First post, by muon
I have a ISA Paradise vga with 512 kb video memory. How I can test the 256-512kb memory range?
The checkit and other testing utilities test 0-256kb video memory range but not 256-512kb memory range.
How I can test that range?
Reply 1 of 6, by Jo22
That's an issue because the normal VGA standard has a max. of 256KiB, but you want to test features of "Super VGA".
The hardware register to check memory essentially can hold either the values "false" or "true" only.
Depending on these, a program can only check if the card has full VGA RAM or less.
Hence CheckIt! say "256KiB or more". 😀
The simplest idea that comes to mind:
If you want to check the rest of RAM, either load a VBE 1.x TSR and use a picture viewer.
Or run a program that supports the card directly.
A pack of old VBE TSRs can be found here: Re: OAK OTI-037c - 800x600 mode ?
They may work (or not work) better than UniVBE.
Paradise PVGA1A/PVGA1B and Western Digital WD90c00 are the same from a software point of view.
Reply 2 of 6, by Grzyb
Re: Testing VRAM on older cards under DOS?
My choice for testing RAM on ISA SVGA cards is X-VESA.
It requires VESA BIOS Extensions, which some early SVGAs lack in their ROM BIOS, so an additional utility is necessary - eg. UniVBE.
Reply 4 of 6, by muon
Grzyb wrote on 2020-06-23, 22:05:
Where I can get X-VESA?
Reply 5 of 6, by Grzyb
muon wrote on 2020-06-24, 17:41:
ftp://ftp.elf.stuba.sk/pub/pc/utildiag/xvesa102.zip
