Reply 21 of 26, by w0lf42
I'm back with more updates.
New motherboard arrived and I have installed it.
ASUS CUV4X Socket 370 Motherboard w/ Pentium III 733MHz CPU & 512MB RAM
As far as I can tell, all of my graphical issues have been resolved. I don't believe that it was a settings/driver issue as I used the same hard drives with the same Windows98SE install with the new motherboard.
However, my mouse seems to crash the game.
I've tried:
  • Two different mice (Logitech MX518 and Microsoft Intellimouse)
  • Using PS/2 and USB connections
  • Using multiple mouse drivers (Microsoft Mouse v8.20 [C:\DRIVERS\MOUSE\MOUSE.EXE /R4 /P1], CuteMouse 1.91 [LH C:\DRIVERS\MOUSE\CT191\CTMOUSE.EXE /5, LH C:\DRIVERS\MOUSE\CT191\CTMOUSE.EXE /5 /P /Y], CuteMouse 2.0A4 [LH C:\DRIVERS\MOUSE\CT20A4\CTMOUSE.EXE /5], and CuteMouse 2.1B4 [LH C:\DRIVERS\MOUSE\CT21B4\CTMOUSE.EXE /5]).
If I play the game and don't touch the mouse, everything works fine. But within ~5 minutes (it varies between sessions) of using the mouse, the game will freeze - requiring a CTRL-ALT-DEL and a system restart.
This only happens at 800x600 resolution.
I have not been able to replicate this issue with any other game/application/etc.
Also, I was able to us my Thrustmaster T.16000M with no issue. However, mapping (via joytokey) the Thrustmaster to my mouse causes the same crashing.
I saw someone suggesting that I disable SLI. I saw a list of environmental variables here, but I wasn't sure which ones to use.
I am using sst1init.dll and fxmemmap.vxd suggested by Gamecollector.
I ran these two programs (provided the same output) detect / pcirw
Slot	venderID	devID		baseAddr0		command		description
00 0x1106 0x0605 0xfc000008 0x0006 ???:Host bridge
01 0x1106 0x8605 0x00000000 0x0007 ???:PCI-toPCI bridge
04 0x1106 0x0686 0x00000000 0x0087 ???:ISA bridge
13 0x105a 0x6268 0x0000b801 0x0007 ???:???
14 0x121a 0x0002 0xee000008 0x0002 3Dfx:video multimedia adapter
15 0x121a 0x0002 0xed000008 0x0002 3Dfx:video multimedia adapter
16 0x1317 0x0985 0x0000a001 0x0007 ???:ethernet controller
17 0x1102 0x0002 0x00009801 0x0105 Creative:audio multimedia adapter
I'm still working on obtaining and installing other Voodoo1 games.
Reply 22 of 26, by w0lf42
I may be onto something. I installed GLQuake and had some issues. I turned off "Activation follows mouse (X-Mouse) in Tweak UI and it ran great. So, after having it off, I ran MW2 and it ran mostly fine.It's not crashing any more. But, there is some "alt-tabbing" to desktop behavior happening on occasion when I'm moving the mouse and clicking at the same time.
Reply 23 of 26, by biessea
Ehy there, any news here?
I'm having big troubles when try to run this game on my system, a P3-S with 64MB RAM, Winodws98SE, SLI Voodoo2.
I tried the batch files, two files put in the MECH2 main directory, try disabling the SLI, nothing works. When It load the mission system just hang on black screen.
I don't know what to do, I read a lot but no solution for me 🙁
Computer lover since 1992.
Love retro-computing, retro-gaming, high-end systems and all about computer-tech.
Love beer, too.
Reply 24 of 26, by biessea
Oh God, I got it!!!
After tries and tries, I apparently solved through a switch that I "unchecked" in the control panel of the FastVoodoo 4.6 drivers. I toggle that every frame is synced with the videocard "vertical sync I think".
In the FastVoodoo 4.6 drivers you have to go on the panel Voodoo2 OC (probably a plug in inside the drivers to overclock the card) and uncheck the "Don't sync buffer swaps to monitor refresh rate for Glide (and Direct3D too).
I click on FACTORY DEFAULT too, just to put the video card to 90mhz (I had before 94mhz I don't know if this can cause that block).
Immediately after this the game runs fine. No colour problems, no other problems. I have to try the 800x600 resolution now. Let's see.
PS: I have enabled the SLI mode without problems, it run.
I keep you informed!
Love beer, too.
Reply 25 of 26, by biessea
No, this is incredible.
I made it work ONE TIME, but after that, it never worked anymore.
Artifacts, or black screen another time.
I don't know what to say really, I just seen one time working good, stop. Incredibile. I don't know what to do. Any ideas?
Love beer, too.
Reply 26 of 26, by biessea
And sometimes after it load the mission it crashes with this error:
    433.23 KiB
    mech2 3dfx voodoo2 crash error
Love beer, too.
