90's 10/100 ethernet switch
Reply 20 of 133, by cyclone3d
All the hubs I had after people upgraded to switches got tossed. There is 0 reason to use a hub over a switch. You won't ever change my mind.
Here is a great retro one... and from CompUSA which no longer exists:
https://www.ebay.com/itm/10-100-network-switc … a-/194136771104
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 21 of 133, by darry
Even the once ubiquitous Linksys BEFSR41 from 1999 had an integrated switch and Ethernet switches were a thing in business environments well before that .
My take on experiencing a given time period is to try to take advantage of the best that was available then, except when going for the nostalgia element .
My experience with broadband Internet at home started in early 1997 with peak downstream speeds of over 5Mbps during off-peak hours . I also bought my first 5-port switch in 1999ish, AFAICR (Netgear FS105). I am pretty sure that qualifies me as an early adopter, at least where I live .
That being said, I completely understand why someone might want to use a hub or even 10Base2 over coax,or even so far as simulating dial-up Internet, but that is taking it a step too far for me personally and, I would guess, a fair number of other people.
Anyway, we all have our specific retro kinks, some of which are only shared by a select few and that's fine by me .
Good luck, OP, and have fun!
Reply 22 of 133, by weedeewee
I recently fixed my 16 port + coax/AUI 10Mbit hub by replacing one of the chips inside responsible for half of the ports.
Came across an outdated aliexpress link on google for the chip , contacted the seller and they were still selling them.
I already had patched it to only use 8 ports before I had the replacement, and have plenty of 5 and 8 port 10/100/1000 switches around, so anyone asking themselves why I would fix that.
Well the answer is simple.
Anyway, now I have a fully working 19" wide 16 RJ45 + coax/aui 10 Mbit hub with the rackmount brackets again !
Do not ask Why !
Reply 23 of 133, by Intel486dx33
HP or Cisco or 3com from that time period were popular.
Get a managed switch.
3com and Intel network cards were most popular and had good support back in 1990’s
I would go with an HP or Cisco switch.
Reply 24 of 133, by Caluser2000
Intel486dx33 wrote on 2021-05-23, 22:15:
What do you need one of those for on a home network to systems with 10-100-gigabit nics other than bragging rights?
Oh that's right you are the resident Silicon Valley network expert from the early '90s who doesn't know how to set up a 486 system.
Reply 25 of 133, by cyclone3d
Caluser2000 wrote on 2021-05-23, 23:03:
Hah...
On the same note, I picked up a Dell 48-port switch with 4x 10Gb fiber ports a while back. 10Gb rocks for backing up and for moving files between systems.
Don't have it in my rack yet. The OS is a bit different than Cisco stuff but I really couldn't care less as it was cheap.
YMF7x4 Guide
Reply 26 of 133, by maxtherabbit
Lmao got em
Reply 27 of 133, by Caluser2000
maxtherabbit wrote on 2021-05-24, 00:13:
Lmao got em
You arte most welcome maxtherabbit.
At least he and the Brilliant Brazilian Bito Banana Boy aren't spamming vogons anymore.
Reply 28 of 133, by Horun
Just get any old 10/100 switch (NOT a HUB) that works, even the cheap "Fry's" special Hawking's PN205ES from around 2000 work OK (if they work). Still have one in a box 🤣
The older D-Link also work well, like a DSH-8 from about 1999-2000 (is actually a Switch, not a Hub) and have a few of those too. Just my opinion.
Yes there are better brand/models but as long as it really works at 10Mbit is all I care and many of the newer 10/100/1000 have major collision issues from 10mbit ;p
    316.95 KiB
Reply 29 of 133, by Caluser2000
Horun wrote on 2021-05-24, 04:05:
Yip. That's the reason I introduced a 10/100 switch into my setup.
Reply 30 of 133, by Intel486dx33
How about these.
Reply 31 of 133, by Joakim
Maybe off topic but what I used to do for internet sharing somewhere <2004 was to set up my (then ancient) slot 7 pentium 1 PC with Linux on a 3.5" floppy with dual ISA 10base NICs. On one card I had ADSL incoming and I believe the other one was connected to a switch. Awesome to be able to connect to the internet with amazing 2,5 Mbit speed on two computers.
I was probably too poor to buy a router and it was my first attempt on Linux but I think it only ran for a year or so as I think later adsl modems (that you got for free) included router capabilities, but I can't remember.
Sadly I think all that hardware was thrown away.
Reply 32 of 133, by darry
Caluser2000 wrote on 2021-05-24, 04:21:
If those collision issues stem from the newer switches' lack of proficiency at dealing with the fact that old 10Mbps Ethernet hardware does not typically support auto-negotiation or even full duplex mode on older devices, using a cheap managed modern Gigabit switch that allows manual per-port configuration should work as well .
Reply 35 of 133, by chinny22
In '99 I upgraded f rom coax to a Netgear DS 108 hub.
Google a picture of that then have a look at Netgear's GS product range and you'll see not much has changed!
I'd say any blue Netgear switch gives you authentic look but yeh I'd recommend a switch over a hub now cost isn't a factor.
Something like a Cisco Catalyst 29xx would have been the "ultimate switch" back then. Overkill for a small home network but if your after um, period correct sex appeal?
HP, Dlink, 3Comm, Intel are the other brands that come to mind.
Personally use a 24port Dlink DES-1024 from around 2001. It wins over the Cisco's and HP's I have thanks to its on/off switch. Useful on rackmount switch's that usually have fans and your retro pcs are in the bedroom!
Reply 36 of 133, by Intel486dx33
chinny22 wrote on 2021-05-24, 15:24:
In '99 I upgraded f rom coax to a Netgear DS 108 hub. Google a picture of that then have a look at Netgear's GS product range […]
Stay away from Netgear or other cheap switches. From my experience these tend to lock up and not work properly with high end network cards.
Get a good switch like HP or Cisco or Linksys. Back in 1990’s I had a 16 port HP 10/100 switch at home and it worked fine.
Reply 37 of 133, by BitWrangler
Joakim wrote on 2021-05-24, 07:59:
Actually my first router was a 486dx2-66 16MB with dual NICs connected to that 8 port+coax hub I mentioned. It was quite a nice setup running linux based FreeSCO, but I could never get any other geeks interested because they were all "ewwww SCO" despite it standing for "Free ciSCO" and nothing to do with SCO. Further into the 2000s that thing was getting hammered relentlessly with port scans and various other scriptkiddie BS... it was blocking them just fine, it was just running out of CPU time to do the routery thing... I was going to replace it with a PII box, but I think it was one of those linksys jobbies mentioned above that filled the gap for a few months, before I got a nicer Netgear WiFi router for cheap.
Reply 38 of 133, by BitWrangler
I dunno if that intel one pictured is any good but at least the logo matches ones on the later half of 90s CPUs 🤣
Reply 39 of 133, by Intel486dx33
BitWrangler wrote on 2021-05-24, 16:45:
Yeah, I use to have one of those Intel switches back in the 1990’s
They have BIG GREEN LEDs in front. They put on a light show for sure.
But I dont know much about the internals or its reliability.
So I would rather go with the HP or Cisco or Linksys.
