Reply 23 of 239, by vetz
Some CGL tech demos for the 3D Blaster, acquired from an ex-Creative employee.
The DTDTEST is a dungeon 3D demo where you can activate lights which will light up the area around it. Can't remember what test.zip did, will report back when I got my 3D Blaster up and running again.
    test.zip
    478.8 KiB
    161 downloads
    Another Tech demo for 3D Blaster
    DTDTEST.ZIP
    2.79 MiB
    179 downloads
    Tech Demo 3D Blaster
Reply 24 of 239, by RichB93
Sorry to reply to such an old thread but I thought it better than cluttering the forum with yet another one... can CGL be used (or patched to be used) on Verite based non-Creative cards? And if so, could it then be further patched to use V2x00 cards as well, in the same fashion that V2DOSFIX can do for Verite compatible games? Apologies if this has already been asked before!
Reply 25 of 239, by vetz
No, you can't unfortunately. I have tested this before I got hand of a 3D Blaster PCI card.
Reply 26 of 239, by RichB93
That's a bummer! I wonder what checks it does to make sure its running on a Creative card?
Reply 27 of 239, by Gona
CGL do not bios check. Earlier I have tried to run CGL games on V2200 and put a Creative Graphics Blaster card to the system too (I thinked that the CGL seek Creative video bios, and can find the Graphics Blaster bios), but without success. Later I have tried this with added 3D Blaster PCI as second card. CGL games are starts but the 3D screens are presented by 3D Blaster PCI not the non-Creative Vérité card. So with CGL API the 3D Blaster PCI can works as an add-in 3D accelerator card (like 3D Blaster VLB or Voodoo 1-2 but without pass-through VGA option you need a 2nd monitor or 2nd input on your monitor).
So CGL API do not video bios check but seek and find the card.
3D Blaster VLB is an add-in 3D accelerator card. Fatal Racing and Whiplash has patch/supports the 3D Blaster VLB and with the "VRITE170.CGL" file you can start the game on 3D Blaster PCI but at the game menu, monitor will goes to offline/no signal. This because, the menu comes after a 3D screen and the game "send back" the signal from 3D Blaster card to the videocard. I have tried that I booting with 3D Blaster PCI as primary and the another VGA is also presents as "secondary", but there is no menu of the Fatal Racing/Whiplash. With 3D Blaster PCI you can use Fatal Racing/Whiplash without problems if the 3D Blaster PCI is not the primary videocard and you have an other VGA card in the system that is primary.
This is a CGL specific thing, vQuake (Speedy3D API of the Vérité) can not start if the 3D Blaster PCI (or other Vérité card) is not primary.
CGL might seek the PCI ID, I don't know.
Video card compatibility matrix for DOS games | ATI3DCIF compatibility matrix | CGL API compatibility matrix
Reply 28 of 239, by RaVeN-05
ok sorry for bumping old thread, have unrelative question about "21st Century Digital Boy"
Is there any list of demoscenes with API's support like vetz 3d acceleration thread?
i see:
CGL
3dfx:
at pouet.net
s3d
i seen one demoscene
ATI 3d CIF:
https://www.youtube.com/watch?v=jecJsjgZ7as
something like that exist at vogons or somewhere else?
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 29 of 239, by Stiletto
RaVeN-05 wrote:
Is there any list of demoscenes with API's support like vetz 3d acceleration thread? ...
I looked for one a few years ago but didn't find one. I think it might need to be created.
do the Fandango!" - Queen
Stiletto
Reply 30 of 239, by furan
Reviving a dead thread.
From my disassembly it looks like with some games you can do:
set HOTCGL=mydriverfile.cgl
beforehand, and it will use that "creative hotlink" CGL binary (I guess they came up with their own form of DLL). Possibly this can also be a directory containing CGL files.
Reply 31 of 239, by furan
You might realize this but these files contain CGL drivers for the Verite V1000 and the Laguna 3D.
"Strings" analysis of what these drivers support:
GIGTB170.CGL
CGL Revision 1.70 Release
: EAGLE REV 1.0
: EAGLE REV 2.0
: GLINT300SX REV 1.0
: C Simulator
PDLTB170.CGL
: PERMEDIA (DELTA) REV 1.0
: EAGLE REV 2.0
: C Simulator
: PERMEDIA (DELTA) REV 2.0
: PERMEDIA (DELTA) REV 0.0
L3DTB170.CGL
CGL Revision 1.70 :
Cirrus Logic :
Insert Optional names Here
CL-GD5462 :
CL-GD5464 :
VRITB170.CGL
Verite CGL 1.70 beta 7
VRITE170.CGL
Verite CGL 1.70 beta 4
VRITI170.CGL
These CGL files are loaded using a custom dynamic-linking system Creative called (in the binaries) "Creative Hotlink 2." - I would like to disassemble the detection routine to try and get an idea of how they only allow the creative labs v1000, but I will need to get an in-memory, already loaded and "fixed-up" (relocated) copy of the binary.
Reply 33 of 239, by furan
Stiletto wrote:
furan, thanks for posting this analysis - keep up the good work! 😀
Thanks!
It seems that both the PERMEDIA 1 and 2 datasheets reference CGL support with the following quote:
"The TVP4020 accelerates key consumer-focused 3-D APIs and drivers. The
TVP40x0 family of PERMEDIA processors is the reference port for many 3-D
drivers:
Microsoft Direct3D
OpenGL
Creative Labs CGL
Autodesk Heidi for 3D Studio MAX support"
Reply 34 of 239, by RaVeN-05
Sorry for noob question. What that means? it means non Creative 3D Blaster cards can support CGL ?
Reply 35 of 239, by furan
- Possibly, the Glint 300SX PCI card can be made to work with these games.
- Probably the most interesting thing is that existing CGL-supporting games could support the Cirrus Logic GD-5446/Laguna3D.
- It's already been said that the CGL driver for Verite 1000 won't work on cards that aren't Creative Labs - I'm trying to look into what they use to detect that.
Reply 38 of 239, by Gona
The environment variable "HOTCGL" not works if you try to use with filename (I have tried it), this works only if you set a directory.
Error message in BATTLE ARENA TOSHINDEN:
Cannot find the right .CGL files in "C:\TSD".
Copy these files in "C:\TSD" or specify the location setting the environment variable HOTCGL.
e.g. SET HOTCGL=C:\3DBLAST\DLL
So if you want to use more than one exact cgl file, put them separate directories and set this in bat files.
For example I put the 3D Blaster PCI (2D/3D card) and the 3D Blaster VLB (3D only add-on card) into the same computer and copy the CGL file like this:
C:\ASOCCER\VLB\GIGTB170.CGL
C:\ASOCCER\PCI\VRITB170.CGL
I could make batch files:
VLB.BAT
SET HOTCGL=C:\ASOCCER\VLB
PCI.BAT
SET HOTCGL=C:\ASOCCER\PCI
But some games and demos could works only with an exact hotcgl version, for example Actua Soccer and DTDTEST are not works for me with the latest VRITB170.CGL (CGL170IRT) "Verite CGL 1.70 beta 7" but works only with VRITB170.CGL (CGL170IRT) "Verite CGL 1.70 beta" (I think this is a "beta 1" because older). Because this, better if you put the needed CGL file into the game directory or using directories under the game directory. So using a "global" HOTCGL environment variable not the best.
(UPDATE: Later I have tested 3D Blaster PCI in a later PnP system and DTDTEST works with "Verite CGL 1.70 beta 7" cgl file too.)
I'm using 3D Blaster VLB and PCI in separate machines so I put the needed CGL file into the game directory (not subdirectory) and in this case HOTCGL environment variable not needed at all.
But for playing this things for this tests I but the 3D Blater VLB and PCI in to the same computer (test config 1: Socket 4 VLB/PCI motherboard based on OPTi Premium chipset with Pentium 60 CPU) and I have used 2 monitors (separate for the 3D Blaster VLB and PCI).
First I have tested Actua Soccer. If both the GIGTB170.CGL and VRITB170.CGL are present, the game will start with VRITB170.CGL, so on 3DB PCI. If I have moved the GIGTB170.CGL to a directory and set this directory with environment variable HOTCGL, the game has started with GIGTB170.CGL so with VLB. Than I have deleted the GIGTB170.CGL file from the directory setted by HOTCGL but sill left the VRITB170.CGL in the game directory and the game started in software mode ("No 3D Blater detected - running in software mode").
So if you use the environment variable HOTCGL, this will be an exclusive, only one path without fallback.
Later tests I have used environment variable HOTCGL, a directory with only one CGL file.
furan wrote:
Note that we have no "driver" for the Permedia 1 and 2 cards, so even if it were a reference port for them, we'd have to find the .CGL file targeting those cards.
Only we have a DOS driver for 3D Blaster VLB (INIT3D.EXE), but I have tried Actua Soccer and works with 3DB VLB without loaded driver too. So the CGL files can be enough, no other drivers are needed (3DB PCI also have no DOS driver and CGL API works).
PDLTB170.CGL
Than I have removed 3D Blaster cards, I have put my Glint 300SX PCI card to the test system, I have removed CGL files, and copyad the PDLTB170.CGL file ("CGL Revision 1.70 : PERMEDIA (DELTA) REV 1.0 : EAGLE REV 2.0 : GLINT300SX REV 1.0 : C Simulator : PERMEDIA (DELTA) REV 2.0 : PERMEDIA (DELTA) REV 0.0") into my HOTCGL directory, than try to start Actua Soccer, but "No 3D Blater detected".
I have tried to start the DTDTEST (both test.exe files) in CGL mode too (note that DTDTEST will start in software mode by default, for CGL mode you need to use cgl switch
test.exe -cgl
), but the same result "Error #699 loading CGL modules.".
Because PDLTB170.CGL has some lines that the same with GIGTB170.CGL lines, I have tried PDLTB170.CGL with 3D Blaster VLB by Actua Soccer without success "No 3D Blater detected".
Than I have to tried my Permedia1 card (by PowerColor), but nothing ("No 3D Blater detected" and "Error #699 loading CGL modules.") but this card has no Glint Delta chip as the Creative engeneering sample Permedia1 card. Diamond Fire GL 1000 card has also Glint Delta chip too, but I don't have that card, and I think that also not works because I think this CGL file also see if the card is Creative card or not...
I have tested my Permedia2 card (by ELSA), but nothing ("No 3D Blater detected" and "Error #699 loading CGL modules."). I have no Permedia2 card made by Creative.
L3DTB170.CGL
But I have a Creative CL-GD5464 card: Graphics Blaster MA334 (CT6381), and a Creative CL-GD5465 Graphics Blaster Eclipse (CT6510), so I have tried this with L3DTB170.CGL file (CGL Revision 1.70 : Cirrus Logic : CL-GD5462 : CL-GD5464).
Creative CL-GD5465 card with Actua Soccer and DTDTEST do the same things as all other not supported cards,
but with Creative CL-GD564 card Actua Soccer gives dark screen and DTDTEST exe files are crash, so CGL has tried to start.
Then I have moved Creative CL-GD564 card to a later (period correct) PnP Pentium PCI motherboard (test config 2: Intel TC430HX with Pentium 100 CPU), then I have tried L3DTB170.CGL with the Creative CL-GD564 card by DTDTEST. It has started! But the picture was not clear, it was "ghosted", noised.
I have tested Actue soccer (SOC3DB.EXE) too. This also has started, but looks like in software mode.
I have tried to find other game which uses CGL files.
I have found that Rebel Moon - 3D Blater PCI version - also can use CGL files.
This also can start with L3DTB170.CGL file on Creative CL-GD564 card, but looks like a software mode game (note that Rebel Moon has no batch or switch to start it in software mode).
Update: L3DTB170.CGL has no card check and runs on non-Creative Cirrus Logic CL-GD5464 cards too (thanks Putas).
Pictures:
373.69 KiB
Rebel Moon (3D Blaster PCI version) on 3D Blaster PCI
380.24 KiB
Rebel Moon (3D Blaster PCI version) on Graphics Blaster MA334
Reply 39 of 239, by vetz
WoW! This is a new discovery! Nice work Gona!
Do you have more games you can test on the Creative CL-GD5464? I believe Fatal Racing/Whiplash, Screamer II and Battle Arena Toshinden can be tested as they have separate .CGL files. I don't think the card supports bilinear filtering so I'd expect it to look exactly like software mode (just like the 3D Blaster VLB)
Reply 40 of 239, by Gona
According to cirrus.com the CL-GD5464 have bilinear filtering
https://web.archive.org/web/19980111174607/ht … ews/gd546x.html
but L3DTB170.CGL supports CL-GD5462 too which has no bilinear filtering and nothing 3D because it is a 2D only chip:
https://web.archive.org/web/19990907202610/ht … ews/gd5462.html
I will try to compare my Creative CL-GD5464 with 3D Blaster VLB.
Reply 41 of 239, by Gona
With GIGTB170.CGL I can start the Rebel Moon - 3D Blater PCI version on the 3D Blaster VLB! This gives a third type drawing!
373.69 KiB
494.97 KiB
Rebel Moon (3D Blaster PCI version) on 3D Blaster VLB
380.24 KiB
