Reply 20 of 37, by Eep386
Personally, I actually would recommend the DX4 Overdrive over the other upgrades if you can find it cheap. Internally it's close enough to the Intel 486DX2 that often even the buggiest and most backward BIOSes work just fine with them. Sometimes particularly old and nasty Award BIOSes struggle with the Am5x86-133 upgrades, and Pentium Overdrive support is highly dependent on both the motherboard chipset and the BIOS for it to work its best.
I've had a card exactly like that very GD5429 many years ago. If it has 60ns rated memory, it ought to be plenty quick enough for a 486 game box. (And you can squeeze a little extra performance out of it using the CIRBOOST utility.) I also noticed you found a QD6500 VLB card. That's a really good one, especially if you can find someone to burn an XT-IDE BIOS ROM chip to plug into that vacant slot. (What the XT-IDE BIOS ROM will do, is make using a hard drive larger than 503MB much less painful to set up and use. Many old 486 boards have incomplete or even non-existent LBA support, meaning you're often stuck with a 503MB or, if you're lucky, 2GB or so maximum drive size otherwise.)
    CIRBOOST.ZIP
    88.06 KiB
    38 downloads
    The file you want in this is CIRBOOST.COM, as that's the speedup utility. The others are just benchmarking tools, source codes and what not.
Reply 21 of 37, by Mvickers03
Eep386 wrote on 2020-12-13, 01:00:
That’s excellent. Pretty much a perfect chip then really. I’m really looking forward to putting it all together
Looking at the part number, it is 60ns memory. I’m in no rush but I shall be upgrading it with 2 512kb 60ns memory chips very soon
In regards to the BIOS, my father had a EEPROM reader / writer, can we write the BIOS with that?
Can you use any old BIOS chip that physically matches and reprogram that?
It would be nice to be able to have large drive support. I chose the card for its performance, I never considered about large drive support, I just thought it wasn’t possible without a PCI controller.
Reply 22 of 37, by evasive
If the chip type this board has is in the list of supported chips, yes.
needs to be the same size and sometimes have the same cell organization. Your mileage may vary.
As for large disk support, most award 4.51PG bioses can be patched relatively easy, not so for AMI bioses it seems. We still miss the bios for this board in UH19 btw so if you could make a dump and post it somewhere that would be nice.
Reply 25 of 37, by Mvickers03
evasive wrote on 2020-12-13, 16:42:
There's no mention of the P24D in supported CPUs. So I fear it's not supporting WB.
Thank you for that, I’m not too concerned, in benchmarks the WB makes a big difference, but some DOOM benchmarks I’ve been looking at actually come out a frame or two slower.
All in all, I think this is going to be an awesome machine, I just hope it’s as good as what I’m expecting. I’m looking for at least 25-30 frames in DOOM, if it does that then I’m winning.
If not then I have to spend more money, those Are the only two options available. 😅
Reply 27 of 37, by Mvickers03
douglar wrote on 2020-12-14, 02:55:
Are there any utilities that can enable P24d or 5x86 wb mode after booting?
I found this, looks like it enables WT but not WB.
http://www.vcfed.org/forum/showthread.php?619 … os-command-line
Reply 28 of 37, by douglar
I remember messing with some sort of tool that came some tool for managing the cache on evergreeen upgrade modules a long time ago.
I also remember the WB jumper pictured here:
http://www.vcfed.org/forum/showthread.php?699 … een-586-upgrade
Here are some good links about processor upgrades:
http://www.pchardwarelinks.com/cpu_proc.htm
Reply 29 of 37, by Mvickers03
douglar wrote on 2020-12-14, 18:41:
That CPU looks monstrous.
I'd love one of those, but not for the price I see.
Thanks, I'll have a read
Reply 30 of 37, by Eep386
Oh yeah, one note about Cirrus 542x VLB cards: they don't gain much of anything with 2MB of RAM, only a few interlaced modes.
I have the Evergreen 5x86 in that one thread, it's indeed a very nice processor but you must find a way to keep it cool. Evergreen fitted a far too small heatsink to the top so if you can't replace the heatsink with a larger one, you'll probably want to look into an active cooler (like a fan). Finding a fan that fits the tiny surface area of the heatsink may be difficult, but some computer cases do have cut-outs for an 80mm fan in front which you can try.
Reply 31 of 37, by OzzFan
I'm using a Kingston TurboChip for my Socket 2 486. It comes with a voltage converter and an active cooler on an Am5x86 133MHz CPU.
A (mostly accurate) listing of my computer systems: http://www.shelteringoak.com/OzzNet/
Reply 32 of 37, by Mvickers03
Thanks all. I'm too deep into the build to stop now. But not going mad with. Going to keep this one moderately specced out and keep it for really old DOS games.
I just lucked out on eBay and got a full system for £70. It knocks spots off the one earlier in this post.
Specs of the one I just won are as follows:
Processor: AMD 5x86 133Mhz Socket 3
Motherboard: Hsing tech Socket 3 PCI & VLB! 486AVIP
C2032 battery
RAM amount: 16Mb (2x8mb, 2 slots empty)
HDD: Seagate 3Gb
FLOPPY: 3.5
SCSI Controller & SCSI Sanoyo x4 CDROM
GFX: ATI MACH 64 PCI 2Mb
Sound: ISA Realtek RTA3000
Ethernet: SMC basic PCI ethernet
Comes with an AT keyboard but is a bit haggard.
I'm made up with it. Hope it survives the trip from Poland.
    376.07 KiB
    183.67 KiB
    184.17 KiB
    269.93 KiB
    192.7 KiB
Reply 33 of 37, by OzzFan
Sounds like a really good machine you won there. Even better that it comes with a coin battery instead of those leaky barrel batteries! Congrats.
Reply 34 of 37, by Mvickers03
OzzFan wrote on 2020-12-17, 18:53:
Thank you mate. I agree. Doesn't need anything doing to it really. Nothing that I don't already own anyway.
I've probably spent 300 on the build in this thread then this comes along. I shouldn't rush into things, but that's a running theme with me.
Ah well. I'm fully kitted out now at least. I hope I can have some Voodoo 2 fun with it.
I did purchase one more thing. Some people hate these drives, but I think it gets respect for lasting 30 years on this earth and still working.
It's a Connor 40MB IDE HDD.
    29.38 KiB
Reply 35 of 37, by douglar
It's funny how much each individual part costs these days, but you can pick up a complete functioning system & with a case & PS for less than the price of the motherboard if you are patient and not too picky. When I started playing with my retro parts, I needed a stable system with a floppy drive for testing. I was able to snag a 350mhz 440bx gateway for $50. Smelled like an ash tray, but has worked like a champ.
Reply 36 of 37, by Mvickers03
douglar wrote on 2020-12-17, 19:45:
Yeah, and you know what.. I kinda knew that all along. I wanted to build a full older ISA 486 from scratch. I've never had the struggles of setting up system resources and such, so we will see what it entails. Doing the 'new' build this weekend hopefully, and looking forward to it.
Will be a while before the complete system I won arrives anyway, so will be good to start setting up the hard drive, and clone onto the beast when it arrives.
All good things.
Reply 37 of 37, by Mvickers03
Most bits are here now.
Just waiting on the HDD and VLB cards.
It’s a painful wait. Some pics of progress so far.
Bye bye evil barrel battery.
