Reply 580 of 893, by vorob
Just wanna share some pictures. Because i can.
896.39 KiB
Siemens Nixdorf Scenic Mobile 710
387.01 KiB
343.94 KiB
787.46 KiB
930.23 KiB
Reply 583 of 893, by vorob
Since i've got only 64mb flashcard i've installed only doom, commander keen and prince of persia. They all work well, and i've got sound and gm music without drivers.
One issue so far, and it is covered here:
Re: Cropped screen
By default320x200 games are just a small window in center, no build-in option to stretch it. When i use VEXP utility i'm able to make window bigger, but i still have borders and 320x200 is squeezed like i had on my toshiba 2805 with S3 videocard. Looks like it's best i can get here.
Reply 584 of 893, by vorob
I'm trying to enable USB on this Siemens. All other PC's work with this thing:
DEVICE=HIMEM.SYS /TEST:OFF
DOS=HIGH
DEVICEHIGH=USBASPI.SYS /V /W
DEVICEHIGH=DI1000DD.SYS
But this one find no devices. Maybe there is another approach? Another dude made another way to work with USB under DOS?
Reply 585 of 893, by BitWrangler
Variations on that theme... USB storage drivers that work in DOS 6.22?
Reply 586 of 893, by vorob
BitWrangler wrote on 2021-08-05, 22:26:
I'll try, thanks.
Honestly, if this laptop is really from 1997 i don't get how USB exist there. And i see no drivers on FJS support page. What was the use case for it back then?
Reply 587 of 893, by vorob
Thanks once again! This thing solved the issue: http://bretjohnson.us/
Just used two exe files and my flash drive is available in dos. The speed though is super slow, but it's better then nothing.
As for a lappy, i'm happy for now 😀 No drivers, no dancing with the settings. I just choose GM or roland and game produce rich music! Now i'm waiting for my 2gb compactflash.
Reply 588 of 893, by vorob
Just received my 2gb compact flash card for my Siemens Nixdorf Scenic Mobile 710. Now i'm packing it with games like a madman. I've also installed Win 98 and it supports USB with better speed than i had in DOS. So far all stuff i'm launching is working like i expect it to work: for music i'm selecting mt32 or sound canvas or general midi and for sound just sound blaster. And it works. Just works!
The only game where i face issues is Dune 2, can't have both gm music and sound effects...
Reply 589 of 893, by bjwil1991
I got a standard 1GB CF card installed on my Toshiba Satellite Pro T2150CDT internally (attempted to use a 512MB Industrial and 1GB Industrial CF cards to no avail (either freezes up or not detected) and copied all of the files from the 527MB image of the old hard drive onto the CF card once I was done formatting it.
And it's a lot more silent than before.
Reply 590 of 893, by vorob
The Dune issue is solved. For now, I can't see a reason why Siemens Scenic Mobile 710 can't be called an ultimate dos gaming machine. Well, maybe its scaling can be a weak point. Mode 13h is squeezed...
Reply 591 of 893, by vorob
909.5 KiB
I Bought CD-ROM for my lappy. Couldn't live with a dead battery, useless waste of space.
Reply 592 of 893, by vorob
Capturing some samples from my Siemens. Direct capture. If you know some tough gm music games, name them please.
https://youtu.be/l-F7u2S9NVM
https://youtu.be/Uc7zHIYEpfQ
Reply 593 of 893, by imi
my disappointment is immeasurable and my day is ruined!
all that work cleaning out the heavy corrosion of the NiCad pack and disassembling... for this? 😁
...though I guess the missing audio jacks should have been a sign ^^
601.27 KiB
Reply 594 of 893, by kixs
vorob wrote on 2021-08-17, 22:14:
I don't like the keyboard feeling. Also mouse buttons are flimsy. Machine wise it pretty good. My has Tillamook 266.
Reply 595 of 893, by ragefury32
imi wrote on 2021-08-22, 20:42:
my disappointment is immeasurable and my day is ruined! […]
What exactly am I looking at here?
Reply 596 of 893, by BitWrangler
It's what isn't there.... like all the sound chips.
Reply 597 of 893, by ragefury32
BitWrangler wrote on 2021-08-23, 03:16:
What, is it supposed to be missing (as in, did it came from a 486 laptop that has a multimedia option…which is not populated in certain models)?
The 83c611 and the CT65540 chips pretty much point to it being on a VLB machine.
Reply 599 of 893, by imi
ragefury32 wrote on 2021-08-23, 05:39:
What, is it supposed to be missing (as in, did it came from a 486 laptop that has a multimedia option…which is not populated in […]
yeah, it's a nice 486 VLB laptop, what could have been is also a nice 16-bit sound section with real OPL3, as seen here: http://www.ombertech.com/cnk/skd-4000/img/Sma … /P1010001,s.jpg
while the components seem to be nicely labeled there's still a million SMD resistors and capacitors, so it would be kinda hard to populate all of that let alone know what values exactly 😒
would have been a nice project to try and swap in a color TFT, but without sound it's kinda pointless.
