First post, by deksar
Dear friends,
I'm looking for Zotac's GT220 PCI VGA (1GB) drivers for Win2k Professional. I'm sick and tired of looking for that. Does anyone has any idea/link regarding the topic?
Card: https://www.zotac.com/lk/product/graphics_card/gt220
Many thanks in advance!
Reply 3 of 10, by BinaryDemon
I have no experience with either option I'm suggesting but:
1) Looks like there are some modified Nvidia drivers which *may* work: http://blog.livedoor.jp/blackwingcat/archives/1114373.html (Some versions require KernelEx patched OS)
I'd atleast try this - http://w2k.flxsrv.org/cgi-bin/dl.cgi?file=nv2k19745.exe , doesnt appear to require KernelEx
2) If you don't need 3D acceleration, you should be able to find Universal Vesa drivers - http://bearwindows.boot-land.net/vbemp.htm
Check out DOSBox Distro:
https://sites.google.com/site/dosboxdistro/ [*]
a lightweight Linux distro (tinycore) which boots off a usb flash drive and goes straight to DOSBox.
Make your dos retrogaming experience portable!
Reply 4 of 10, by deksar
BinaryDemon wrote:
I have no experience with either option I'm suggesting but: […]
Wow, THANK YOU SO MUCH, BinaryDemon! It worked! Your suggestion has successfully installed my VGA card! There are a lot of users all around the Internet forums looking for that thing, as I've seen recently.
So in case if someone happen to appear here from Google, what I did:
-First, (nv2k19745.exe needs that) I installed Update Rollup 1 for Windows 2000 SP4(v2) on my Windows 2000 Pro SP4. Got it here: http://w2k.flxsrv.org/cgi-bin/wluc.cgi?OS=1&T … DATE2=/&KEY=SRP
-Then I downloaded and ran nv2k19745.exe from http://blog.livedoor.jp/blackwingcat/archives/1114373.html
Thanks once again.
P.S: dxdiag reports that Direct 3D is not enabled. Perhaps that's because the default low version of DirectX on the system? (ver.7 something). I'm going to update it to directx_feb2010_redist.exe which is the latest one for Win2k I assume.. I'll keep here updated.
Reply 7 of 10, by deksar
Mr. horse wrote:
You can use older xp drivers if you manually install them from the device manager.
Using XP drivers for installing Nvidia GT 220 card on Windows 98SE? I don't really think that would work.
Reply 9 of 10, by Kristallbaldr
Hello can anyone help me please I am new. The Drivers on Japanese Page are down.
deksar can you help me. Greetings
Content: nVIDIA 197.45 WQHL Desktop Driver Full
Filename: nv2k19745.exe
Language: Multi
LastUpdate: 2010/06/1
Download size: 102M
Version: 1.0
Require: Windows 2000 SP4 +SRP1v2
Reply 10 of 10, by oeuvre
Google is your friend. I found it in 2 seconds. http://blog.livedoor.jp/blackwingcat/archives/1114373.html
