First post, by skel2raw
Hi guys,
I want to build a 5x86 rig with an ASUS PVI-486SP3 board. However, I am having difficulties getting it running. I installed the correct ram, tried different CPUs, set jumpers correctly, tried different graphic cards, different PCI slots...
Always the same result. When I turn the PC on, the monitor light goes on, no picture is shown and it goes to standyba again. Unfortunately the board does not produce any beep codes. Am I missing something or is this board simply dead?
Thanks for your help!
