Reply 20 of 26, by Davros
- l33t
Windows 3.1
The Adventures of HyperMan
http://www.mobygames.com/game/win3x/adventures-of-hyperman
Windows 3.1
This is an old post, but interesting as I was looking to do something like this. The way I would do it is gather a list of old games and sort by date. Then split the games based on the OS release dates.
You could then run a script, which could local the main game .exe file and somehow check if its a dos or windows executable (to filter out dos games). Thats a lot of work because there are a lot of games.
About "exclusive" Windows 3.x and 9x games: There are those that uses the VGA registers directly and/or taking advantage of VxDs in ways they normally shouldn't in Windows. The WinDirect API by SciTech is a perfect example of this when used exclusively.
Technically Star Havoc counts too but that's a very obscure DOS game that requires LFN support and running within Windows 9x for the best stability.
VIA C3 Nehemiah 1.2A @ 1.46 GHz | ASUS P2-99 | 256 MB PC133 SDRAM | GeForce2 GTS 32 MB | Voodoo2 12 MB | SBLive! | AWE64 | SBPro2 | GUS
There is an old windows program to scan executables for what API they use and then categorize it per OS. It hasn't been updated since 9x days and I don't think it covered dependencies but there wasn't too many of those back then. Open source has made compatibility worse in that aspect heh. I have it squirreled away but am visiting my folks.
Doesn't seem to be many answers to the original question.
Full Tilt Pinball (the ancestor to Microsoft's free Space Cadet Pinball), only runs on 3.1 and 9x. There's separate installs for each of those OS's. 256-colour (minimum) is required. I don't have ME to test with.
I tried running the game on a W2K machine but it errors at start. The hardware is the same as used for the supported OS's.
When Microsoft modified it, they got it to work on all 32-bit versions of Windows, and also 16-colour became supported.
Gmlb256 wrote on 2023-11-17, 00:43:About "exclusive" Windows 3.x and 9x games: There are those that uses the VGA registers directly and/or taking advantage of VxDs in ways they normally shouldn't in Windows. The WinDirect API by SciTech is a perfect example of this when used exclusively.
DxWnd handles VGA palette registers, I would exclude that from this criteria. Examples using this are Dark Vengeance, Campus Heroes and Terracide (Eidos).
For other ways that touch registers, I don't know (are there any excluding WinDirect/DispDib ones)?
Robbbert wrote on 2023-11-17, 05:28:Doesn't seem to be many answers to the original question. […]
I just played FT Pinball on Windows 11 today 😉
Could SCI Win32 games count? There are modern patches for the game, but the OG ones don't work on NT
