PC-Chips M321 repair work
Reply 21 of 40, by GigAHerZ
My M321 is running on Winbond W27C512 chip having MR-BIOS on it. 😀
And i was able to also read the original BIOS ROM as 27C512.
(My journey is pretty much summed up here: Chipset datasheet for M321 (PC Chips) [Found chipset! OPTi 82C391] )
Reply 22 of 40, by megatron-uk
GigAHerZ wrote on 2021-04-18, 18:28:
So there's definitely something wrong with my ROM then; it won't read at all. I'm definitely interested in trying the MR BIOS and will give it a go when those eeproms arrive.
https://www.target-earth.net
Reply 23 of 40, by pshipkov
hope you wake it up eventually.
this is one of the finest classic 386 boards.
the chipset is one of the fastest clock-to-clock ones, but does not overclock very well.
if the board starts ticking, you may consider swapping the clock gen with crystal oscillator. so far all pcb versions i have seen have through holes and witing for them (not clear from the pictures you shared here).
this way you can get it past the 40mhz.
retro bits and bytes
Reply 24 of 40, by megatron-uk
No change with a newly programmed W27C512 eeprom and a PC-CHIPS M321 BIOS image (v. 060692) from UH19:
164.14 KiB
Edit: Same result with the v. 070791 BIOS image.
Reply 25 of 40, by megatron-uk
Now, this is interesting.....
176.92 KiB
That's error code 03-- (according to the MR BIOS code list, that's a BIOS checksum error.. but at least it's evidence of something working).
This is with a MR BIOS 1.30 linked to from above - underneath it all the M321 uses a rebadged Opti 82C391 chipset, so something is definitely working at least to a certain degree... but not with an original PC-CHIPS AMI BIOS.
Reply 26 of 40, by GigAHerZ
Maybe it's a "simple" case of some data or address line from bios rom to chipset being broken?
Reply 27 of 40, by Deunan
megatron-uk wrote on 2021-04-20, 12:02:
There was battery corrosion next to BIOS area, correct? Check all the address pins - BIOS should sit on the same bus as ISA so it's probably easiest to compare with one of the slots. I doubt it's the data lines, it would probably not boot at all to even show that 03 code in that case, but check that too. Data bus however can be isolated by a '245 nearby, or (on newer chipsets) same as ISA and connected to the 82C206 chip variant.
It's also a good idea to test first vs last ISA slot, since the signals can be routed to those somewhere in the middle and sometimes the spill disables parts of the mobo but not all of it, which is hard to find unless you do these sanity checks.
Reply 28 of 40, by Woody72
I admire your perseverence! Do you mind me asking where you got the keyboard socket? The one on my motherboard is leaning at a worrying angle and I'd like to have a spare in case it ever gives up the ghost.
Modern PC: i7-9700KF, 16GB memory, RTX 3060. Proper PC: Pentium 200 MMX, 128MB EDO memory, GeForce2 MX(200).
Reply 29 of 40, by megatron-uk
My understanding at this point is that the processor is running, and has started to execute the self-test routine from ROM, writing the results to IO port 80h. So I'm pleased to see that at least the board is now resurrected enough to do that.
I did desolder the original OTP BIOS chip and cleaned under it - there was very little evidence of corrosion around it (the closest obvious damage being one main trace from the AT header and a trace from the keyboard port), but I did fit a socket in its place - I should probably triple check the soldering of that again.
179.03 KiB
Reply 30 of 40, by megatron-uk
Woody72 wrote on 2021-04-20, 12:26:
Sure - it was a pack (of 10?), pretty cheap, from one of those Chinese drop shipping sellers on Ebay:
https://www.ebay.co.uk/itm/10Pcs-Set-PCB-Pane … Nt/193878237014
One thing I had to do was bend the two metal shield support tabs on the front to fit the AT keyboard spacing on the motherboard. All the socket pins line up perfectly, it's just those non-transmitting tabs that don't quite fit - just bend them up to be flush, and then bend the tip back down again to suit the slightly different spacing, depending on your motherboard.
Reply 31 of 40, by megatron-uk
I re-touched the each of the pins on the new BIOS socket as well as the two jumper wires I soldered at the cache sockets:
https://www.youtube.com/watch?v=s0iVc30RQg0
POST error codes galore!
pushing my luck, I popped in a VGA card, and.....
71.73 KiB
54.96 KiB
60.21 KiB
116.93 KiB
IT'S ALIVE! ALIVE, I TELL YOU! 😁
I know the keyboard controller on my board won't work with the MR BIOS ROM, as documented elsewhere, so the keyboard error I was expecting. Also, there's some rubbish information on the MR BIOS info screen - cache size is wrong (and the error probably indicates my jumper wires are not working), etc. But, the damn thing now actually works!
My score is now 1 out of 3 for the pile of scrap electronics I bought from Russia for just a couple £/$ each 😁
Reply 35 of 40, by megatron-uk
A little more work and we have two new error codes, but some progress on the cache front:
38.48 KiB
58.78 KiB
According to the MR BIOS codes, they are, unsurprisingly:
- 15h: Keyboard controller failure - I've tested a 'JetKey' which I had spare, but it's no good either, so I'll probably need to pick up an Amikey or similar
- 16h: Size and test CPU cache
Regardless of whether I fit 128k of 256k or jumper for either, it only 'detects' 112k (which is an improvement on the 'Cache address line' failure I had previously). I've redone the two jumper wires and rechecked continuity, but it's got to be something related to that damage which is causing the cache errors.
Reply 37 of 40, by megatron-uk
chrismeyer6 wrote on 2021-04-20, 19:48:
This a great progress. Was there any corrosion damage around the cache sockets or the cache chips themselves?
No, no corrosion at that end of the board at all - it was limited to just a small area immediately surrounding the battery and keyboard socket. There were scratched traces on the underside of the board where the cache sockets are; I'm positive that this is the cause of the "cache detect/sizing" error. I'll admit that the size of those traces are at the limit of my what I can do by eye any more!
It probably needs a double and triple check.
Reply 39 of 40, by megatron-uk
Not really progressed any further with this. I did receive a couple of NOS Amikey-2 controllers, but they don't appear to make any difference to the "Keyboard controller failure or keyboard not present" error; I do see the keyboard lights flash on start, so there's power getting there, but I've tried the following controllers and they don't make any difference:
- Regional (as fitted originally to this board)
- JetKey (from a working 286)
- Amikey-2 (two, NOS parts)
In the meantime I'll have to do something about that cache error. I'll try removing those jumper wires and just soldering on the shortest wire links I can get away with.
