Reply 20 of 43, by Takedasun
Unreal 1152x864
Unreal 1152x864
Interesting. I wonder why the TNT2 PRO goes from 23 FPS at 32-bit color with 2.08 drivers to just 9 FPS with 3.68 drivers. That's a huge difference!
Nvidia driver bugs
Or nvidia dirty tricks that have been disabled in the newer driver?
Half-Life ver. 1.0.1.6
Direct3D
OpenGL
What's interesting is how well the supposedly vastly inferior S3 Savage4 Xtreme manages to hang in there, on this game. Sure it's noticeably slower under 32 bit color, but 16 bit color it's only a little bit slower than the better cards. Perhaps the S3 drivers are sensitive to the CPU and chipset combination used?
Well until you swap the CPU out for a K6-3+ 550 and it gets slow again.
I should imagine one that works would be go.....
BitWrangler wrote on 2021-08-05, 03:31:Well until you swap the CPU out for a K6-3+ 550 and it gets slow again.
Ought to be just fine for my Pentium MMX 233MHz system. (PCI version anyhow.)
Much as I love 3dfx cards, the prices are absoludicrous anymore.
Need for Speed III: Hot Pursuit (Modern Patch for Need for Speed III) 1998.
Direct3D 5
Direct3D 6
NFS3 has Glide support and that is probably the fastest/smoothest option with a K6.
Need For Speed 4: High Stakes
Add a radeon 9800 pro to the tests if you are able to get one to run stable.
Kinda surprised how well the Rage 128 are doing, I don't feel so dumb for owning *cough* several now.
Sphere478 wrote on 2023-07-24, 22:00:Add a radeon 9800 pro to the tests if you are able to get one to run stable.
There is no way to test the Radeon 9800 right now.
Taking into account the weakness of the platform, most likely the performance will be equal to Radeon 9250 (Catalyst 4.7)
Need For Speed 4: High Stakes. (1024x768x16)
S3 Savage 4 Xtreme 166/166 Mhz (64-bit, 32MB, ver. 8.10.33)
S3 Savage 4 Xtreme 166/166 Mhz (64-bit, 32MB, ver. 8.20.38)
S3 Savage 4 Xtreme 166/166 Mhz (64-bit, 32MB, Creative Driver)
Riva TNT2 (driver v2.08)
Voodoo3
Need For Speed 4: High Stakes (1024x768x32)
Ati Rage128
Matrox G400
S3 Savage4
Nvidia TNT2
Nvidia Geforce 3
There is a lot of inconsistency wrt the clouds being rendered between those cards as well as between driver versions for the S3 Savage 4.
Millennium Soldier: Expendable (DirectX 6) 1999.
