Phantasy Star Online Blue Burst classic fullscreen won't load
General information and assistance with dgVoodoo.
Postby todd » 2018-8-01 @ 11:10
Hi there is an issue.
I installed this for PSOBB to see if it worked better or the same as the directx8 to directx9 wrappers from reshade.
There is no issue with the reshade wrapper that I know of besides slow frame rate at very high res in a few spots which might be hardware limit.
PSOBB works great with the reshade one enabling me to play at 4K res, 2xEQ AA, 16xAF etc.
The main problem these wrappers fix for PSOBB as a directx8 game is the fact nVidia Optimus and switchable graphics on AMD no longer support directx8 so the games cannot be detected properly and ran on discrete graphics cards. None switchable graphics systems have no real issue just running directly. There may be performance boosts or other fixes by using a wrapper tho, have not tested.
The issue with dgVoodoo 2 is when starting PSOBB in classic fullscreen mode at 1080p the screen is black with just the mouse cursor. Sometimes the game launching flips out and somehow ends up in a tiny window which the game renders in fine but is too small- odd.
One thing I should mention if it has anything to do with this is I do run dgVoodoo 2 PSOBB from steam as I have a steam controller. The steam controller does not work with any game unless launched from steam or otherwise with steam open. It does add a graphical feature to PSOBB such as a virtual keyboard etc.
Anyway wonder what the issue is. Any idea?
Todd Giffen
todd
Re: Phantasy Star Online Blue Burst classic fullscreen won't load
Postby Dege » 2018-8-02 @ 09:04
Does it work for you in windowed mode?
It's a bit weird, I just tried PSOBB (altough not the Steam version) in fullscreen 2560x1440 and it worked for me fine.
Dege
Postby todd » 2018-8-06 @ 10:19
-edit-
todd
Postby todd » 2018-8-06 @ 11:42
This is odd. Fullscreen works now but it has the same missing text starting at the start screen as the above screen shot. All menu items, chat text, user names etc are like that.
This is very strange as I changed nothing on my PC but switched to reshade dx8 to dx9, changed some AMD control panel settings to optimize quality and performance.
Anyway now the game starts fine all modes. It is just the text is corrupt.
todd
Postby todd » 2018-8-07 @ 00:02
Was able to do more testing.
Window mode works.
But for classic fullscreen mode, it might only work in the monitors native resolution.
So my monitor is 4K. 4K res starts but text is corrupt. This is one of the other settings I changed is setting the game to 4K instead of 1080p.
If I set res to 1080p or anything else, something will cause the app to freeze at the start.
There could be an issue with the windows popup that asks if you want to fix your resolution or blurry apps.
The other thing to know about this game is it locks up if the game ever loses full screen focus. So if the dgVoodoo 2 wrapper or windows 10 is somehow sending a signal it should not that fullscreen has been interrupted, it will freeze.
I am wondering if the windows 10 popup that asks if your app is blurry when in fullscreen without native resolution is having an effect on dgVoodoo 2 and the PSOBB activating the games built in freeze function?
Dont know why PSO and PSOBB freeze but in the first version of the game there was no window mode. Only fullscreen and if you tried to leave fullscreen or accidentally hit the windows key or anything, you would end up freezing or crashing the game.
The way this looks I think - if I am onto the right thing - is PSOBB with the dgVoodoo 2 wrapper simple displays a black screen at start up, sometimes with a mouse cursor, or sometimes displays the first loading frame before freezing. This difference between black screen or first frame might correspond to the windows 10 popup appearing about not being in native resolution- which takes different time each load depending on factors.
Also I can confirm in regular PSOBB, if you even so much as click cancel on that windows 10 popup the game will freeze immediately. This is difference between dgVoodoo 2 PSOBB and regular PSOBB: regular PSOBB allows the popup from windows 10 without freezing but will freeze if you click the popup. dgVoodoo 2 PSOBB freezes just if the popup appears or tries to.
Also I can confirm that with dgVoodoo 2 upon starting psobb with any resolution, the game randomly starts in a window mode instead of fullscreen, but the window is so small you can barely see the game, rather than starting up in classic fullscreen as intended.
And the text all throughout the game is replaced with white or gold boxes even if you do get it started.
Testing using ephinea version of app.
todd
Postby ZellSF » 2018-8-07 @ 13:15
Try running it without ReShade and Steam overlay? You're adding complicating variables before you have solved the basic problem which is stupid.
Also disable DPI scaling in compatibility settings for the program if you think that's the issue?
ZellSF
Postby todd » 2018-8-07 @ 17:53
I already did. I dont have steam or reshade enabled during my tests.
I only had steam on the first time I noticed it.
Launching the game directly has the same issue.
I never had reshade installed. I only use the reshade directx8 to directx8 wrapper, which when dgVoodoo 2 is installed replaces reshades dll.
No DPI scaling is not the issue. WINDOWS 10 unlike previous versions of windows always warns the user when they run the desktop or a game in non native resolutions. This is where dgVoodoo 2 is having a fuck up causing a conflict with the warning popup which does not happen when dgVoodoo 2 is not in use.
todd
Postby ZellSF » 2018-8-07 @ 18:37
todd wrote:No DPI scaling is not the issue. WINDOWS 10 unlike previous versions of windows always warns the user when they run the desktop or a game in non native resolutions. This is where dgVoodoo 2 is having a fuck up causing a conflict with the warning popup which does not happen when dgVoodoo 2 is not in use.
Does it show that warning popup when you've explicitly chosen a DPI scaling mode in compatibility options?
ZellSF
Postby todd » 2018-8-08 @ 00:57
The app is already 100% scaled properly. Fully DPI compliant game.
Set your desktop resolution to lower than the native and windows will show the popup there too.
Windows 10 gives the warning whenever the screen is not running at native.
todd
Postby ZellSF » 2018-8-08 @ 06:42
todd wrote:The app is already 100% scaled properly. Fully DPI compliant game.
Windows 10 (1803 and lower at least) do not give any sort of warning when changing resolutions to lower than native. It only gives warning when changing DPI settings while still logged inn, which might correlate with a resolution change, but the cause is still DPI settings. So if a game is triggering that notification, manually setting a DPI scaling mode might fix it. There's also a "No and don't show again" in the notification.
I don't believe the notification is the problem, but getting rid of it and ruling it out shouldn't be difficult.
ZellSF
Postby todd » 2018-8-10 @ 03:35
The option for DPI scaling is already set correctly.
This game handles it's own DPI so it is set to application.
I happen to be in the Windows 10 insider club, I am on a mega advanced build.
This popup box only appears if running the game in non native resolution. There is probably also a box for DPI settings too.
The box is definitely the problem. Switching to native resolution eliminates the box, and the game runs.
Switching to non native resolution activates the box causing dgVoodoo 2 PSOBB to freeze.
If you cannot get the little popup to appear on your system you may have already disabled it or are not running in sub native resolution.
todd
Postby ZellSF » 2018-8-10 @ 09:02
As I said, I'm running 1803, the stable build of Windows. That popup does not exist there. If it isn't third party software (can you make a screenshot of the box?) then it's something new specifically to insider builds.
ZellSF
Postby todd » 2018-8-13 @ 00:31
Have no idea if the popup is causing it but that popup is a nasty biatch possibly. dgVoodoo 2 just doesn't work on my config at any resolution.
I reinstalled dgVoodoo 2 and for 4K resolution, and qHD, the game creates a mini black box in the corner then crashes.
Anyway I have confirmed dgVoodoo 2 is just a big piece of turd.
Both ENB and ReShade's DirectX8 to DirectX9 wrappers work fine confirming the issue is dgVoodoo 2 not a third party wrapper.
PSOBB also works fine with all wrappers uninstalled except it runs on the intel graphics because it is a directx8 game.
todd
Postby todd » 2018-8-13 @ 01:38
here's a debug:
Code: Select all
[\\DESKTOP-HKAVRA7]
00000001   0.00000000   [12744] RecursiveDirectoryCreate( C:\Users\wiseg\AppData\Local\CEF\User Data directory exists )
00000002   0.06427090   [13920] IPC server is in my process - could/should be using an in process pipe
00000003   0.08905010   [12744] [0812/183021.240:INFO:crash_reporting.cc(215)] Crash reporting enabled for process: browser
00000004   0.12172260   [13920] CApplicationManagerPopulateThread took 2 milliseconds to initialize (will have waited on CAppInfoCacheReadFromDiskThread)
00000005   0.13560820   [12744] [0812/183021.287:ERROR:gpu_process_transport_factory.cc(1029)] Lost UI shared context.
00000006   0.17118300   [13920] CAppInfoCacheReadFromDiskThread took 67 milliseconds to initialize
00000007   0.20236970   [13920] CHTTPRequestCache took 82 milliseconds to initialize
00000008   1.14467263   [13920] Local Device Found
00000009   1.14467263   [13920]   type: 28de 1102
00000010   1.14467263   [13920]   path: \\?\hid#vid_28de&pid_1102&mi_02#7&3abbaa23&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
00000011   1.14467263   [13920]   serial_number:  - 0
00000012   1.14476526   [13920]   Manufacturer: Valve Software
00000013   1.14480126   [13920]   Product:      Valve
00000014   1.14489102   [13920]   Release:      100
00000015   1.14491034   [13920]   Interface:    2
00000016   1.14491034   [13920]
00000017   1.14505982   [13920] Controller uses V1 HID protocol
00000018   1.14515316   [13920] !! Steam controller device opened for index 0.
00000019   1.14553022   [13920] Steam Controller reserving XInput slot 0
00000020   1.20913744   [13920] Controller 0 connected, configuring it now...
00000021   1.65865076   [13920]   Chip ID: 308002186794abaec6a43255401900f5
00000022   1.70768797   [13920] BYieldingQueryAccountsRegisteredToController
00000023   1.75030541   [13920] !! Controller 0 attributes:
00000024   1.75030541   [13920]   Type: 2
00000025   1.75030541   [13920]   ProductID: 4354
00000026   1.75030541   [13920]   Serial: FC619203BC
00000027   1.75030541   [13920]   Capabilities: 00013ff7
00000028   1.75030541   [13920]   Firmware Version: 0
00000029   1.75030541   [13920]   Firmware Build Time: 1527718333 (Wed, 30 May 2018 22:12:13 GMT)
00000030   1.75030541   [13920]   Bootloader Build Time: 1439863405 (Tue, 18 Aug 2015 02:03:25 GMT)
00000031   1.75232923   [13920] Could not load local selection (), local override (C:\Program Files (x86)\Steam/controller_config/bigpicture.vdf), or user path (C:\Program Files (x86)\Steam/appcache//controller_configs/bigpicture.vdf), checking last resort path: C:\Program Files (x86)\Steam/controller_base/bigpicture.vdf
00000032   1.75973356   [13920] Loaded Config for Last Resort Path for App ID 413090: C:\Program Files (x86)\Steam/controller_base/bigpicture.vdf
00000033   1.76665723   [13920] Could not load local selection (), local override (C:\Program Files (x86)\Steam/controller_config/bigpicture.vdf), or user path (C:\Program Files (x86)\Steam/appcache//controller_configs/bigpicture.vdf), checking last resort path: C:\Program Files (x86)\Steam/controller_base/bigpicture.vdf
00000034   1.76963377   [13920] Loaded Config for Last Resort Path for App ID 413090: C:\Program Files (x86)\Steam/controller_base/bigpicture.vdf
00000035   1.77162480   [13920] Could not load local selection (), local override (C:\Program Files (x86)\Steam/controller_config/steamdesktop.vdf), or user path (C:\Program Files (x86)\Steam/appcache//controller_configs/steamdesktop.vdf), checking last resort path: C:\Program Files (x86)\Steam/controller_base/steamdesktop.vdf
00000036   1.77666402   [13920] Loaded Config for Last Resort Path for App ID 413080: C:\Program Files (x86)\Steam/controller_base/steamdesktop.vdf
00000037   1.77770436   [13920] Controller 0 mapping uses xinput : false
00000038   7.23012018   [12744] Found unsupported CDM version 1.4.9.1088, using last known good version 1.4.8.1008
00000039   11.78475761   [13920] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000040   11.78512478   [13920] [413080]Non-Steam Controller Configs Enabled: 1
00000041   11.78746414   [13920] local (potentially out of sync) copy of roaming config loaded - 3693 bytes.
00000042   12.65886974   [13920] roaming config store loaded successfully - 3693 bytes.
00000043   12.65922165   [13920] migrating temporary roaming config store
00000044   12.86247921   [13672] [0812/183034.027:INFO:crash_reporting.cc(215)] Crash reporting enabled for process: gpu-process
00000045   12.88053322   [9448] [0812/183034.045:INFO:crash_reporting.cc(215)] Crash reporting enabled for process: renderer
00000046   13.36731625   [13920] Failed to init SteamVR because it isn't installed
00000047   13.44098568   [13920] ExecCommandLine: ""C:\Program Files (x86)\Steam\Steam.exe""
00000048   14.03650284   [13920] IPC server is in my process - could/should be using an in process pipe
00000049   14.04355717   [13920] System startup time: 14.17 seconds
00000050   14.04393482   [13920] !! Controller 0 attributes:
00000051   14.04393482   [13920]   Type: 2
00000052   14.04393482   [13920]   ProductID: 4354
00000053   14.04393482   [13920]   Serial: FC619203BC
00000054   14.04393482   [13920]   Capabilities: 00013ff7
00000055   14.04393482   [13920]   Firmware Version: 0
00000056   14.04393482   [13920]   Firmware Build Time: 1527718333 (Wed, 30 May 2018 22:12:13 GMT)
00000057   14.04393482   [13920]   Bootloader Build Time: 1439863405 (Tue, 18 Aug 2015 02:03:25 GMT)
00000058   14.04466438   [13920] Fetching Config Sets 0
00000059   14.04479885   [13920] CClientJobFetchPersonalizationFileID
00000060   14.06091976   [13920] Blocking global navigation to: data:text/html,%3Cbody%3E%3C%2Fbody%3E
00000061   14.16389942   [13852] [0812/183035.329:INFO:crash_reporting.cc(215)] Crash reporting enabled for process: renderer
00000062   14.19801426   [9088] [0812/183035.363:INFO:crash_reporting.cc(215)] Crash reporting enabled for process: renderer
00000063   14.27734280   [13920] Set Account Config Sets 0 1 1
00000064   14.60515881   [13920] OnFocusWindowChanged to window type: k_nGameIDControllerConfigs_Desktop, AppID 413080
00000065   14.60775375   [13920] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000066   14.60803318   [13920] [413080]Non-Steam Controller Configs Enabled: 1
00000067   14.60857487   [13920] OnFocusWindowChanged to window type: k_nGameIDControllerConfigs_Desktop, AppID 413080
00000068   14.61030674   [13920] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000069   14.67731953   [13920] CAPIJobRequestUserStats - Server response failed 2
00000070   16.10744286   [13920] [413080-650764041]: Failed to start tracking playtime
00000071   16.27648354   [13920] [413080-650764041]: Failed to start tracking playtime
00000072   20.43580246   [13920] Loaded Config for Local Selection Path for App ID -2147483647: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\1459950924\957464882662497763_legacy.bin
00000073   20.43635941   [13920] [2147483649]Non-Steam Controller Configs Enabled: 1
00000074   20.48215675   [13920] Initializing font file enumerator: C:\Program Files (x86)\Steam\tenfoot\resource\fonts\
00000075   20.48264122   [13920] CreateCustomFontfileReference succeeded
00000076   20.48837662   [13920] CreateCustomFontfileReference succeeded
00000077   20.72313118   [13920] No cached sticky mapping in GetActionSetHandle. Native Steam Controller support won't work.
00000078   20.81058311   [13920] Found adapter AMD Radeon (TM) R9 M390X
00000079   20.81063843   [13920] Found adapter Intel(R) HD Graphics 530
00000080   20.81070518   [13920] Found adapter Microsoft Basic Render Driver
00000081   20.84043121   [13920] !! Using adapter AMD Radeon (TM) R9 M390X, GPU Mem: 3.22 GB, Sys Mem: 0 bytes, Shared Mem: 1.07 GB
00000082   20.86727905   [13920] Created ID3DX11Effect for orthographic2d.fxo from memory ok!
00000083   20.89989662   [13920] defaultfocus=DummyInput not found within layout file for welcome_nocontroller
00000084   20.90000343   [13920] defaultfocus=DummyInput not found within layout file for welcome_nocontroller
00000085   20.91007614   [13920] Loaded Config for Local Selection Path for App ID 413090: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\754616467\266097744495173226_legacy.bin
00000086   20.91067886   [13920] [413090]Non-Steam Controller Configs Enabled: 1
00000087   20.91893578   [13920] Loaded Config for Local Selection Path for App ID 413090: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\754616467\266097744495173226_legacy.bin
00000088   21.55488396   [13920] GameAction [AppID 0, ActionID 1] : LaunchApp changed task to RunningInstallScript with ""
00000089   21.55514336   [13920] GameAction [AppID 0, ActionID 1] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
00000090   21.55650711   [13920] GameAction [AppID 0, ActionID 1] : LaunchApp changed task to CreatingProcess with ""
00000091   21.55654335   [13920] GameAction [AppID 0, ActionID 1] : LaunchApp waiting for user response to CreatingProcess ""
00000092   21.55657768   [13920] GameAction [AppID 0, ActionID 1] : LaunchApp continues with user response "CreatingProcess"
00000093   21.55690002   [13920] Opted-in Controller Mask: 70
00000094   21.63076973   [13920] Game update: AppID 0 "Ephinea PSOBB", ProcID 13760, IP 0.0.0.0:0
00000095   22.02332306   [13920] IPC server is in my process - could/should be using an in process pipe
00000096   22.02700233   [13920] GameAction [AppID 0, ActionID 1] : LaunchApp changed task to Completed with ""
00000097   22.04226112   [13920] >>> Adding process 13760 for game ID 33554432
00000098   22.14051437   [13920] DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 1853 (1855 input number was)
00000099   22.25110626   [13920] HTTP Response for https://store.steampowered.com/api/featured/?cc=US&l=english: 200, 18472
00000100   22.28101158   [13920] DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 991 (1857 input number was)
00000101   22.36098480   [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\mainmenu_bg_2.png (dimensions 1920x1080, took 79 msec)
00000102   22.37811279   [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\systemmenu\capsule_glow.png (dimensions 1920x1080, took 49 msec)
00000103   22.42835236   [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\profile\activity_bg_wash.png (dimensions 1879x928, took 49 msec)
00000104   22.44248962   [13920] DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 952 (1099 input number was)
00000105   22.44528008   [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\profile\profile_bg_wash.png (dimensions 1879x928, took 65 msec)
00000106   22.46156502   [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\gamesbanner.png (dimensions 1280x288, took 45 msec)
00000107   22.47842979   [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\friends.png (dimensions 768x512, took 32 msec)
00000108   22.49414063   [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\overlay.png (dimensions 768x512, took 31 msec)
00000109   22.49425125   [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controllerbanner.png (dimensions 1280x512, took 31 msec)
00000110   22.52829170   [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\securitybanner.png (dimensions 1280x430, took 33 msec)
00000111   22.54520035   [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_overview.jpg (dimensions 1922x329, took 33 msec)
00000112   22.60898018   [13920] DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 1660 (1922 input number was)
00000113   22.61114311   [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_moystick.jpg (dimensions 1922x598, took 80 msec)
00000114   22.61369133   [13920] OnFocusWindowChanged to window type: k_nGameIDControllerConfigs_Desktop, AppID 413080
00000115   22.61394119   [13920] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000116   22.61725044   [13920] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000117   22.61739922   [13920] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000118   22.62820435   [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_mouseregions.jpg (dimensions 1922x598, took 81 msec)
00000119   22.62827492   [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_gyro_touchmenu.jpg (dimensions 1922x598, took 82 msec)
00000120   22.63032913   [13920] DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 770 (1719 input number was)
00000121   22.67855644   [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_personalize.jpg (dimensions 1922x598, took 66 msec)
00000122   22.69559860   [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_hometheater.jpg (dimensions 1922x598, took 66 msec)
00000123   22.72038651   [13920] DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 189 (862 input number was)
00000124   22.72804451   [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_shortcuts.jpg (dimensions 1922x598, took 98 msec)
00000125   22.76167297   [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\browser\browser_reticule_outer.png (dimensions 426x426, took 33 msec)
00000126   22.82826805   [13920] Slow image load - https://steamcdn-a.akamaihd.net/steam/apps/13230/header.jpg (dimensions 460x215, took 32 msec)
00000127   22.83099556   [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\background_alpha_mask.png (dimensions 1920x1080, took 35 msec)
00000128   22.84536934   [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\panel_background.png (dimensions 1920x1080, took 83 msec)
00000129   22.92774200   [13920] Slow image load - https://steamcdn-a.akamaihd.net/steam/apps/10500/header.jpg (dimensions 460x215, took 31 msec)
00000130   22.92784309   [13920] Slow image load - https://steamcdn-a.akamaihd.net/steam/apps/475150/header.jpg (dimensions 460x215, took 32 msec)
00000131   22.92790794   [13920] Slow image load - https://steamcdn-a.akamaihd.net/steam/apps/13210/header.jpg (dimensions 460x215, took 32 msec)
00000132   28.43720245   [13760]
00000133   28.43720245   [13760]  === Begin DirectDraw / Direct3D leak report ========
00000134   28.43720245   [13760]
00000135   28.43724823   [13760]
00000136   28.43724823   [13760]  === No leaked objects were found
00000137   28.43729591   [13760]
00000138   28.43729591   [13760]  === End DirectDraw / Direct3D leak report ========
00000139   28.43729591   [13760]
00000140   28.56545639   [13920] >>> Adding process 9508 for game ID 33554432
00000141   28.62959099   [13920] OnFocusWindowChanged to window type: k_nGameIDControllerConfigs_Desktop, AppID 413080
00000142   28.62967682   [13920] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000143   28.63173103   [13920] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000144   28.63190460   [13920] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000145   30.22309685   [9508] Direct3DCreate8 (SDKVersion = dc)
00000146   30.22332764   [9508] [dgVoodoo] INFO: Reading config from file C:\Users\wiseg\EphineaPSO\dgVoodoo.conf.
00000147   30.23152733   [9508] [dgVoodoo] INFO: INI file based version of config file is successfully read.
00000148   30.23319435   [9508] [dgVoodoo] INFO: D3D8 is successfully loaded: C:\Users\wiseg\EphineaPSO\d3d8.dll
00000149   30.23337364   [9508] [dgVoodoo] WARNING: Direct3DCreate8: Attempt to access Direct3D8 from DllMain. Application may need to be modified or patched to use with dgVoodoo.
00000150   30.23344994   [9508] [dgVoodoo] INFO: Reading config from file C:\Users\wiseg\EphineaPSO\dgVoodoo.conf.
00000151   30.23367691   [9508] [dgVoodoo] INFO: INI file based version of config file is successfully read.
00000152   30.35054398   [9508] [dgVoodoo] INFO: Direct3D8 (05153AC8) DirectDraw has been loaded: C:\Users\wiseg\EphineaPSO\DDRAW.DLL
00000153   30.46465302   [9508] [dgVoodoo] INFO: Direct3D8 (05153AC8) is created. Number of display outputs (on which devices can be created): 1
00000154   30.46468735   [9508] [dgVoodoo] INFO: Direct3D8 (05153AC8)     Device 0: Name: "AMD Radeon (TM) R9 M390X", Description: "\\.\DISPLAY1", Monitor rect: (0, 0, 3840, 2160), system primary monitor
00000155   30.46471596   [9508] [dgVoodoo] INFO: Direct3D8 (05153AC8) Virtual video card is 'dgVoodoo Virtual 3D Accelerated' with 64MB onboard memory.
00000156   30.46488380   [9508] Driver     :AMD Radeon (TM) R9 M390X
00000157   30.46492195   [9508]
00000158   30.46834946   [9508] Description:\\.\DISPLAY1
00000159   30.46838760   [9508]
00000160   30.47177315   [9508] VendorID   :00000000
00000161   30.47178841   [9508]
00000162   30.47513962   [9508] DeviceID   :00000000
00000163   30.47519684   [9508]
00000164   30.47862434   [9508] SubSysID   :00000000
00000165   30.47864342   [9508]
00000166   30.48253822   [9508] Revision   :00000000
00000167   30.48255348   [9508]
00000168   30.89110374   [8008] ADLDirty = true
00000169   30.97186470   [8008] ADLDirty = false
00000170   30.97246742   [2032] ************Executable file path is: '
00000171   30.97305870   [9508] [dgVoodoo] INFO: Direct3DDevice8 (05233A00)::Init: Implicit swapchain (051D4A80) is created. Its display mode is 1920x1080, 32 bit, 59 Hz, fullscreen mode
00000172   30.97336960   [2032] \Device\HarddiskVolume5\Windows\System32\svchost.exe
00000173   30.97377014   [2032]
00000174   30.97436142   [2032] PID=2032
00000175   30.97495079   [2032]
00000176   30.97586823   [2032] ************Trace & dump config file path is: '
00000177   30.97644234   [2032] C:\Users\wiseg\AppData\Local\AMDh264Encoder.cfg
00000178   30.97676468   [2032] '************
00000179   30.97795868   [9508] [dgVoodoo] INFO: Direct3DDevice8 (05233A00)::Init: Requested output API type is "Best Available", DDI type is D3D 10.1, hardware accelerated
00000180   30.97815323   [9508] [dgVoodoo] INFO: Direct3DDevice8 (05233A00)::Init: Device is successfully initialized on output device index: 0. Maximum video memory: 65536 kBs, currently available video memory: 60416 kBs
00000181   30.97831726   [9508] [dgVoodoo] INFO: Direct3DDevice8 (05233A00): External shader compiler is successfully found: C:\Users\wiseg\EphineaPSO\D3DCompiler_47.dll
00000182   30.97847939   [9508] [dgVoodoo] INFO: Direct3D8 (05153AC8)::CreateDevice: Direct3DDevice8 (05233A00) is created on output device 0, device type: D3DDEVTYPE_HAL.
00000183   30.97860146   [9508] [dgVoodoo] INFO: Direct3DDevice8 (05233A00) is released.
00000184   30.97945023   [9508] [dgVoodoo] INFO: Direct3DSwapchain8 (051D4A80) is released.
00000185   31.62531281   [8008] ADLDirty = true
00000186   31.62774467   [8008] ADLDirty = false
00000187   31.79450607   [9508] [dgVoodoo] INFO: Direct3DDevice8 (0B7A09D0)::Init: Implicit swapchain (052954D0) is created. Its display mode is 1920x1080, 32 bit, 59 Hz, fullscreen mode
00000188   31.79640388   [9508] [dgVoodoo] INFO: Direct3DDevice8 (0B7A09D0)::Init: Requested output API type is "Best Available", DDI type is D3D 10.1, hardware accelerated
00000189   31.79644394   [9508] [dgVoodoo] INFO: Direct3DDevice8 (0B7A09D0)::Init: Device is successfully initialized on output device index: 0. Maximum video memory: 65536 kBs, currently available video memory: 60416 kBs
00000190   31.79648972   [9508] [dgVoodoo] INFO: Direct3DDevice8 (0B7A09D0): External shader compiler is successfully found: C:\Users\wiseg\EphineaPSO\D3DCompiler_47.dll
00000191   31.79656410   [9508] [dgVoodoo] INFO: Direct3D8 (05153AC8)::CreateDevice: Direct3DDevice8 (0B7A09D0) is created on output device 0, device type: D3DDEVTYPE_HAL.
00000192   31.79661179   [9508] DEVICE     :HAL-HARD
00000193   31.79664040   [9508]
00000194   31.81316185   [8008] ADLDirty = true
00000195   31.82819557   [8008] ADLDirty = false
00000196   31.85976028   [13920] OnFocusWindowChanged to window type: k_nGameIDControllerConfigs_Desktop, AppID 413080
00000197   31.85985565   [13920] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000198   31.86134720   [13920] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000199   31.86145020   [13920] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000200   31.99248886   [9508] [dgVoodoo] INFO: Direct3DDevice8 (0B7A09D0)::CreateTexture: Direct3DTexture8 (0B742CA0, IDirect3DTexture8 = 0B742D64) is created.
00000201   31.99451828   [9508] [dgVoodoo] INFO: Direct3DDevice8 (0B7A09D0)::CreateTexture: Direct3DTexture8 (052800E8, IDirect3DTexture8 = 052801AC) is created.
00000202   31.99512672   [9508] [dgVoodoo] INFO: Direct3DDevice8 (0B7A09D0)::CreateTexture: Direct3DTexture8 (0B809688, IDirect3DTexture8 = 0B80974C) is created.
00000203   32.05486298   [9508] [dgVoodoo] INFO: Direct3DDevice8 (0B7A09D0)::CreateTexture: Direct3DTexture8 (0B8152F8, IDirect3DTexture8 = 0B8153BC) is created.
00000204   32.05563354   [9508] [dgVoodoo] INFO: Direct3DDevice8 (0B7A09D0)::CreateTexture: Direct3DTexture8 (0B84D938, IDirect3DTexture8 = 0B84D9FC) is created.
00000205   32.05595016   [9508] [dgVoodoo] INFO: Direct3DDevice8 (0B7A09D0)::CreateTexture: Direct3DTexture8 (0B84DCE8, IDirect3DTexture8 = 0B84DDAC) is created.
00000206   32.12069321   [6796] Suspending
00000207   32.16239166   [7324] Failed to log to file
00000208   32.16948318   [7324] Failed to log to file
00000209   32.18873215   [7324] Failed to file tracing file
00000210   32.39751053   [13920] Found adapter AMD Radeon (TM) R9 M390X
00000211   32.39756775   [13920] Found adapter Intel(R) HD Graphics 530
00000212   32.39762115   [13920] Found adapter Microsoft Basic Render Driver
00000213   32.43791962   [13920] !! Using adapter AMD Radeon (TM) R9 M390X, GPU Mem: 3.22 GB, Sys Mem: 0 bytes, Shared Mem: 1.07 GB
00000214   32.45652771   [13920] Created ID3DX11Effect for orthographic2d.fxo from memory ok!
00000215   32.46441650   [13920] Found adapter AMD Radeon (TM) R9 M390X
00000216   32.46450806   [13920] Found adapter Intel(R) HD Graphics 530
00000217   32.46453857   [13920] Found adapter Microsoft Basic Render Driver
00000218   32.50388336   [13920] !! Using adapter AMD Radeon (TM) R9 M390X, GPU Mem: 3.22 GB, Sys Mem: 0 bytes, Shared Mem: 1.07 GB
00000219   32.51204300   [13920] Created ID3DX11Effect for orthographic2d.fxo from memory ok!
00000220   32.72405624   [13920] Found adapter AMD Radeon (TM) R9 M390X
00000221   32.72412491   [13920] Found adapter Intel(R) HD Graphics 530
00000222   32.72420120   [13920] Found adapter Microsoft Basic Render Driver
00000223   32.75801468   [13920] !! Using adapter AMD Radeon (TM) R9 M390X, GPU Mem: 3.22 GB, Sys Mem: 0 bytes, Shared Mem: 1.07 GB
00000224   32.76571655   [13920] Created ID3DX11Effect for orthographic2d.fxo from memory ok!
00000225   32.78184509   [13920] DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 1100 (1102 input number was)
00000226   32.81112671   [13920] !! Controller 0 attributes:
00000227   32.81112671   [13920]   Type: 2
00000228   32.81112671   [13920]   ProductID: 4354
00000229   32.81112671   [13920]   Serial: FC619203BC
00000230   32.81112671   [13920]   Capabilities: 00013ff7
00000231   32.81112671   [13920]   Firmware Version: 0
00000232   32.81112671   [13920]   Firmware Build Time: 1527718333 (Wed, 30 May 2018 22:12:13 GMT)
00000233   32.81112671   [13920]   Bootloader Build Time: 1439863405 (Tue, 18 Aug 2015 02:03:25 GMT)
00000234   32.81204605   [13920] OnFocusWindowChanged to game window type: AppID 2147483649, ephinea psobb
00000235   32.81216812   [13920] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000236   32.81546021   [13920] Loaded Config for Local Selection Path for App ID -2147483647: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\1459950924\957464882662497763_legacy.bin
00000237   32.81565094   [13920] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000238   32.86642075   [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\profile\activity_bg_wash.png (dimensions 1879x928, took 44 msec)
00000239   32.90610504   [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\profile\profile_bg_wash.png (dimensions 1879x928, took 84 msec)
00000240   32.92782974   [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\mainmenu_bg_2.png (dimensions 1920x1080, took 110 msec)
00000241   32.95402908   [13232] [000:00:00:000][P][GameBarUpdateTask][0x000035a0] GameBarUpdateTask::RegisterTasks has been invoked.
00000242   32.97124100   [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\overlay\overlay_bg_wash.png (dimensions 1879x928, took 63 msec)
00000243   32.97647095   [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\panel_background.png (dimensions 1920x1080, took 72 msec)
00000244   32.98349762   [13232] [000:00:00:029][P][BackgroundTaskManager][0x000035a0] BroadcastBackgroundTask: Broadcast background task already registered.
00000245   32.98380661   [13232] [000:00:00:029][P][BackgroundTaskManager][0x000035a0] BackgroundTaskManager::RegisterBroadcastBackgroundTask. Unregistering the existing task that was found.
00000246   32.98583984   [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\background_alpha_mask.png (dimensions 1920x1080, took 32 msec)
00000247   32.98775482   [13232] [000:00:00:033][P][BackgroundTaskManager][0x000035a0] BackgroundTaskManager. IsBroadcastingAllowed: true
00000248   32.98781586   [13232] [000:00:00:033][P][BackgroundTaskManager][0x000035a0] BackgroundTaskManager::RegisterBroadcastBackgroundTask.  Registering broadcast task now.
00000249   33.03797531   [13232] [000:00:00:083][P][BackgroundTaskManager][0x000035a0] BroadcastBackgroundTask: Broadcast background task successfully registered.
00000250   33.38160706   [13920] HTTP Response for https://steamcommunity-a.akamaihd.net/news/newsforapp/v0001/?appid=2147483649&count=5&maxlength=500&format=json: 403, 0
00000251   33.38167572   [13920] HTTP Response failed https://steamcommunity-a.akamaihd.net/news/newsforapp/v0001/?appid=2147483649&count=5&maxlength=500&format=json
00000252   35.99900818   [13920] Warning: The game hasn't rendered a frame from us in over 10 seconds
00000253   48.82380676   [13920] Warning: The game hasn't rendered a frame from us in over 10 seconds
the last thing I saw was a black screen I could not switch from, with the dgVoodoo 2 logo in the lower right hand corner, forcing me to reboot my machine. I did so about 10-20 seconds after the black screen appeared, which appeared when I launched PSOBB in classic fullscreen mode.
by the way PSOBB is a free game to download on the Ephinea server. so try it yourself. do not post here trying to offer tech support unless you have the game installed, try various resolutions and settings with WINDOW MODE DISABLED and CLASSIC FULLSCREEN ENABLED in PSOBB.
todd
Postby todd » 2018-8-13 @ 01:45
also using the DEFAULT dgVoodoo 2 settings, PSOBB refuses to start up at all when you use the NATIVE RESOLUTION OF 4K or qHD. I am seeing an error about being out of video memory. this must be because 4K is too much for the adapters default of 64MB:
Code: Select all
[\\DESKTOP-HKAVRA7]
00000001   0.00000000   [11928] RecursiveDirectoryCreate( C:\Users\wiseg\AppData\Local\CEF\User Data directory exists )
00000002   0.04773860   [12624] IPC server is in my process - could/should be using an in process pipe
00000003   0.08995420   [11928] [0812/184022.600:INFO:crash_reporting.cc(215)] Crash reporting enabled for process: browser
00000004   0.10234600   [12624] CApplicationManagerPopulateThread took 2 milliseconds to initialize (will have waited on CAppInfoCacheReadFromDiskThread)
00000005   0.14196239   [11928] [0812/184022.647:ERROR:gpu_process_transport_factory.cc(1029)] Lost UI shared context.
00000006   0.15480261   [12624] CAppInfoCacheReadFromDiskThread took 68 milliseconds to initialize
00000007   0.18294939   [12624] CHTTPRequestCache took 82 milliseconds to initialize
00000008   1.12478936   [12624] Local Device Found
00000009   1.12478936   [12624]   type: 28de 1102
00000010   1.12478936   [12624]   path: \\?\hid#vid_28de&pid_1102&mi_02#7&3abbaa23&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
00000011   1.12478936   [12624]   serial_number:  - 0
00000012   1.12486351   [12624]   Manufacturer: Valve Software
00000013   1.12488723   [12624]   Product:      Valve
00000014   1.12493944   [12624]   Release:      100
00000015   1.12503159   [12624]   Interface:    2
00000016   1.12503159   [12624]
00000017   1.12514555   [12624] Controller uses V1 HID protocol
00000018   1.12523603   [12624] !! Steam controller device opened for index 0.
00000019   1.12552440   [12624] Steam Controller reserving XInput slot 0
00000020   1.18860137   [12624] Controller 0 connected, configuring it now...
00000021   1.63487911   [12624]   Chip ID: 308002186794abaec6a43255401900f5
00000022   1.68409884   [12624] BYieldingQueryAccountsRegisteredToController
00000023   1.75106680   [12624] !! Controller 0 attributes:
00000024   1.75106680   [12624]   Type: 2
00000025   1.75106680   [12624]   ProductID: 4354
00000026   1.75106680   [12624]   Serial: FC619203BC
00000027   1.75106680   [12624]   Capabilities: 00013ff7
00000028   1.75106680   [12624]   Firmware Version: 0
00000029   1.75106680   [12624]   Firmware Build Time: 1527718333 (Wed, 30 May 2018 22:12:13 GMT)
00000030   1.75106680   [12624]   Bootloader Build Time: 1439863405 (Tue, 18 Aug 2015 02:03:25 GMT)
00000031   1.75332439   [12624] Could not load local selection (), local override (C:\Program Files (x86)\Steam/controller_config/bigpicture.vdf), or user path (C:\Program Files (x86)\Steam/appcache//controller_configs/bigpicture.vdf), checking last resort path: C:\Program Files (x86)\Steam/controller_base/bigpicture.vdf
00000032   1.76206636   [12624] Loaded Config for Last Resort Path for App ID 413090: C:\Program Files (x86)\Steam/controller_base/bigpicture.vdf
00000033   1.76927841   [12624] Could not load local selection (), local override (C:\Program Files (x86)\Steam/controller_config/bigpicture.vdf), or user path (C:\Program Files (x86)\Steam/appcache//controller_configs/bigpicture.vdf), checking last resort path: C:\Program Files (x86)\Steam/controller_base/bigpicture.vdf
00000034   1.77227819   [12624] Loaded Config for Last Resort Path for App ID 413090: C:\Program Files (x86)\Steam/controller_base/bigpicture.vdf
00000035   1.77403641   [12624] Could not load local selection (), local override (C:\Program Files (x86)\Steam/controller_config/steamdesktop.vdf), or user path (C:\Program Files (x86)\Steam/appcache//controller_configs/steamdesktop.vdf), checking last resort path: C:\Program Files (x86)\Steam/controller_base/steamdesktop.vdf
00000036   1.77921963   [12624] Loaded Config for Last Resort Path for App ID 413080: C:\Program Files (x86)\Steam/controller_base/steamdesktop.vdf
00000037   1.78031802   [12624] Controller 0 mapping uses xinput : false
00000038   6.73048162   [11928] Found unsupported CDM version 1.4.9.1088, using last known good version 1.4.8.1008
00000039   11.64793587   [12624] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000040   11.64853668   [12624] [413080]Non-Steam Controller Configs Enabled: 1
00000041   11.65106487   [12624] local (potentially out of sync) copy of roaming config loaded - 3693 bytes.
00000042   12.37659740   [12624] roaming config store loaded successfully - 3693 bytes.
00000043   12.37692642   [12624] migrating temporary roaming config store
00000044   12.57612801   [12412] [0812/184035.086:INFO:crash_reporting.cc(215)] Crash reporting enabled for process: gpu-process
00000045   12.59643173   [12416] [0812/184035.106:INFO:crash_reporting.cc(215)] Crash reporting enabled for process: renderer
00000046   13.06160355   [12624] Failed to init SteamVR because it isn't installed
00000047   13.13765240   [12624] ExecCommandLine: ""C:\Program Files (x86)\Steam\Steam.exe""
00000048   14.01604176   [12624] IPC server is in my process - could/should be using an in process pipe
00000049   14.02343655   [12624] System startup time: 14.15 seconds
00000050   14.02413082   [12624] !! Controller 0 attributes:
00000051   14.02413082   [12624]   Type: 2
00000052   14.02413082   [12624]   ProductID: 4354
00000053   14.02413082   [12624]   Serial: FC619203BC
00000054   14.02413082   [12624]   Capabilities: 00013ff7
00000055   14.02413082   [12624]   Firmware Version: 0
00000056   14.02413082   [12624]   Firmware Build Time: 1527718333 (Wed, 30 May 2018 22:12:13 GMT)
00000057   14.02413082   [12624]   Bootloader Build Time: 1439863405 (Tue, 18 Aug 2015 02:03:25 GMT)
00000058   14.02482224   [12624] Fetching Config Sets 0
00000059   14.02494240   [12624] CClientJobFetchPersonalizationFileID
00000060   14.02843666   [12624] Blocking global navigation to: data:text/html,%3Cbody%3E%3C%2Fbody%3E
00000061   14.10999012   [12892] [0812/184036.619:INFO:crash_reporting.cc(215)] Crash reporting enabled for process: renderer
00000062   14.24090385   [12624] Set Account Config Sets 0 1 1
00000063   14.46912193   [12624] OnFocusWindowChanged to window type: k_nGameIDControllerConfigs_Desktop, AppID 413080
00000064   14.47226429   [12624] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000065   14.47264290   [12624] [413080]Non-Steam Controller Configs Enabled: 1
00000066   14.47340679   [12624] OnFocusWindowChanged to window type: k_nGameIDControllerConfigs_Desktop, AppID 413080
00000067   14.47504807   [12624] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000068   14.54109287   [12624] CAPIJobRequestUserStats - Server response failed 2
00000069   15.38687229   [12624] [413080-650764041]: Failed to start tracking playtime
00000070   15.53605461   [12624] [413080-650764041]: Failed to start tracking playtime
00000071   17.05288696   [12624] Loaded Config for Local Selection Path for App ID -2147483647: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\1459950924\957464882662497763_legacy.bin
00000072   17.05325508   [12624] [2147483649]Non-Steam Controller Configs Enabled: 1
00000073   17.10480690   [12624] Initializing font file enumerator: C:\Program Files (x86)\Steam\tenfoot\resource\fonts\
00000074   17.10491753   [12624] CreateCustomFontfileReference succeeded
00000075   17.11126709   [12624] CreateCustomFontfileReference succeeded
00000076   17.35015106   [12624] No cached sticky mapping in GetActionSetHandle. Native Steam Controller support won't work.
00000077   17.43824768   [12624] Found adapter AMD Radeon (TM) R9 M390X
00000078   17.43832016   [12624] Found adapter Intel(R) HD Graphics 530
00000079   17.43837357   [12624] Found adapter Microsoft Basic Render Driver
00000080   17.46815109   [12624] !! Using adapter AMD Radeon (TM) R9 M390X, GPU Mem: 3.22 GB, Sys Mem: 0 bytes, Shared Mem: 1.07 GB
00000081   17.49493408   [12624] Created ID3DX11Effect for orthographic2d.fxo from memory ok!
00000082   17.52921867   [12624] defaultfocus=DummyInput not found within layout file for welcome_nocontroller
00000083   17.52933693   [12624] defaultfocus=DummyInput not found within layout file for welcome_nocontroller
00000084   17.53961372   [12624] Loaded Config for Local Selection Path for App ID 413090: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\754616467\266097744495173226_legacy.bin
00000085   17.54001999   [12624] [413090]Non-Steam Controller Configs Enabled: 1
00000086   17.54772758   [12624] Loaded Config for Local Selection Path for App ID 413090: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\754616467\266097744495173226_legacy.bin
00000087   18.17680550   [12624] GameAction [AppID 0, ActionID 1] : LaunchApp changed task to RunningInstallScript with ""
00000088   18.17709351   [12624] GameAction [AppID 0, ActionID 1] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
00000089   18.17924500   [12624] GameAction [AppID 0, ActionID 1] : LaunchApp changed task to CreatingProcess with ""
00000090   18.17930984   [12624] GameAction [AppID 0, ActionID 1] : LaunchApp waiting for user response to CreatingProcess ""
00000091   18.17937279   [12624] GameAction [AppID 0, ActionID 1] : LaunchApp continues with user response "CreatingProcess"
00000092   18.17959976   [12624] Opted-in Controller Mask: 70
00000093   18.25487518   [12624] Game update: AppID 0 "Ephinea PSOBB", ProcID 12968, IP 0.0.0.0:0
00000094   19.01034927   [12624] IPC server is in my process - could/should be using an in process pipe
00000095   19.01394844   [12624] GameAction [AppID 0, ActionID 1] : LaunchApp changed task to Completed with ""
00000096   19.02272034   [12624] >>> Adding process 12968 for game ID 33554432
00000097   19.13959122   [12624] DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 1853 (1855 input number was)
00000098   19.24167633   [12624] HTTP Response for https://store.steampowered.com/api/featured/?cc=US&l=english: 200, 18472
00000099   19.25896835   [12624] OnFocusWindowChanged to window type: k_nGameIDControllerConfigs_Desktop, AppID 413080
00000100   19.25908470   [12624] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000101   19.26090813   [12624] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000102   19.26109695   [12624] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000103   19.27746964   [12624] DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 1433 (1857 input number was)
00000104   19.34740257   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\systemmenu\capsule_glow.png (dimensions 1920x1080, took 32 msec)
00000105   19.37967110   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\systemmenu\icon_community.png (dimensions 200x200, took 31 msec)
00000106   19.37978745   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\mainmenu_bg_2.png (dimensions 1920x1080, took 97 msec)
00000107   19.38005829   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\systemmenu\icon_friends.png (dimensions 200x200, took 30 msec)
00000108   19.41271591   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\library\icon_search.png (dimensions 64x64, took 31 msec)
00000109   19.43171120   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\profile\profile_bg_wash.png (dimensions 1879x928, took 50 msec)
00000110   19.43181038   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\profile\activity_bg_wash.png (dimensions 1879x928, took 51 msec)
00000111   19.46904564   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\gamesbanner.png (dimensions 1280x288, took 50 msec)
00000112   19.47827148   [12624] DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 1617 (2469 input number was)
00000113   19.48179054   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\friends.png (dimensions 768x512, took 47 msec)
00000114   19.49871063   [12624] DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 978 (1700 input number was)
00000115   19.51461601   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controllerbanner.png (dimensions 1280x512, took 32 msec)
00000116   19.51620293   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\overlay.png (dimensions 768x512, took 34 msec)
00000117   19.54335594   [12624] DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 536 (1058 input number was)
00000118   19.54781342   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\securitybanner.png (dimensions 1280x430, took 32 msec)
00000119   19.58134270   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_overview.jpg (dimensions 1922x329, took 49 msec)
00000120   19.61446571   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_moystick.jpg (dimensions 1922x598, took 64 msec)
00000121   19.64783287   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_gyro_touchmenu.jpg (dimensions 1922x598, took 81 msec)
00000122   19.64797020   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_mouseregions.jpg (dimensions 1922x598, took 65 msec)
00000123   19.68060684   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_personalize.jpg (dimensions 1922x598, took 65 msec)
00000124   19.71451187   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_shortcuts.jpg (dimensions 1922x598, took 65 msec)
00000125   19.71461678   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_hometheater.jpg (dimensions 1922x598, took 65 msec)
00000126   19.74780464   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\browser\browser_reticule_outer.png (dimensions 426x426, took 32 msec)
00000127   19.74790192   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\browser\favorite_added.png (dimensions 512x512, took 32 msec)
00000128   19.83151436   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\panel_background.png (dimensions 1920x1080, took 65 msec)
00000129   19.84789848   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\background_alpha_mask.png (dimensions 1920x1080, took 49 msec)
00000130   19.89805603   [12624] Slow image load - https://steamcdn-a.akamaihd.net/steam/apps/212480/header.jpg (dimensions 460x215, took 31 msec)
00000131   19.89810181   [12624] Slow image load - https://steamcdn-a.akamaihd.net/steam/apps/71250/header.jpg (dimensions 460x215, took 31 msec)
00000132   37.16056061   [12968]
00000133   37.16056061   [12968]  === Begin DirectDraw / Direct3D leak report ========
00000134   37.16056061   [12968]
00000135   37.16060257   [12968]
00000136   37.16060257   [12968]  === No leaked objects were found
00000137   37.16063690   [12968]
00000138   37.16063690   [12968]  === End DirectDraw / Direct3D leak report ========
00000139   37.16063690   [12968]
00000140   37.33926773   [12624] >>> Adding process 1884 for game ID 33554432
00000141   37.40284348   [12624] OnFocusWindowChanged to window type: k_nGameIDControllerConfigs_Desktop, AppID 413080
00000142   37.40302277   [12624] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000143   37.40530014   [12624] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000144   37.40536499   [12624] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000145   40.44532013   [1884] Direct3DCreate8 (SDKVersion = dc)
00000146   40.44569778   [1884] [dgVoodoo] INFO: Reading config from file C:\Users\wiseg\EphineaPSO\dgVoodoo.conf.
00000147   40.45311737   [1884] [dgVoodoo] INFO: INI file based version of config file is successfully read.
00000148   40.45486069   [1884] [dgVoodoo] INFO: D3D8 is successfully loaded: C:\Users\wiseg\EphineaPSO\d3d8.dll
00000149   40.45495605   [1884] [dgVoodoo] WARNING: Direct3DCreate8: Attempt to access Direct3D8 from DllMain. Application may need to be modified or patched to use with dgVoodoo.
00000150   40.45502853   [1884] [dgVoodoo] INFO: Reading config from file C:\Users\wiseg\EphineaPSO\dgVoodoo.conf.
00000151   40.45522308   [1884] [dgVoodoo] INFO: INI file based version of config file is successfully read.
00000152   40.55678940   [1884] [dgVoodoo] INFO: Direct3D8 (0599EFD8) DirectDraw has been loaded: C:\Users\wiseg\EphineaPSO\DDRAW.DLL
00000153   40.68557358   [1884] [dgVoodoo] INFO: Direct3D8 (0599EFD8) is created. Number of display outputs (on which devices can be created): 1
00000154   40.68573761   [1884] [dgVoodoo] INFO: Direct3D8 (0599EFD8)     Device 0: Name: "AMD Radeon (TM) R9 M390X", Description: "\\.\DISPLAY1", Monitor rect: (0, 0, 3840, 2160), system primary monitor
00000155   40.68575287   [1884] [dgVoodoo] INFO: Direct3D8 (0599EFD8) Virtual video card is 'dgVoodoo Virtual 3D Accelerated' with 64MB onboard memory.
00000156   40.68590164   [1884] Driver     :AMD Radeon (TM) R9 M390X
00000157   40.68604279   [1884]
00000158   40.68931198   [1884] Description:\\.\DISPLAY1
00000159   40.68944168   [1884]
00000160   40.69241714   [1884] VendorID   :00000000
00000161   40.69253922   [1884]
00000162   40.69543839   [1884] DeviceID   :00000000
00000163   40.69556427   [1884]
00000164   40.69824600   [1884] SubSysID   :00000000
00000165   40.69836807   [1884]
00000166   40.70102310   [1884] Revision   :00000000
00000167   40.70108032   [1884]
00000168   40.71638870   [1884] [dgVoodoo] ERROR: Direct3DDevice8 (05A7FC80)::Init/CreateAdditionalSwapChain: Out of videomemory, cannot create swapchain. Required bytes: 99532800, remained bytes: 61865984.
00000169   40.71645355   [1884] [dgVoodoo] ERROR: Direct3DDevice8 (05A7FC80)::Init: Cannot create device implicit swapchain.
00000170   40.71655273   [1884] [dgVoodoo] ERROR: Direct3D8 (0599EFD8)::CreateDevice: Initializing Direct3DDevice8 (05A7FC80) failed.
00000171   40.71681213   [1884] [dgVoodoo] ERROR: Direct3DDevice8 (0AFB2008)::Init/CreateAdditionalSwapChain: Out of videomemory, cannot create swapchain. Required bytes: 99532800, remained bytes: 61865984.
00000172   40.71690369   [1884] [dgVoodoo] ERROR: Direct3DDevice8 (0AFB2008)::Init: Cannot create device implicit swapchain.
00000173   40.71693420   [1884] [dgVoodoo] ERROR: Direct3D8 (0599EFD8)::CreateDevice: Initializing Direct3DDevice8 (0AFB2008) failed.
00000174   40.71727371   [1884] [dgVoodoo] ERROR: Direct3DDevice8 (0AFB2008)::Init/CreateAdditionalSwapChain: Out of videomemory, cannot create swapchain. Required bytes: 99532800, remained bytes: 61865984.
00000175   40.71736908   [1884] [dgVoodoo] ERROR: Direct3DDevice8 (0AFB2008)::Init: Cannot create device implicit swapchain.
00000176   40.71742630   [1884] [dgVoodoo] ERROR: Direct3D8 (0599EFD8)::CreateDevice: Initializing Direct3DDevice8 (0AFB2008) failed.
00000177   40.71802521   [1884] [dgVoodoo] ERROR: Direct3DDevice8 (0AFB2008)::Init/CreateAdditionalSwapChain: Out of videomemory, cannot create swapchain. Required bytes: 82944000, remained bytes: 61865984.
00000178   40.71805191   [1884] [dgVoodoo] ERROR: Direct3DDevice8 (0AFB2008)::Init: Cannot create device implicit swapchain.
00000179   40.71813583   [1884] [dgVoodoo] ERROR: Direct3D8 (0599EFD8)::CreateDevice: Initializing Direct3DDevice8 (0AFB2008) failed.
00000180   40.71837234   [1884] [dgVoodoo] ERROR: Direct3DDevice8 (0AFB2008)::Init/CreateAdditionalSwapChain: Out of videomemory, cannot create swapchain. Required bytes: 82944000, remained bytes: 61865984.
00000181   40.71849060   [1884] [dgVoodoo] ERROR: Direct3DDevice8 (0AFB2008)::Init: Cannot create device implicit swapchain.
00000182   40.71855927   [1884] [dgVoodoo] ERROR: Direct3D8 (0599EFD8)::CreateDevice: Initializing Direct3DDevice8 (0AFB2008) failed.
00000183   40.71881866   [1884] [dgVoodoo] ERROR: Direct3DDevice8 (0AFB2008)::Init/CreateAdditionalSwapChain: Out of videomemory, cannot create swapchain. Required bytes: 82944000, remained bytes: 61865984.
00000184   40.71884155   [1884] [dgVoodoo] ERROR: Direct3DDevice8 (0AFB2008)::Init: Cannot create device implicit swapchain.
00000185   40.71891022   [1884] [dgVoodoo] ERROR: Direct3D8 (0599EFD8)::CreateDevice: Initializing Direct3DDevice8 (0AFB2008) failed.
00000186   40.71893311   [1884] Fail    Direct3DCreateDevice
00000187   40.71895218   [1884]
00000188   40.72835922   [1884] [dgVoodoo] WARNING: Direct3DCreate8: Attempt to access Direct3D8 from DllMain. Application may need to be modified or patched to use with dgVoodoo.
00000189   40.73173904   [1884] [dgVoodoo] INFO: Direct3D8 (059DDE98) is created. Number of display outputs (on which devices can be created): 1
00000190   40.73186874   [1884] [dgVoodoo] INFO: Direct3D8 (059DDE98)     Device 0: Name: "AMD Radeon (TM) R9 M390X", Description: "\\.\DISPLAY1", Monitor rect: (0, 0, 3840, 2160), system primary monitor
00000191   40.73211670   [1884] [dgVoodoo] INFO: Direct3D8 (059DDE98) Virtual video card is 'dgVoodoo Virtual 3D Accelerated' with 64MB onboard memory.
00000192   40.73261642   [1884] Driver     :AMD Radeon (TM) R9 M390X
00000193   40.73263550   [1884]
00000194   40.73577881   [1884] Description:\\.\DISPLAY1
00000195   40.73589706   [1884]
00000196   40.73875809   [1884] VendorID   :00000000
00000197   40.73888779   [1884]
00000198   40.74181747   [1884] DeviceID   :00000000
00000199   40.74192810   [1884]
00000200   40.74475861   [1884] SubSysID   :00000000
00000201   40.74488831   [1884]
00000202   40.74781418   [1884] Revision   :00000000
00000203   40.74792480   [1884]
00000204   40.76404190   [1884]
00000205   40.76404190   [1884]  === Begin DirectDraw / Direct3D leak report ========
00000206   40.76404190   [1884]
00000207   40.76455307   [1884]
00000208   40.76455307   [1884]  === No leaked objects were found
00000209   40.76474762   [1884]
00000210   40.76474762   [1884]  === End DirectDraw / Direct3D leak report ========
00000211   40.76474762   [1884]
00000212   40.89038086   [1884] [dgVoodoo] WARNING: Leaked D3D8 objects detected at unloading D3D8 (probably process exit)!
00000213   43.12639999   [12624] Game removed: AppID 0 "Ephinea PSOBB", ProcID 12968
00000214   43.17207718   [12624] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000215   43.25959015   [12624] saving roaming config store to 'sharedconfig.vdf'
00000216   43.28545761   [12624] roaming config store 2 saved successfully
00000217   43.28706360   [12624] **** Panel FavoritePages has fill-parent-flow for height, but isn't in a flowing down or up layout
00000218   44.74097443   [12624] Loaded Config for Local Selection Path for App ID -2147483647: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\1459950924\957464882662497763_legacy.bin
00000219   44.78536987   [12624] Initializing font file enumerator: C:\Program Files (x86)\Steam\tenfoot\resource\fonts\
00000220   44.78544998   [12624] CreateCustomFontfileReference succeeded
00000221   44.78570175   [12624] CreateCustomFontfileReference succeeded
00000222   44.95258331   [12624] Warning: DirectSound playback reset due to non-moving playback cursor (buggy sound driver) time: 27693 play: 0 write: 0.
00000223   45.00438309   [12624] Found adapter AMD Radeon (TM) R9 M390X
00000224   45.00447464   [12624] Found adapter Intel(R) HD Graphics 530
00000225   45.00452042   [12624] Found adapter Microsoft Basic Render Driver
00000226   45.03282928   [12624] !! Using adapter AMD Radeon (TM) R9 M390X, GPU Mem: 3.22 GB, Sys Mem: 0 bytes, Shared Mem: 1.07 GB
00000227   45.04304504   [12624] Created ID3DX11Effect for orthographic2d.fxo from memory ok!
00000228   45.05223846   [12624] defaultfocus=DummyInput not found within layout file for welcome_nocontroller
00000229   45.05241013   [12624] defaultfocus=DummyInput not found within layout file for welcome_nocontroller
00000230   45.05720139   [12624] Loaded Config for Local Selection Path for App ID 413090: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\754616467\266097744495173226_legacy.bin
00000231   45.06124115   [12624] Loaded Config for Local Selection Path for App ID 413090: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\754616467\266097744495173226_legacy.bin
00000232   45.19448471   [12624] GameAction [AppID 0, ActionID 2] : LaunchApp changed task to RunningInstallScript with ""
00000233   45.19481277   [12624] GameAction [AppID 0, ActionID 2] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
00000234   45.19810486   [12624] GameAction [AppID 0, ActionID 2] : LaunchApp changed task to CreatingProcess with ""
00000235   45.19814682   [12624] GameAction [AppID 0, ActionID 2] : LaunchApp waiting for user response to CreatingProcess ""
00000236   45.19817352   [12624] GameAction [AppID 0, ActionID 2] : LaunchApp continues with user response "CreatingProcess"
00000237   45.19844818   [12624] Opted-in Controller Mask: 70
00000238   45.20829010   [12624] Game update: AppID 0 "Ephinea PSOBB", ProcID 8928, IP 0.0.0.0:0
00000239   45.21203995   [12624] GameAction [AppID 0, ActionID 2] : LaunchApp changed task to Completed with ""
00000240   45.21303177   [12624] >>> Adding process 8928 for game ID 33554432
00000241   45.33587265   [12624] DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 1853 (1855 input number was)
00000242   45.45837784   [12624] DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 1432 (1856 input number was)
00000243   45.49997330   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\systemmenu\capsule_glow.png (dimensions 1920x1080, took 45 msec)
00000244   45.51745605   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\mainmenu_bg_2.png (dimensions 1920x1080, took 66 msec)
00000245   45.56654358   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\profile\activity_bg_wash.png (dimensions 1879x928, took 49 msec)
00000246   45.58340073   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\profile\profile_bg_wash.png (dimensions 1879x928, took 66 msec)
00000247   45.58633423   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\gamesbanner.png (dimensions 1280x288, took 36 msec)
00000248   45.59316254   [12624] DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 941 (1530 input number was)
00000249   45.61946106   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\friends.png (dimensions 768x512, took 36 msec)
00000250   45.63679504   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controllerbanner.png (dimensions 1280x512, took 35 msec)
00000251   45.63707352   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\overlay.png (dimensions 768x512, took 36 msec)
00000252   45.68379211   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_overview.jpg (dimensions 1922x329, took 33 msec)
00000253   45.74924850   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_moystick.jpg (dimensions 1922x598, took 65 msec)
00000254   45.76589584   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_gyro_touchmenu.jpg (dimensions 1922x598, took 81 msec)
00000255   45.76611328   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_mouseregions.jpg (dimensions 1922x598, took 65 msec)
00000256   45.81578064   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_personalize.jpg (dimensions 1922x598, took 64 msec)
00000257   45.82481766   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_shortcuts.jpg (dimensions 1922x598, took 57 msec)
00000258   45.83283997   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_hometheater.jpg (dimensions 1922x598, took 65 msec)
00000259   45.84826279   [12624] HTTP Response for https://store.steampowered.com/api/featured/?cc=US&l=english: 200, 18472
00000260   45.91406631   [12624] Slow image load - https://steamcdn-a.akamaihd.net/steam/apps/219950/header.jpg (dimensions 460x215, took 23 msec)
00000261   45.91466522   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\panel_header_background.png (dimensions 1920x128, took 23 msec)
00000262   45.91602325   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\panel_background.png (dimensions 1920x1080, took 64 msec)
00000263   45.95051575   [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\background_alpha_mask.png (dimensions 1920x1080, took 33 msec)
00000264   45.98880386   [12624] HTTP Response for https://store.steampowered.com/api/featured/?cc=US&l=english: 200, 18472
00000265   45.99658585   [12624] OnFocusWindowChanged to window type: k_nGameIDControllerConfigs_Desktop, AppID 413080
00000266   45.99673462   [12624] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000267   45.99827957   [12624] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000268   45.99853897   [12624] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000269   50.46805191   [8928]
00000270   50.46805191   [8928]  === Begin DirectDraw / Direct3D leak report ========
00000271   50.46805191   [8928]
00000272   50.46813583   [8928]
00000273   50.46813583   [8928]  === No leaked objects were found
00000274   50.46821594   [8928]
00000275   50.46821594   [8928]  === End DirectDraw / Direct3D leak report ========
00000276   50.46821594   [8928]
00000277   50.57886124   [12624] >>> Adding process 12680 for game ID 33554432
00000278   50.70522690   [12624] OnFocusWindowChanged to window type: k_nGameIDControllerConfigs_Desktop, AppID 413080
00000279   50.70545959   [12624] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000280   50.70761871   [12624] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000281   50.70777512   [12624] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000282   53.03483963   [12680] Direct3DCreate8 (SDKVersion = dc)
00000283   53.03525925   [12680] [dgVoodoo] INFO: Reading config from file C:\Users\wiseg\EphineaPSO\dgVoodoo.conf.
00000284   53.03554535   [12680] [dgVoodoo] INFO: INI file based version of config file is successfully read.
00000285   53.03735352   [12680] [dgVoodoo] INFO: D3D8 is successfully loaded: C:\Users\wiseg\EphineaPSO\d3d8.dll
00000286   53.03747177   [12680] [dgVoodoo] WARNING: Direct3DCreate8: Attempt to access Direct3D8 from DllMain. Application may need to be modified or patched to use with dgVoodoo.
00000287   53.03762054   [12680] [dgVoodoo] INFO: Reading config from file C:\Users\wiseg\EphineaPSO\dgVoodoo.conf.
00000288   53.03780365   [12680] [dgVoodoo] INFO: INI file based version of config file is successfully read.
00000289   53.07757568   [12680] [dgVoodoo] INFO: Direct3D8 (057DB570) DirectDraw has been loaded: C:\Users\wiseg\EphineaPSO\DDRAW.DLL
00000290   53.20409775   [12680] [dgVoodoo] INFO: Direct3D8 (057DB570) is created. Number of display outputs (on which devices can be created): 1
00000291   53.20417786   [12680] [dgVoodoo] INFO: Direct3D8 (057DB570)     Device 0: Name: "AMD Radeon (TM) R9 M390X", Description: "\\.\DISPLAY1", Monitor rect: (0, 0, 3840, 2160), system primary monitor
00000292   53.20419693   [12680] [dgVoodoo] INFO: Direct3D8 (057DB570) Virtual video card is 'dgVoodoo Virtual 3D Accelerated' with 64MB onboard memory.
00000293   53.20435333   [12680] Driver     :AMD Radeon (TM) R9 M390X
00000294   53.20442581   [12680]
00000295   53.20540619   [12680] Description:\\.\DISPLAY1
00000296   53.20548630   [12680]
00000297   53.20628738   [12680] VendorID   :00000000
00000298   53.20636368   [12680]
00000299   53.20719528   [12680] DeviceID   :00000000
00000300   53.20727921   [12680]
00000301   53.21051025   [12680] SubSysID   :00000000
00000302   53.21053696   [12680]
00000303   53.21142197   [12680] Revision   :00000000
00000304   53.21150589   [12680]
00000305   53.22371674   [12680] [dgVoodoo] ERROR: Direct3DDevice8 (058C4CF8)::Init/CreateAdditionalSwapChain: Out of videomemory, cannot create swapchain. Required bytes: 99532800, remained bytes: 61865984.
00000306   53.22373199   [12680] [dgVoodoo] ERROR: Direct3DDevice8 (058C4CF8)::Init: Cannot create device implicit swapchain.
00000307   53.22377777   [12680] [dgVoodoo] ERROR: Direct3D8 (057DB570)::CreateDevice: Initializing Direct3DDevice8 (058C4CF8) failed.
00000308   53.22407150   [12680] [dgVoodoo] ERROR: Direct3DDevice8 (0B152008)::Init/CreateAdditionalSwapChain: Out of videomemory, cannot create swapchain. Required bytes: 99532800, remained bytes: 61865984.
00000309   53.22409058   [12680] [dgVoodoo] ERROR: Direct3DDevice8 (0B152008)::Init: Cannot create device implicit swapchain.
00000310   53.22411728   [12680] [dgVoodoo] ERROR: Direct3D8 (057DB570)::CreateDevice: Initializing Direct3DDevice8 (0B152008) failed.
00000311   53.22451019   [12680] [dgVoodoo] ERROR: Direct3DDevice8 (0B152008)::Init/CreateAdditionalSwapChain: Out of videomemory, cannot create swapchain. Required bytes: 99532800, remained bytes: 61865984.
00000312   53.22454071   [12680] [dgVoodoo] ERROR: Direct3DDevice8 (0B152008)::Init: Cannot create device implicit swapchain.
00000313   53.22456741   [12680] [dgVoodoo] ERROR: Direct3D8 (057DB570)::CreateDevice: Initializing Direct3DDevice8 (0B152008) failed.
00000314   53.22494125   [12680] [dgVoodoo] ERROR: Direct3DDevice8 (0B152008)::Init/CreateAdditionalSwapChain: Out of videomemory, cannot create swapchain. Required bytes: 82944000, remained bytes: 61865984.
00000315   53.22496033   [12680] [dgVoodoo] ERROR: Direct3DDevice8 (0B152008)::Init: Cannot create device implicit swapchain.
00000316   53.22503662   [12680] [dgVoodoo] ERROR: Direct3D8 (057DB570)::CreateDevice: Initializing Direct3DDevice8 (0B152008) failed.
00000317   53.22525787   [12680] [dgVoodoo] ERROR: Direct3DDevice8 (0B152008)::Init/CreateAdditionalSwapChain: Out of videomemory, cannot create swapchain. Required bytes: 82944000, remained bytes: 61865984.
00000318   53.22528076   [12680] [dgVoodoo] ERROR: Direct3DDevice8 (0B152008)::Init: Cannot create device implicit swapchain.
00000319   53.22530746   [12680] [dgVoodoo] ERROR: Direct3D8 (057DB570)::CreateDevice: Initializing Direct3DDevice8 (0B152008) failed.
00000320   53.22551346   [12680] [dgVoodoo] ERROR: Direct3DDevice8 (0B152008)::Init/CreateAdditionalSwapChain: Out of videomemory, cannot create swapchain. Required bytes: 82944000, remained bytes: 61865984.
00000321   53.22553253   [12680] [dgVoodoo] ERROR: Direct3DDevice8 (0B152008)::Init: Cannot create device implicit swapchain.
00000322   53.22556305   [12680] [dgVoodoo] ERROR: Direct3D8 (057DB570)::CreateDevice: Initializing Direct3DDevice8 (0B152008) failed.
00000323   53.22560501   [12680] Fail    Direct3DCreateDevice
00000324   53.22562408   [12680]
00000325   53.22826004   [12680] [dgVoodoo] WARNING: Direct3DCreate8: Attempt to access Direct3D8 from DllMain. Application may need to be modified or patched to use with dgVoodoo.
00000326   53.23189545   [12680] [dgVoodoo] INFO: Direct3D8 (05862A18) is created. Number of display outputs (on which devices can be created): 1
00000327   53.23191833   [12680] [dgVoodoo] INFO: Direct3D8 (05862A18)     Device 0: Name: "AMD Radeon (TM) R9 M390X", Description: "\\.\DISPLAY1", Monitor rect: (0, 0, 3840, 2160), system primary monitor
00000328   53.23193741   [12680] [dgVoodoo] INFO: Direct3D8 (05862A18) Virtual video card is 'dgVoodoo Virtual 3D Accelerated' with 64MB onboard memory.
00000329   53.23223495   [12680] Driver     :AMD Radeon (TM) R9 M390X
00000330   53.23226929   [12680]
00000331   53.23360062   [12680] Description:\\.\DISPLAY1
00000332   53.23361969   [12680]
00000333   53.23447800   [12680] VendorID   :00000000
00000334   53.23450089   [12680]
00000335   53.23534012   [12680] DeviceID   :00000000
00000336   53.23536301   [12680]
00000337   53.23620987   [12680] SubSysID   :00000000
00000338   53.23622894   [12680]
00000339   53.23710251   [12680] Revision   :00000000
00000340   53.23712158   [12680]
00000341   53.24308014   [12680]
00000342   53.24308014   [12680]  === Begin DirectDraw / Direct3D leak report ========
00000343   53.24308014   [12680]
00000344   53.24322128   [12680]
00000345   53.24322128   [12680]  === No leaked objects were found
00000346   53.24329758   [12680]
00000347   53.24329758   [12680]  === End DirectDraw / Direct3D leak report ========
00000348   53.24329758   [12680]
00000349   53.24902725   [12624] OnFocusWindowChanged to window type: k_nGameIDControllerConfigs_Desktop, AppID 413080
00000350   53.24915314   [12624] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000351   53.25102615   [12624] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000352   53.25123596   [12624] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000353   53.40605164   [12680] [dgVoodoo] WARNING: Leaked D3D8 objects detected at unloading D3D8 (probably process exit)!
00000354   53.61149979   [12624] OnFocusWindowChanged to window type: k_nGameIDControllerConfigs_Desktop, AppID 413080
00000355   53.61162186   [12624] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000356   53.61346054   [12624] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000357   53.61356735   [12624] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000358   55.57763290   [12624] Game removed: AppID 0 "Ephinea PSOBB", ProcID 8928
00000359   55.70304108   [12624] **** Panel FavoritePages has fill-parent-flow for height, but isn't in a flowing down or up layout
00000360   63.26501083   [12624] OnFocusWindowChanged to window type: k_nGameIDControllerConfigs_Desktop, AppID 413080
00000361   63.26840210   [12624] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000362   63.77277374   [12624] saving roaming config store to 'sharedconfig.vdf'
00000363   63.79288864   [12624] roaming config store 2 saved successfully
PSOBB error is provided here:
Code: Select all
Failed : CreateDevice
Error : Can't use format [D3DFMT_X8R8G8B8]
Error : Can't find DisplayMode
Error : Can't use format [D3DFMT_A8R8G8B8]
todd
Re: Phantasy Star Online Blue Burst classic fullscreen won't load
Postby todd » 2018-8-13 @ 01:57
dbgview3.log
(364.04 KiB) Downloaded 8 times
guys the only way I could get PSOBB to play with dgVoodoo 2 is changing the VRAM to 1024MB, in order to launch PSOBB at 4K resolution - which happens to be my monitors main resolution.
at this point you absolutely do not want to use dgVoodoo 2 even at 4K, because all game text, chat text, etc is converted to white and gold boxes with dgVoodoo 2.
here is a reason to run with classic fullscreen: if your computer experiences a speed issue, classic fullscreen runs 2-4 times faster than borderless window mode, or window mode. I heard this might be fixable by setting PSOBB to High priority but who knows, I prefer classic full screen mode anyway.
todd
Postby todd » 2018-8-13 @ 08:23
here's some screen shots of the windows 10 popup
todd
Postby todd » 2018-8-16 @ 02:31
By the way the above popup had to be taken with reshade directx8 to directx9 wrapper because dgVoodoo 2 wrapper cannot even display the popup before it crashes the computer.
todd
Postby ZellSF » 2018-8-21 @ 17:36
That was the popup I was talking about earlier. It's about the DPI setting, not the resolution setting, which again might correlate with a resolution change, but that's not what the popup is telling you about. It's also possible in the notification to tell it to not appear again, so why don't you try that if you believe that's the problem? I don't think it is, I think this is the problem:
Fairly sure Dege's position is that he doesn't support games that use DllMain. Maybe post about it here:
viewtopic.php?f=59&t=51818
It's weird that it occasionally works though.
ZellSF
Postby todd » 2018-8-22 @ 00:26
Hey I tested this on my grandpas desktop. That's a 1803 windows 10 system. It's a budget box with like 8GB RAM, Nvidia GeForce 730, 1080p display.
It does not display any sort of popup when running PSOBB at different resolutions and runs fine. Could be my grandpa disabled the popup already somehow as the kids play a lot of games on it.
But the text also is rendered fine on the nVidia box.
It does not render properly on my AMD 4K switchable graphics laptop at all. Wonder if this is AMD specific issue or what.
Otherwise game was ran identically. Launched from steam and all.
todd
Next
Return to dgVoodoo General
Who is online
Users browsing this forum: No registered users and 2 guests
