Reply 40 of 68, by pdw
Benedikt wrote on 2021-08-18, 11:23:
Is the programming model publicly documented, yet?
You can use these routines (for DOS compilers):
https://github.com/pdewacht/cmslpt/blob/maste … cmslpt/cmsout.c
https://github.com/pdewacht/cmslpt/blob/maste … mslpt/cmsinit.c
The CMS has two SAA1099 chips: the "cmslpt_first" routines control the first one, the "cmslpt_second" routines control the second one. Simple as that 😀
You can find the manual for the SAA1099 here: http://www.vgmpf.com/Wiki/index.php?title=SAA1099
Reply 42 of 68, by FreddyV
Benedikt wrote on 2021-08-18, 19:04:
This is the kind of information I was looking for. (Mostly the relationship between CMS and CMSLPT)
These are the files I use for Mod Master CMSLPT code, Just needed to do an ASM Version.
You are working on what ?
Reply 43 of 68, by Benedikt
FreddyV wrote on 2021-08-18, 20:35:
I've been working (on and off) on a support TSR that does Tandy-to-CMS translation for binaries that have been patched to use int 0c0h instead of out 0c0h,al.
Reply 44 of 68, by FreddyV
Benedikt wrote on 2021-08-19, 07:06:
Nice, I would like to do the same.
CMSLPT Now work on Mod Master.
Reply 45 of 68, by Benedikt
FreddyV wrote on 2021-08-21, 13:53:
We could certainly share some code for the Tandy-to-CMS parameter translation.
Reply 46 of 68, by FreddyV
Benedikt wrote on 2021-08-21, 15:02:
Are you doing it in ASM ? What code do you need ?
Doing this is simple, the more difficult are the Frequencies and volume conversion
(Linear to LOG) CAn be done with tables of course.
CMS Volume is Linear and frequency LOG (Octave + Period)
Tandy Volume is LOG and Frequency linear 😀 : 16 Values to convert, simple table
Reply 47 of 68, by Benedikt
I have mostly concentrated on precisely that frequency conversion, so far.
My code snippets use the nasm syntax, but do not use any fancy features that would prevent an adaptation for Turbo Pascal's inline assembler.
Reply 50 of 68, by AppleSauce
Hey , I've got a question since I've been thinking of getting one of these , from what I've read the original gameblaster had a chip labeled CT1302A.
That chip did some sort of detection routine for games , does the TSR for this device circumvent/replace that chip?
And does the CMSLPT work with pretty much any cms/gameblaster game?
Reply 51 of 68, by AppleSauce
Also one other question , for the power it uses a usb cable , could I plug it into my pentium 1's usb 1.1 port or would I need some kind of usb power adapter?
Reply 52 of 68, by dreamblaster
AppleSauce wrote on 2022-03-22, 01:12:
The TSR does the heavy lifting here.
AppleSauce wrote on 2022-03-23, 03:31:
Yes
Thanks for your support !
Reply 53 of 68, by AppleSauce
Alright well I bought one and connected it but no games seem to detect it though the test music player works.
Police quest 2 for example just gives me an error.
909.1 KiB
Reply 54 of 68, by AppleSauce
dreamblaster wrote on 2022-03-23, 18:10:
The TSR does the heavy lifting here. […]
Yes
Could it be a conflict issue with my sound blaster pro 2?
I tried the sb option in the tsr but that didnt work either.
Reply 55 of 68, by bjwil1991
Set the HW address on the CMSLPT to 210 and change the HW address for Sierra On-Line and Lucasarts (Money Island) games (there is a patch somewhere and I cannot recall exactly).
I had the same exact issues with my 486 with an Aztech Sound Galaxy NX Pro 16 at 220h and the patch/address change for the games and setting the HW address as 210h in the TSR program fixed my issues hands down.
Reply 56 of 68, by AppleSauce
bjwil1991 wrote on 2022-04-06, 09:59:
Well I tried patching some games after referring to this thread
CMS/Game Blaster game patching and setting a new standard!
pretty sure I did the patch for colonels bequest right but its still not working.
Reply 57 of 68, by AppleSauce
Yeah I've tried a buncha other games no dice.
I've also got a gravis in the pc and it's using irq 7 I think , would that cause it to not work if it conflicted with the printer port? I didn't initialise it but that didn't help either.
I've tried setting the cmslpt to 210 but it doesn't make a difference.
Reply 58 of 68, by bjwil1991
Set the GUS to a different HW address. That there's a conflict.
