB is 1.30 mm. Conservatively, we could probably trim 1 mm off all 4 sides, assuming that 1 mm wide perimeter is imperative for trace real-estate. The header with 5 through-holes can be nudged maybe 0.5 mm to 0.7 mm closer to the socket to help meet the clearance. I wouldn't spend any more time on the layout until we know it works though.
Reply 495 of 1207, by Sphere478
Do you think making it smaller will actually help on any boards? Are there boards with clearance issues that tight?
I can understand it maybe hitting the fet side, but the sides?
Reply 496 of 1207, by feipoa
I don't own every 386 motherboard out there, so I cannot say for certain if the reduction by 1 mm will help. I am talking about all 4 sides, not just the FET side. I have on a few occasions had upgrade adapters just barely not fit and it is irritating. I either have to desolder a cap on the motherboard and replace it with a smaller one, bend the cap out of the way, or have to use PGA extension sockets to make the clearance.
The other adaptor I have, same one that the other poster just provided a photo of, I use it with an additonal VRM module, and on one baord, it just barely hits the reset header on the motherboard. So I had to use an extension socket to make the clearance. In such a case, if it was 1 mm smaller, I wouldn't have to use sockets to lift up the board.
It may only be worth the effort to shrink the board by 1 mm on all 4 sides if something else of greater importance needs to be changed on the design.
Luckily, the 1210 ceramic capacitors I ordered will fit the existing design, as well the smaller 1411 tantalums. Just barely, but enough that solder won't have to bridge an air gap.
Reply 498 of 1207, by Sphere478
I looked at the images from
Earlier in thread to refresh myself, (I’m still away from computer) and if you want it smaller, the edge capacitors gotta go.
Or, it will have to be a non rectangular shape.
So options are:
1: Leave as is
2: irregular shape
3: smaller rectangular but ditch the edge caps
I campaigned to remove the edge caps earlier but you wanted to keep them because they look cool. And I agree they do. I’m actually happy we kept them, you were right about them looking cool 🤣
But if you want smaller, they gotta go.
I’m leaning toward leave as is. Doesn’t seem like it’s worth it to alter it at this point.
I have thought up an idea to flip the center caps around 180* though.
To make the path to the regulator more direct. But it isn’t necessary.
Reply 499 of 1207, by feipoa
I don't quite follow how the VRM's left/right caps follow shrinking the PCB footprint on the far side of the PCB. Seems unrelated.
It is the giant pin header which is the limiting factor on the overhangs protrusion distance right now, not the side caps.
Normally, primary output for VRM's should be placed as close as possible to the VRM.
I am wondering if the centre input caps serve any purpose. Seems like only the centre output caps serve a purpose.
feipoa wrote on 2022-11-26, 03:03:
