First post, by Flakchak
Just got a Vectra VA6/200 and would like to remove the rear plastic as it’s cracked and filthy. However, the lock is keeping the rear panel on. Does anyone have a good way of removing the lock so I can take the plastic off?
Also, don’t have a key. The lock is already in the unlocked position as I can take the top cover off.
Searching for a Packard Bell 15" CRT Monitor - 1511SL or 1512SL
