First post, by Horun
Have an older system running FF on Win7. The last update causes a Update Now drop down on top right side every time FF is launched. Is there a way to stop it ? Yes I know that Win 7 is not very old OS so not really vintage but the old system is soc478 which sorta of is. Tried some of the methods posted online (other than reverting to a previous version) but nothing works to stop it. Any suggestions ?
Reply 1 of 2, by darry
Long shot, if the video card is recent enough to have hardware acceleration in Firefox, maybe try disabling that .
EDIT: Re-read your message . Not what I thought initially. My suggestion does not apply, sorry .
Reply 2 of 2, by Horun
Figured it out. As of FF 64 you cannot disable Notify about updates, it was removed from the Options menu.
"You can create a policies.json file and store that file into the
‘C:\Program Files\Mozilla Firefox\distribution’ folder.
Create a ‘distribution’ folder in \Program Files\Mozilla Firefox\ folder and place that
policies.json file into that folder with the following contents:
"policies":
"DisableAppUpdate": true
That's it."
NOTE: Above thanks to EP at Winaero
The "DisableAppUpdate": line can only be true or false. To restore Update notifications just delete the policies.json
Do not create and add the .json file (or delete it) with FF running.
That is all ! And it works ! Top picture is what happens every time I launched FF before the fix, and it happened at about 10 min intervals. A very annoying balloon popup. Bottom picture shows Options and updates disabled.
    19.47 KiB
    25.72 KiB
