First post, by dnewhous
- Member
I've done enough research to ascertain that so called FM or CQM midi used .smf or "standard mid files".
Aha!
Of the synthesis chips on the Soundblaster 16 and Yamaha SoundEdge, which had the ability to playback that file?
From what I have read, the CT1747 is the only chip that definitely did.
The last chip for the soundblaster 16 is YMF289
Yamaha SoundEdge's YMF278B
Out of the later sound modules, it was the Edirol cm-32l rather than the Roland cm-32l that was CQM compatible, wasn't it?
Daniel L Newhouse
