386SX-40 Motherboard Not POSTing
Reply 60 of 101, by appiah4
Murugan wrote:
Hmmm same as mine except I have no speaker attached.
Oh please do break out the debug kit and check out your card because I have a feeling the issue may be identical 😁
Reply 61 of 101, by Murugan
Hehe, I just moved into my new home and ATM everything is in boxes. I know where it is but I need to get settled first before I start with the hobby again. Give it a week or 2.
It's a different board than yours (Soyo 4SAW2) but the symptoms appear to be the same.
Reply 62 of 101, by appiah4
It's a different board than yours (Soyo 4SAW2) but the symptoms appear to be the samen.
I'm a patient man, I can wait. 😎
Reply 64 of 101, by Murugan
Ok so I quickly set this board up. I get 4E 46 as a code.
Keyboard leds briefly light up when powered on but after that the keyboard error and no more led's.
Reply 65 of 101, by appiah4
Same behavior (keyboard error after memory test complete), different debug code.. Is your BIOS AMI or Award?
I hope we can solve this issue with our boards. I'm guessing it might be a keyboard controller failure, is yours socketed? Mine is not, so it's not an easy replacement, maybe you could replace yours and try if it's socketed?
Reply 66 of 101, by Murugan
It's an Award BIOS.
My controller is not socketed sadly.
The board suffered from battery leakage and I couldn't get a signal from the Data pin or I did something wrong.
My codes are related to errors in the BIOS setup.
4E: If there is any error, show all the error messages on the screen & wait for user
to press<F1>.Manufacturing POST loop or display messages; Reboot if
manufacturing POST loop pin is set. Otherwise display any messages and enter
setup
46: display the setup message(to press Ctrl-Alt-Esc to enter setup), and enable
setup.
Reply 67 of 101, by appiah4
Murugan wrote:
It's an Award BIOS. My controller is not socketed sadly. The board suffered from battery leakage and I couldn't get a signal fro […]
It's an Award BIOS.
setup
setup.
The POST code says there was an error in an earlier stage and it stops POST there to report that, your board reports a keyboard error, same as mine.
Mine also had the battery leak, which I cleaned best I could. As far as I can see, mine has no connectivity issues with Data or Clock pins on the KBC. I THINK my issue is with 5V.. I will do more in depth testing tonight.
If you are certain that it's about Data, have you tried soldering a botch wire between Pin 2 of the keyboard connector and pin 39 of the KBC?
One thing that just occured to me, I know that the PINS of the keyboard connector have continuity to 5V, Data and Clock, but I don't know the CONNECTOR has it.. I never checked the connector side against the pins to verify, it may just be a broken connector for me. Wouldn't that be funny?
Reply 68 of 101, by Murugan
I assume that I get the error because the BIOS is not set (CMOS mismatch). I haven't done anything to the board since I'm still in my learning fase with the multimeter. I don't even know where the 5v pin is on my board. I usually have the luck of having working equipment so I need to learn about repairing and diagnose 😀
Reply 69 of 101, by appiah4
OK, I need help from more electically educated people here.
I took a multimeter and tested every trace leading to and from the keyboard socket and everything checks out.
Moreover, here is what the circuit diagram appears to be:
456.65 KiB
This makes no sense to me. Why is the 5V pin also connected to the Data Pin on the KBC? Is this normal? I'm guessing there is something fundamentally wrong here, I don't understand whythe Data port would be connecte to +5V as well in parallel with the keyboard connector socket Pin 2 - R45 being connected to +5V makes no sense to my uneducated brain.
Can someone look at this and tell me what if anything may be wrong here?
Reply 70 of 101, by gdjacobs
It's a pull up arrangement. The data line from the keyboard only has to pull down to ground while avoiding an indeterminate state instead of pulling both ways.
Reply 71 of 101, by appiah4
So it looks fine? Then I don’t know what else could possibly be wrong with this system if it does not boot when I replace the fuse other than a possibly faulty KBC.. The legs on it look dull so I’ll give it a spray of contact cleaner just in case but I guess adding a socket and replacing it is next..
Reply 72 of 101, by Tiido
Problem is most probably some connection to a KBC if another KBC won't work in there. If you can borrow one from another board then do so, if it still gives the same error you got a broken trace or a via somewhere.
Reply 73 of 101, by Murugan
I will break out the board and multimeter again and see if I can educate myself and find all the pinouts. Frustrating being a noob...
Reply 74 of 101, by appiah4
Pins 1-2-5 are definitely connected to the KBC, solid. If the circuit I posted above is also logical, then there should be no issue between the socket and the KBC. Aside from the blown fuse, which I shorted with a botch wire and that only served to blink the keyboard lights momentarily durin boot.
Say, tonight I will replace the blown fuse with these:
https://www.direnc.net/3a-250v-direnc-tip-sigorta
If that does not work, I will then remove the KBC and replace it with a DIP-40 socket, then install a KBC from one my 486 motherboards, such as this one:
83C42 to replace 80C42 should probably work, it only seems to add PS/2 functionality etc.
And if that doesn't work, well I don't know which traces and vias to look at - any pointers about how the KBC and chipset/CPU are connected?
Reply 75 of 101, by Tiido
By connection to KBC I meant ISA or dedicated peripheral bus, not connection between keyboard and KBC. CPU is not able to talk to the KBC so either KBC is damaged or connection to it. There will be usual D0...D7, perhaps few address lines and read, write and enable strobe, plus clock signal.
Reply 76 of 101, by appiah4
Ok so I should basically check every single D and A pins and make sure they are connected to something without any continuity breaks. Understood. I'll get to it tonight, first replace the fuse (by the way, is the fuse I linked above OK? The fuse currently in place is transparent, the one I bought is ceramic, though I doubt it matters?) they check every single D and A leg extensively.
Reply 77 of 101, by Tiido
That fuse will be just fine. As far as KBC connections go, they may not be directly connected to ISA but to smoe driver/buffer instead, some nearby 74x244 or 74x245 chip for example.
Reply 78 of 101, by Murugan
I checked too and I don't get a signal when probing pin 39 and pin 2 data so there is a broken trace but how to find it. I don't see anything going from pin 39...
Reply 79 of 101, by Tiido
Then there's a trace inside the board that reaches some via somewhere, and that via is where the problem is. I saw a lot of surpicious vias earlier. It is easy to connect top and bottom again but restoring connection to inner layer is difficult outside adding a patch wire to the destination.
