Dominus wrote on 2020-03-11, 14:03:
pfffff ... would be a legit response if DOSBox was BSD-licensed 😀
But yeah.. the Software Freedom Law Center (SFLC), even wrote a guide about build scripts and steps needed to get to the distributed binary:
https://www.softwarefreedom.org/resources/200 … ance-guide.html
4.2.2 Building the Sources
Note that you must include “scripts used to control compilation and installation of the executable” and/or anything “needed to generate, install, and (for an executable work) run the object code and to modify the work, including scripts to control those activities”. These phrases are written to cover different types of build environments and systems. Therefore, the details of what you need to provide with regard to scripts and installation instructions vary depending on the software details. You must provide all information necessary such that someone generally skilled with computer systems could produce a binary similar to the one provided.
[...] Sometimes, however, scripts were never written (e.g., the information on how to build the binaries is locked up in the mind of your “build guru”). In that case, we recommend that you write out build instructions in a natural language as a detailed, step-by-step readme.
No matter what you offer, you need to give those who receive source a clear path from your sources to binaries similar to the ones you ship. If you ship a firmware (kernel plus filesystem), and the filesystem contains binaries of GPL’d programs, then you should provide whatever is necessary to enable a reasonably skilled user to build any given GPL’d source program (and modified versions thereof), and replace the given binary in your filesystem. If the kernel is Linux, then the users must have the instructions to do the same with the kernel. The best way to achieve this is to make available to your users whatever scripts or process your engineers would use to do the same.
