First post, by UpNorth
I have an ATI Graphics Solutions (Rev. 3, I believe) card in my Commodore PC. I need the utilities and the drivers. Can anyone point me to a working FTP server with those files? Or any other source?
Reply 1 of 12, by Grzyb
https://web.archive.org/web/19970619214748/ht … hics%20Solution
Żywotwór planetarny, jego gnijące błoto, jest świtem egzystencji, fazą wstępną, i wyłoni się z krwawych ciastomózgowych miedź miłująca...
Reply 3 of 12, by Benedikt
In case you need any information on how to program for that thing, check out the Commodore PC10 PC20 Advanced Graphics Adapter manual. That is apparently how Commodore marketed the ATI Graphics Solution in its systems despite not even rebadging it. The manual contains relatively detailed technical information.
Other than that, I can offer a minimalist bitmap viewer I wrote. It takes a 4bpp 16-color windows bitmap with 640 by 200 pixels and displays it in the card's 640x200x16 mode, ignoring the palette.
Please note, however, that this is proof-of-concept code that skips virtually all sanity checks.
I also ported Planet X3 to that mode, this summer, but that port has not been officially published, yet.
    GS-BMP.zip
    3.02 KiB
    63 downloads
Reply 4 of 12, by Scali
In later machines at least (PC10/20-II and III), Commodore used Paradise PVC2 or PVC4.
They are very similar (both support Hercules, CGA and Plantronics), but not identical.
Reply 5 of 12, by UpNorth
In fact, my machine is a PC10-III. I should have a careful look at my card, as I just assumed I have the ATI Graphics Solutions.
Would you perchance have a link to the same kind of utilities/drivers, for these PCV2 or PVC4 cards?
Reply 6 of 12, by UpNorth
Thanks, I do have the correct manual (in hardcopy).
That's awesome!
Are you... related to the 8 Bit Guy?
Reply 7 of 12, by Benedikt
And I made my own hard copy.
No, I just went on his nerves long enough to get my hands on the source code and then doubled the number of supported video modes.
The high-res Tandy mode in the VGA engine came first, then the grayscale CGA mode, the Plantronics ColorPlus mode and the Hercules mode in the CGA engine, then the medium-res EGA port and finally the ATI GS port.
Furthermore, there are some unfinished experimental modes that also reuse existing engines, e.g. an accelerated VGA mode in the EGA engine and medium-res Tandy support in the ATI GS engine.
In that case, I don't think the 640x200 16-color mode will work (although you can try if you dare). The PVC4 in that machine does evidently support the Plantronics ColorPlus modes, though.
Reply 8 of 12, by Scali
No, I never was able to track down any software or documentation on the PVC4 specifically.
However, I did find a Technical Manual for the PC10-III:
http://www.zimmers.net/anonftp/pub/cbm-pc/sch … al%20Manual.pdf
It documents the video modes on page 32. It lists the Plantronics modes, including 640x200 in 4 of 16 colours, but not a full 16 colour mode.
Reply 9 of 12, by UpNorth
Scali wrote:
No, I never was able to track down any software or documentation on the PVC4 specifically. However, I did find a Technical Manua […]
I finally arrived home after a very busy and hard day at work, had dinner and looked at my PC 10 - III, and discovered that it's in fact a PC 10 - II. I'm an idiot. Still, I downloaded the technical manual for the III, just in case. But the card really is an ATI Graphics Solutions.
Reply 10 of 12, by Scali
Yea, Commodore rebranded it to Advanced Graphics Adapter, but they are indeed ATi GS: http://www.retromaniek.pl/wp-content/uploads/ … ics_Adapter.pdf
Reply 11 of 12, by UpNorth
Will I be able to play Planet X3 on my Commodore PC-10 II (yeah, it's a II, not a III, my brain had a hiccup, I guess) anytime soon? Do you accept donations - how is your effort being rewarded?
Reply 12 of 12, by Benedikt
So far, my work has been rewarded with having a version that runs on my hardware. I surely wouldn't turn down donations, though. (Why would I?!)
Provided that you have the game, you should be able to play it on that machine, right now, using one of the other supported modes.
Only the dedicated ATI GS port for the 640x200x16 mode has not been officially published, yet, but since all the other executables are freely available for download, as well – without the game assets, obviously –, we can surely arrange something.
There's a screenshot in the ATI Graphics Solution thread.
