Top or bottom mounted PSU?
Reply 20 of 33, by gdjacobs
dr_st wrote:
cyclone3d wrote:
For every 7C cooler, you about double the life expectancy of the capacitors inside a PSU.
I think it said 10C in one of the articles you linked to.
10 deg C drops is the accepted figure for the lifespan of capacitors, chokes, and transformers to double.
Reply 21 of 33, by cyclone3d
Ok, I am pretty sure I saw a 7C figure somewhere but not finding it now so I'll just use the standard 10C from now on.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 22 of 33, by Scubs
cyclone3d wrote:
Yes it does. On bottom mounted PSUs, the PSU draws cool air through the PSU from the outside of the case. […]
Scubs wrote:
We all should know the hotter a part runs the shorter the life span. But that has nothing to do with top vs. bottom mounted PSU's
On top mounted PSUs, the PSU draws in warm/hot air though the PSU from inside the case.
It has EVERYTHING to do with top vs. bottom mounted.
Your assuming a top mounted psu cant pull air from outside the case as well. Your also assuming the bottom mounted psu has a side mounted fan and not a rear mounted fan.
Reply 23 of 33, by dr_st
I find his assumptions quite reasonable.
In most bottom-mount PSU cases the airflow is set up as follows, which is consistent with his comments.:
A rear-mounted fan makes little sense, as that's where the cables / connectors go. Even if you found such a PSU, it would still be sucking in cooler air at the bottom of the case than at the top.
And how exactly is the top mounted PSU going to pull air from the outside of the case? Through the exhaust? Or do you suggest an intake fan at the top of the case (which is generally not done, because it would interfere with normal airflow).
Reply 24 of 33, by squiggly
Think I would rather extend the lifespan of everything else in the case by using the PSU as another heat exhaust fan for the entire case.
Reply 25 of 33, by Radical Vision
My machines are very cool, with proper coolers, and the PSU is mounted on the top on all of them, the 462, slot 1 Pentium II, Slot 1 Pentium III, 939 Opteron on 2.7GHz , nothing is overheating or so, i have zero problems with that, but seems other people have.......
K7 2.6/ NF7-S/ HD3850
Cmq P2 450/ GA-BX2000/ V2 SLI
IBM PC365
Cmq DeskPRO 486/33
IBM PS/2 Model 56
SPS IntelleXT 8088
Reply 26 of 33, by dr_st
That's exactly what my initial claim is based on. The assumption that a bottom-mounted PSU will run cooler in most circumstances is very plausible. Whether it has practical (not merely theoretical) effects on the longevity of anything is not so firmly established, in my view (and in light of some of the data cyclone3d linked to).
If the life expectancy of a capacitor running at 55C ambient is 13 years (*), and every 10 degree drop doubles it, then for 45C ambient (which is probably closer to what you would get, even in a hot case with a top-mounted PSU), then it should be ~26 years? Way beyond what one would deem necessary. Almost every other component in a system has significantly shorter life spans.
(*) It may be that I misunderstood the bottom line of the article where this number was mentioned, as I only skimmed it; If I did, please enlighten me.
Reply 27 of 33, by buckeye
dr_st wrote:
I find his assumptions quite reasonable. […]
Ok, got a confession to make. On my XP rig my bottom mounted PSU has the fan TOPSIDE, so it's sucking hot air from the parts above it? Should I flip it?
Reply 28 of 33, by cyclone3d
It will make the PSU run cooler.
YMF7x4 Guide
Reply 29 of 33, by vvbee
I never buy bad quality power supplies that need their airflow micromanaged for heat and I also don't aim to keep them around for decades like I do some other components. That said I mount my psus whichever way I deem beneficial for the particular system. Certainly in designing airflow that doesn't generate harmful pockets of warm air you need to consider more than the placement of the psu, ideally having first obtained 3d heat maps of the case in various configurations.
Reply 30 of 33, by appiah4
Just wanted to chime in to share this PC I have.. Apparently bottom mounted PSUs were a thing all the way back in 1994:
Reply 32 of 33, by shamino
I have an old HP P2 Xeon machine with a bottom mounted PSU. I like it aesthetically and for the physical stability it adds, but that system was designed for it. The PSU connector is on the bottom of the board and each set of wires from the PSU is the appopriate length for where it needs to go. Unlike modern implementations, it pulls air from inside the case, which I think is more practical. It's 20 years old and still works perfectly, but it wasn't cheaply made and wasn't marketed for quietness.
If a PSU fails from heat within a reasonable lifetime, I blame it on any of these things:
1) The use of junk capacitors that will never be reliable at any temperature. I'm not going to try very hard to extend the life of a bunch of Fuhjyyus. The only real solution is to replace the caps or get a PSU that has good ones to start with (admittedly that can be hard to find).
2) The use of a cheap fan that fails. Basically the same complaint as #1 - cheap parts.
3) The use of a variable speed fan. In principle that's great, but in practice these setups seem to be skewed heavily in favor of quietness. They want NewEgg reviews to rave about how quiet the PSU is. Nobody's going to post back about long term issues from a chronically high temperature.
I don't like the idea of pulling air from under the case. This is asking for tons of dust and pet hair to get sucked in. If you keep your computer on your desk then this issue is greatly lessened. Even so, pulling air from the surface directly underneath the case is always going to be the most dust prone way to do it.
From what I've seen of modern cases, I think they tend to have filters down there nowadays. That's good, but it doesn't totally satisfy me with respect to the issue, and it's not a convenient place to need to be messing with filters.
On a conventional motherboard with top mounted power connectors, I prefer a top mounted PSU. If it's going to be in the bottom, I would prefer to pull the air from inside the case. I would also have a dust filtered intake fan in the front of the case.
But I also like external drive bays, a sealed top, and properly colored wires. Based on some recent window shopping, I think my preferences for cases are obsolete on all but the cheapest models nowadays. 😀
Reply 33 of 33, by Errius
The only time I've run a bottom-mounted PSU was as an auxiliary power supply in a system with a weak primary PSU. This was only temporary until I got a more powerful primary PSU. (Power consumption was unacceptably high with two PSUs.) The case was the original Cooler Master Stacker which has both top and bottom PSU slots.
Is this too much voodoo?
