HWiNFO for DOS resurrected !
Reply 480 of 884, by ruthan
No, just realmode.
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
Reply 481 of 884, by Mumak
Here a new build to improve dumping of MSRs on IBM BL3. Also adds recognition of SLC2/3 and BL2/3 model based on actual ratio.
@ruthan: Please run this build with -d parameter and attach the HWINFO.DBG file it produced to analyze the issue.
[build pulled, newer available]
Reply 482 of 884, by ruthan
Here is log.
Reply 484 of 884, by ruthan
No its still broken - CPU type is fine but, TDP is still reported with value 130W, i dunno if you are getting it from some HW registers, or you are just using some clever list with these values its wrong. Intel has on ARK 65W.
Other other issue, is that after is mane of MB reported.. it take at least 45s to print out rest of info, its quite a lot, it would be nice to show some progressbar or something like that, because otherwise some less patient user could easily lose patience and reset the system prematurely.
Reply 485 of 884, by Mumak
ruthan wrote on 2020-05-17, 22:16:
Can you please attach a new report file, so I can see the exact data?
Regarding the very long wait, that's not expected. Can you please take a screenshot where exactly it takes so long?
Reply 486 of 884, by ruthan
First menu option - Mainboard.., after MB name is printed.. is that long wait.
Reply 487 of 884, by Mumak
ruthan wrote on 2020-05-17, 23:13:
I guess this is down to some strange behavior of the system PCI BIOS - it reports the system has 128 buses (which is not correct) and scanning them all takes so much time.
Reply 488 of 884, by ruthan
I heard that these MBs have more than 1 PCI bus to bypass 133 MB/s .
Reply 489 of 884, by Mumak
ruthan wrote on 2020-05-18, 10:05:
1,2,3 would be OK, but 128 is way more than really present 😀
If you can provide the new DBG file, I will check the problem with reporting TDP.
Reply 490 of 884, by ruthan
I will, but it not my priority, so i could be in hour, or it could take a week..
Reply 491 of 884, by feipoa
Here's the latest HWiNFO on the IBM 486BL3. It shows the 3x multiplier.
    IBM_486BL3.rar
    5 KiB
    47 downloads
Reply 493 of 884, by ruthan
Here is new long, TDP is still reported 130W.
What about Sata drives detection crash?
Reply 494 of 884, by Mumak
Version 6.1.1 released:
- Added Debug Mode via -d command-line switch.
- Improved detection of IBM Blue Lightning CPUs.
- Improved detection of some 386/486 chipsets.
- Added reporting of supported/current AGP mode.
- Improved detection of some SiS graphics adapters.
- Improved L1/L2 cache detection.
I cannot edit the initial post anymore because of too many edits, so it's attached here.
    HWINF611.ZIP
    994.27 KiB
    141 downloads
Reply 495 of 884, by RayeR
Tested on my i7 and:
* video detection improved, instead of VGA it shows NVidia unknown (1189) - it's GTX670
* video memory size detected 1GB instead of 2GB
* video mem.clk detected 8MHz
* superIO now detected OK as IT8728F
* missing ATAPI device (DVD) on SATA secondary master (HWI 6.0.5 show it but only sometimes)
* crash happen when do sequence: go to peripheral info, serial port enumeration (IRQs probed) go back, go to peripheral info again
Reply 496 of 884, by Mumak
RayeR wrote on 2020-05-21, 02:28:
Tested on my i7 and: * video detection improved, instead of VGA it shows NVidia unknown (1189) - it's GTX670 * video memory size […]
That GPU is too new for the DOS version and it's not possible to support it under DOS anyway. On Windows one needs to rely on NVIDIA APIs, which is not available under DOS.
Reply 497 of 884, by RayeR
Ok I understand but how from where the mem size and clock came? Maybe rather not display that wrong values for unsupported HW. The clock could be read like nvclock do directly from MMIO but of course it's very specific for various chips and not documented for newer so it's beyond the scope of gereric hwinfo...
Reply 498 of 884, by Mumak
RayeR wrote on 2020-05-21, 08:43:
Those came from using a method for previous generations, which can't be applied here. I will check how to remove that for later ones.
Reply 499 of 884, by feipoa
Here's the log and report files for the IBM 486BL3 using v6.1.1.
    486BL3.rar
    5.14 KiB
    44 downloads
