Reply 23 of 46, by Doornkaat
I believe the siren sound was bad voltages/temperatures/fan speeds on Award.
Is the temperature probe present on your board? Do you have any way of checking it?
Also what PSU are you using? Can you check its voltages on another board?
Reply 24 of 46, by austinham
Xs1nX wrote on 2020-05-22, 16:32:
austinham wrote on 2020-05-22, 16:21:
removed the CPU and see if you get any beeps. My money is on a bad board however.
i dont have a PC speaker also the board was tested before shipping and the CPU was not so I am not sure.
Not everyone on ebay tells the truth or knows how to test old hardware and shipping damage dose happen.
If you have a multimeter or test light (like a led light) you can read the voltage output of the post speaker leads.
Reply 25 of 46, by austinham
Xs1nX wrote on 2020-05-22, 17:22:
So looking this up it seems the beep code I am getting means bad CPU.
wouldn't that be high then low beep repeating? one long high beep would ether be fan failure or over heating cpu.
Reply 26 of 46, by Xs1nX
Doornkaat wrote on 2020-05-22, 17:37:
I have tried 3 different PSUs, a CIT 500w, Casecom 300W and aPC Power And Cooling 510 SLI
How would I access a temp probe if the machine will not POST at all ?
Reply 27 of 46, by Xs1nX
austinham wrote on 2020-05-22, 18:03:
Sorry yes its a High/Low for sure.
With all this being said right now I am about 95% sure that the CPU is dead.
Reply 28 of 46, by Doornkaat
Xs1nX wrote on 2020-05-22, 18:04:
Unsolder, measure?
Reply 29 of 46, by Xs1nX
Doornkaat wrote on 2020-05-22, 18:15:
Unsolder, measure?
I do not have the setup to do this.
Reply 30 of 46, by texterted
Try giving the edge connector a clean with white vinegar.
Cheers
Ted
98se/W2K :- Asus A8v Dlx. A-64 3500+, 512 mb ddr, Radeon 9800 Pro, SB Live.
XP Pro:- Asus P5 Q SE Plus, C2D E8400, 4 Gig DDR2, Radeon HD4870, SB Audigy 2ZS.
Reply 31 of 46, by Xs1nX
texterted wrote on 2020-05-22, 18:50:
I do have some contact cleaner I could try, but the edge and fingers look fine to me and not needing a clean.
Reply 34 of 46, by Xs1nX
Xs1nX wrote on 2020-05-23, 14:09:
Since I now have to get a new CPU does anyone here have specific details on the part number and component I need to have on the Chaintech 6BTM to support Coppermine ?
Anyone have an answer for this ?
Reply 35 of 46, by evasive
6BTMO-x100A
x=
L / M / N version support only with HIP6004BCB ( U9 )
E / F / G / H / J / K version full support
From what I can find you officially need HIP6004BCB to support 1.7v core voltage instead of the HIP6004ACB that only can handle until 1.8v.
(If you can find a slotket for FCPGA that can also adjust the core voltage (so it has a regulator) then it doesn't matter much what board revision you have. But that's a different story)
Reply 36 of 46, by Xs1nX
evasive wrote on 2020-05-26, 05:57:
6BTMO-x100A x= […]
6BTMO-x100A
x=
Where is U9 on the board ?
Reply 37 of 46, by evasive
Should be near the CPU slot, between the CPU and the ports of the board. Two coils, then 2 power transistors, then there an IC. If there is a totally different model on the chip, please post that one, I see some boards were made with a different model and brand of controller chip.
Reply 38 of 46, by PARKE
@evasive
One question, maybe a silly one but I'm trying to improve my understanding here.
His BIOS chip has a sticker that says [02/25/99] which is 8 months before the Coppermine was launched.
If he needs to upgrade his BIOS for Coppermine support (if that is at all possible) should he not begin with a Katmai cpu anyway ?
Slot 1 CPU fitting..
10.52 KiB
Reply 39 of 46, by PC Hoarder Patrol
evasive wrote on 2020-05-26, 13:08:
Saving myself those 1000 words 😀 (this is the official Chaintech image)
Might also be worth reading this post Re: Bios update failed on a chaintech 6btm, any helpers?
40.4 KiB
